Mazda BT 50 20,000 Km Service cost
Submitted: Thursday, Jun 26, 2008 at 18:50
ThreadID: 59229 Views:15478 Replies:7 FollowUps:10
Howdy Folks, we have a BT 50 manual 4X2 due for the 20K service. I phoned the local dealer in Cardiff to book it in & asked the price for this service & was told it was $450.00. I didn't book.
Then phoned the Mazda dealer in Newcastle who quoted $450_ $500
It's our first diesel & I was a bit taken back at that sort of money.
The service record book does not state what they actually do, just provision for date etc & the fact that any particular service had been done.
We have for many years had our vehicles serviced by a licensed & reputable workshop & have always been happy with them. Just worries me a bit with it being a diesel.
Any comments or advise about comparisons between dealerships & quality private workshops would be appreciated.
I am aware that if I move away from dealership servicing that it does not effect warranty.
Thanks.
Reply By: Member - Tessa (NSW) - Thursday, Jun 26, 2008 at 19:20
Barry
Try All 4x4 spares at McDougall St Kotara. They service some of the diesels in our club and the guys seem pretty happy with them.
Thay seem to have a pretty comprehensive workshop setup.
tessa
AnswerID: 312389
Reply By: Member - Mark G (NSW) - Thursday, Jun 26, 2008 at 19:20
BARRY F ; i get my 04 navara serviced at a private workshop and he goes by the service manual,and cheaper than the dealership.
AnswerID: 312390
Follow Up By: Member - Bucky (VIC) - Friday, Jun 27, 2008 at 05:21
Ditto !
Why pay for a tradesman, and get an apprentice.
As long as the private garage, ( mechanic ) can stamp the book.
ie.. liscenced,, and follow the schedule laid out in the manual, there are no issues.
And it heaps cheaper..
Bucky
FollowupID: 578457
Reply By: nowimnumberone - Thursday, Jun 26, 2008 at 19:30
in your service book will only be a place to stamp once the service has been done but if you read your owners manual you will find the list for servicing and what needs done at what ks
AnswerID: 312394
Follow Up By: Member - barry F (NSW) - Thursday, Jun 26, 2008 at 19:55
Thanks, but I have had a look at that, & still can't see where the $450.00 is.
FollowupID: 578380
Follow Up By: wigger - Thursday, Jun 26, 2008 at 20:03
Barry'
Servicing of these BT 50's and Rangers is expensive E.g Ford dealer at sothport wants $600 plus to do 20k service Says it's because the tappets need to be done (can beleive this cos mine are rattly at 19k) and also some possible Bsh.t about the front hubs needing to have the grease repacked. For gawds sakes, these are 2 WD's that don't go near water and mud. I am going to a mechanicic at Biggera waters for $200 but will have taken care of the oil change and filter and fuel filter (at my cost first).
Be careful with the oil that you put in or let any garage puts in . They may try and use some cheap 10-40 crap.
Castrol techno whom I trust has said that you should be using a 5-30 oil and their call would be "Castrol Edge Sport " Synthetic .
It's expensive and at 7.5 litres every 5000k will hurt but if you don't do it, you could have warranty complications later on.
To be on the safe side ring Mazda HQ and ask what the servicing requirements actually are.
Incidentally I am running Bridgstone 623's and I'm not sure to what degree these tires may be contributing to the problem but this ute must be the most evil minded scary handling vehicle i have ever had. Go over the Tomewin range road and if it is the slightest bit wet, then if you give it a touch too much brake or loud pedal, it will dump you in a ditch. Often have to fill a tractor tube with a couple of hundred litres of water to try and get it to behave.
FollowupID: 578383
Follow Up By: Stephen M (NSW) - Thursday, Jun 26, 2008 at 20:07
"Ford dealer at sothport wants $600 plus to do 20k service Says it's because the tappets need to be done (can beleive this cos mine are rattly at 19k)"
If it goes to the dealer I would be putting a mark or some thing on the rocker cover to identify that it has been removed. I got my doubts it will be removed !!. Regards Steve M
FollowupID: 578384
Follow Up By: GoneTroppo Member (FNQ) - Friday, Jun 27, 2008 at 07:43
Wigger
have a look at your tyre pressures, all the Thai stuff has very crude suspension setup to say the least.
the dealer then puts 45psi all round and off into the ditch you go.
Unladen, try 28psi front and 22psi rear and see if there is an improvement.
Turmed my RA rodeo from a dangerous pig into something semi civilised.
FollowupID: 578464
Reply By: Stephen M (NSW) - Thursday, Jun 26, 2008 at 20:04
I would just take it to who you used before, or a reputable mechanic like the one mentioned above. No offence to apprentice mechanics as I know they have to start some where BUT in big dealerships I have found that they just throw tthe cars at the guys and say service it with out giving them the guidence needed. You would probably be fairly safe in the first few services as most would be filter changes, check this check that park back out the front, but when its time for the bigger services, t/belts etc it can be a gamble who is going to be working on your pride and joy. At a smaller garage/workshop they want you to come back and they want you to spread the word about there workmanship and the apprentices most likely have rebuilt a motor before and know what there doing and get trained properly. As long as you use genuine filters (Toyota state you use genuine filters or you void warranty even when not serviced by them) If you know some one that can possibly get the filters from Mazda cheaper for you/trade price then take to your own mechanic. The service bloke will get them trade price anyway but most add a few $$$ to the price (not all). I know a Toyota dealership here in Sydney now charging $120 an hour. Apprentice would be lucky to get $15 of that. Regards Steve M
AnswerID: 312403
Follow Up By: wigger - Thursday, Jun 26, 2008 at 20:22
While we are on the servicing subject:
1 Is the fuel filter for the BT 50 the same as the Ranger. Should be!!
2 How much is the Mazda one compared to the Ford one .
As far as I can ascertain there is no generic filter available yet. Someone posted on this subject within the last six weeks.
3 Has anyone else had this bs about wheel bearing repacking.
4 When you change the oil only, you actaually drain the filter as well because it is on the horizontal, so don't bother unscrewing the filter to empty it.
5 There are aftermarket oil filters around. Will give you code if you require.
FollowupID: 578396
Follow Up By: Stephen M (NSW) - Thursday, Jun 26, 2008 at 21:07
Sorry wigger cant help you in regards to if the filter is the same or price. Wouldnt be surprised if the ford one is cheaper but can you use it technically ?? (warranty) even though as you would think they would be the same. Wheel bearing repacki phfff ??? I'm surprised there not a sealed bearing these days more so on a 4 x 2. They would want to be changing the filter at least every 10k. I dont see the point in puting new oil in and having an old filter on there ??.Regards Steve M
FollowupID: 578409
Follow Up By: wigger - Thursday, Jun 26, 2008 at 21:38
Stephen , the oil is supposed to be changed every 5000k but the filter is only every 10. Lots of vehicles have a filter change at only every second oil change so yes, the new oil goes into a used filter. The filters are only $13 so i should change them every 5k kms too.
I wish I could get the "real oil" on why the oil needs to be changed every 5000 because the fuel I use is only 10ppm sulphur.
Seems like a big con.
I remember where I saw the info on the fuel filters and it was the
...............com site. The Mazda filter is a lot cheaper surprisingly than the Ford one.
This was meant to be a cheap to run work ute but I don't think so. Expensive servicing (at the dealer), expensive oil, very frequent oil changes, lots of ganga to keep you settled waiting for it to head off into the scrub.
FollowupID: 578416
Follow Up By: Member - John F (NSW) - Friday, Jun 27, 2008 at 09:20
Wigger,
I'm no expert (here we go...) but, it's not just about sulphur in the diesel. If you do a short run to the shops etc and the engine doesn't get hot, I believe you get all sorts of condensates diluting the oil.
The current Hilux has 10k intervals for oil, which I'm happy with, using good Penrite and not doing many short runs.
Totally agree with most of the comments re dealer servicing - too much of a lucky dip for me. Most services should be around the $200 mark including oil and filter. Big services $400-500 doing other fluids etc.
BTW, any comments/experiences re the Hilux fuel filter and its lack of recommended replacement? From memory, still only an inspection at 100k?? Is that because the greatest risk to injectors/pumps is from careless filter changing allowing contamination??
Regards, John.
FollowupID: 578474
Follow Up By: wigger - Friday, Jun 27, 2008 at 22:43
Ok . Got it wrong . The Ford fuel filter which is probably identical to the Mazda one is $32.73.. the Mazda one is $115. (Southport dealers)
FollowupID: 578615
Reply By: Grassparrot - Friday, Jun 27, 2008 at 13:20
Dont have a Mazda but have a new dual cab triton that was serviced a couple of months ago at 15,000 for its first service and I went to a local small mechanic who I have alsways used and I checked first that my warranty would not be voided and all is ok. He charged me $190. Tell them to stick their $450 for oil and a filter.
Grassparrot.
AnswerID: 312523
Reply By: Stephen M (NSW) - Friday, Jun 27, 2008 at 18:57
Hi Barry, they just had on current affairs about the servicing for new cars. Funny thing was they were doing it on a BT50. The cheapest what your local garages, Ford was nearly half the cost of Mazda to get the service done and you can legally get it done by who ever you want and it wont void warranty even useing non genuine parts as long as they comply with Mazda, so in other words say the oil, must be say 15/40 or 20/50 just for example. If you jump on the net and get on there website you will probably be able to rewatch it if you missed it on TV. Regards Steve M
AnswerID: 312609
Reply By: Member - 120scruiser (NSW) - Friday, Jun 27, 2008 at 20:53
Here is an excert from the ACCC in regards to warranty servicing.
Warranty service ACCC
AnswerID: 312637
