Does it work or not.
Submitted: Wednesday, Jul 02, 2008 at 06:29
ThreadID: 59422 Views:2343 Replies:3 FollowUps:5
Does it work or not ?? Wouldnt have a clue but sounds ok Regards Steve M
http://yobgbcefbmcchgx.claimroot.com/t.asp?a=c&u=140679229&s=1753&e=1612451
Reply By: Saharaman (aka Geepeem) - Wednesday, Jul 02, 2008 at 07:44
Hi Stephen,
Thanks for the link. It does seem an interesting product and appears to be better than normal fuel additivies (like Pro Ma etc.).
But the advertising blurb always sounds good on these sort of products. I wonder if its available in Australia and how good it is for diesel engines (says it works on diesels as well as petrol). If its available locally and a reasonable price probably not much to loose by giving it a try.
GPM
AnswerID: 313381
Reply By: Member - Graham H (QLD) - Wednesday, Jul 02, 2008 at 09:47
Remember if it sounds to good to be true it usually is.
AnswerID: 313394
Reply By: Member - Porl - Wednesday, Jul 02, 2008 at 11:59
Gees there's some cr@p out there, I got sent a website for pills (no reference to the now defunct and fraudulent Firepower) for cars and, believe this, crumbs for diesel trucks .... meant to post it here but I have deleted it cause it was so ridiculous.
If I had the time to more research on the EPA I'd be at least willing to give this one a single go if what they say about their accreditation is true. Would also like to hear from some industrial chemists on this one!!!
And I was in California in the 70's and the fog was unbelievable.
AnswerID: 313408
Follow Up By: madfisher - Wednesday, Jul 02, 2008 at 13:22
Don't forget the old time truckies use to put moth balls in they fuel tanks for extra power.
Cheers Pete
FollowupID: 579478
Follow Up By: Member - Mark G (NSW) - Wednesday, Jul 02, 2008 at 13:29
when i was into motorsport we used to put mothballs in our tanks to up the octane,worked a treat.
FollowupID: 579480
Follow Up By: Member - Porl - Wednesday, Jul 02, 2008 at 13:31
Well there you go, you learn something every day. I await a new eduction in this area.
FollowupID: 579481
Follow Up By: zacc - Wednesday, Jul 02, 2008 at 15:49
i had a high compressin motor that i could not stop it from pinging, ground up some moth balls put it in a tank of gas and no more pinging. was told it was an old speedway trick that was used.
FollowupID: 579490
Follow Up By: Member - Mark G (NSW) - Wednesday, Jul 02, 2008 at 16:15
thats where i used it.
FollowupID: 579495
