caravan tv reception
Submitted: Sunday, Jul 06, 2008 at 18:02
yap yap
Does a HD set top box improve TV reception in the out back ?
Reply By: Notso - Sunday, Jul 06, 2008 at 18:42
If there is a signal then it is usually better.
But, there are quite a few
places that still only have analog
If you get digital, also get a good quality antenna amplifier.
314154
Reply By: DIO - Sunday, Jul 06, 2008 at 19:31
The accompanying
Link has some useful information on the subject.
314164
Reply By: RoyHarv - Sunday, Jul 06, 2008 at 23:04
Hi yap yap
My understanding and experience is that HD does not provide any stronger signal than standard digital.
If you want TV in the outback then you need to look for a satellite dish & decoder.
(Got this stange feeling you may be a distant inlaw, I'm sure my wife has some yap yap genes!!!!)
Cheers Roy
314200
Reply By: Seeker - Monday, Jul 07, 2008 at 09:22
I can help you with this question. I own an run a major
TV antenna company in
Perth WA. Digital reception (HD or SD) will give you a better clearer picture but only if digital is being broadcast from the transmitter in your area and if the signal strength and quality are above a certain value. With a digital signal HD & SD are both transmitted in what they refer to as a transport stream. So if you can decode SD you can decode HD. I personally wouldnt waste my time trying to pick up signal whilst travelling with a
TV antenna. The issues you come across are vast. Firstly they transmit on different channels. ie in
Perth they transmit on 2, 6, 7, 8, 9, 10, 11, 12, 28, 29, & 31. In the bush they might transmit in the middle 50's. This means you need a different type of antenna to pick up the different bands. Also the polarity of the signal changes. It will be either horizontal or vertical. I would by a good quality 85cm dish and a satellite decoder and pick the signal up from the Optus C1 satellite via Optus Aurora.
314218
Follow Up By: stevesub - Monday, Jul 07, 2008 at 15:55
I agree. We have just returned from 2 weeks in Coastal/Outback QLD. When we could get Digital TV it was fine but the majority of
places either had very bad or no digital reception so out with the old analogue TV, snow and all but at least a picture of sorts. I also got a few books read at night time when the analogue was no good.
Stevesub
580287
Reply By: Wizard1 - Monday, Jul 07, 2008 at 15:26
Best solutions for poor TV reception when away from it all i the outback.........read a book, go for a walk, have a conversation, play cards, etc, etc.
What did we do before?
314250
Reply By: Member -Dodger - Monday, Jul 07, 2008 at 16:46
Haven,t you lot heard of the Bush TV.
= Sitting Around a blazing campfire.
Mesmerizing
Image Could Not Be Found
314262
