uhf radio problem
Submitted: Wednesday, Jul 16, 2008 at 19:04
ThreadID: 59830 Views:6746 Replies:9 FollowUps:7
I have installed my GME radio as per instructions but get a lot of static and a high pitched squeal when receiving a signal. I can't have the volume any higher than about a third or it becomes ear piercing...any advice?
Reply By: Sir Kev & Darkie - Wednesday, Jul 16, 2008 at 19:08
Have you adjusted the Squelch??
Cheers Kev
Russell Coight:
AnswerID: 315645
Reply By: Member - Dennis P (Scotland) - Wednesday, Jul 16, 2008 at 19:26
Just wondering if you have one of those electronic rust protection or battery life extender thingies.
AnswerID: 315649
Reply By:- Wednesday, Jul 16, 2008 at 19:49
I have adjusted the squelch but no difference.
And no rust protection except the good old lanolin
I am going to re-do the antenna connection to see if that is the problem
AnswerID: 315652
Follow Up By: Member - Davoe (Yalgoo) - Thursday, Jul 17, 2008 at 01:06
usually is
FollowupID: 581905
Reply By: Member - kevin Y (SA) - Wednesday, Jul 16, 2008 at 20:10
Why not get it professionally fitted , i feel sure you would find it works a lot better than d i y .
mine did
AnswerID: 315657
Reply By:- Wednesday, Jul 16, 2008 at 21:09
yes, that will be my next step!!!
AnswerID: 315673
Reply By: Member - Glenn D (NSW) - Thursday, Jul 17, 2008 at 01:05
Hows it going,
I am guessing you have a kit type set up with the coax pre terminated ?
Does your radio have a separate ground or just a negative wire , check your grounds out !
Glenn.
AnswerID: 315699
Follow Up By:- Thursday, Jul 17, 2008 at 17:43
No, not pre-terminated. My did, same radio same truck, everything works fine!!
FollowupID: 581977
Follow Up By: Member - Glenn D (NSW) - Friday, Jul 18, 2008 at 19:42
You could get a multi meter and measure resistance from centre to shield - should be very high .
If you have continuity try looking at your connections.
FollowupID: 582166
Follow Up By: Member - Glenn D (NSW) - Friday, Jul 18, 2008 at 19:56
Just reread your response , if you have done the same install in another truck with no problems you could probably rule out routing problems .
Try running the radio with everything else on the truck isolated (pull fuses out for constantly powered accessories), if its still bad its not an interference problem , if it comes good try putting fuses back in till you find whats interfering.
Hope you sort it out.
Glenn.
FollowupID: 582170
Reply By: Member - Phil G (SA) - Thursday, Jul 17, 2008 at 16:53
I guess you had to hook up a PL-259 plug to the aerial lead. In case you weren't sure about how to do it, here are some instructions:
Image Could Not Be Found
AnswerID: 315778
Follow Up By:- Thursday, Jul 17, 2008 at 17:45
Thanks for the instructions, similar to what I had. I have just redone the connection and still the same.....almost time for ro me thinks!!!
Thanks for all the feedback everyone
FollowupID: 581978
Reply By: Louie the fly - Thursday, Jul 17, 2008 at 19:05
Hey, is it feedback? It may be caused by close proximity of other electronic devises. i.e. stereo speakers, microphone, etc. Not an electronics guru but have installed my fair share if comms over the years. There are lots of things that can cause problems. Check where your wiring (coax) goes. Is it near any vital car electronics???
Good luck.
AnswerID: 315807
Follow Up By:- Thursday, Jul 17, 2008 at 19:42
Ok, good question......coax runs from antenna anlong inside wall of engine bay past my auxillary battery through the firewall and in behind the glovebox. The coax and power wire from the radio do run through the same grommet in the firewall would that cause it?
FollowupID: 582015
Follow Up By: Louie the fly - Thursday, Jul 17, 2008 at 20:01
One thing that may be of concern is if you have an electronic battery monitor near the coax. Not saying it will be a problem, but could be.
FollowupID: 582021
Reply By:- Saturday, Jul 19, 2008 at 08:24
Thanks to everyoneor your tips and advice. I will be going overr it from start to finish tomorrow and try process of elimination, then if still no joy its off to the professional
Thanks heaps guys
AnswerID: 315979
