Landcruiser '85 FJ60 Hubs
Submitted: Tuesday, Jul 15, 2003 at 04:21
ThreadID: 5993 Views:3279 Replies:4 FollowUps:0
I'm not sure if this is the best place to ask this question, but I just bought an '85 FJ60 and found that one of the locking hubs appears to be frozen. Does anyone have any tips to see if I can 'unfreeze' at home before I take it to the shop? Also, just in terms of driving RPMs. I drive it around 2500-3000 RPM's on flat ground before I shift, on heavy climbs, what is the max RPM's you want to keep it under?
Reply By: Tony - Tuesday, Jul 15, 2003 at 08:40
It can be done at home. Jack up the corner you are working on, looking at the hub there is from memory 8 x 10mm bolts that hold on the outer flange remove them and with a light tap the flange will come off (romove gasket as well) then undo the 6 x 12mnm nuts that hold the main part of the FWH onto the wheel hub, this will need a fair bit of tapping with a brass hammer, when loose inside will be a cir-clip that retains the front axle in place, remove the cir-clip and the FWH should slid off the axle.
Now it can be stripped down for further cleaning.
# Before removal check and see what position the hub is in, Locked or unlocked. Not that it really matters it will still come off.
For re assembly you will need to re pack it in grease, provide new gaskets or gasket goo, a long bolt to screw into the end of the axle so you can hold it out to put the cir-clip back on. Re assemble in the reverse order.
AnswerID: 24965
Reply By: Member - DOZER- Tuesday, Jul 15, 2003 at 10:20
Hi Geogirl.
Ther are 6 10mm screws to take the outer off, and you may find that when you do, the problem is just in there, as thats where the locking and unlocking happens. Make sure it is water free and lightly coated with grease. If you are that far into the hub, and you want to check the wheel bearings then continue with the disassembly, but it gets alot more involved and you need special tools to do the job.
ps set of hubs for sale on ebay at the moment to suit. www.ebay.com.au wheredayathinkwer mike?
AnswerID: 24977
Reply By: Steve from Drive Systems Victoria - Tuesday, Jul 15, 2003 at 21:07
And after you have washed and degreased all the parts, lightly, read LIGHTLY, grease the moving dog coupler, as too much grease can cause the same problems. Then get in the habit of locking those hubs once a month, preferrably out in the scrub, eh?
AnswerID: 25035
Reply By: Billowaggi - Wednesday, Jul 16, 2003 at 23:00
I have come across a few hubs that have been assembled and fitted incorrectly, always make shure that the position of the internal dog corresponds with the external marking, eg. dog screwed up to plate-free,---dog extended--lock, it is best to assemble in the free position. Also tend think this area is not for a beginer, probably best if you get someone that knows what they are doing to show you first. Sometimes they are stiff through lack of use and sticky grease try some [very] gentle persuasion.It sounds like a front hub and wheel bearing service may be due.
Regads Ken.
AnswerID: 25165
