OME Shocks setup
Submitted: Thursday, Jul 17, 2003 at 13:58
ThreadID: 6025 Views:2368 Replies:5 FollowUps:7
Can I get some advice on what to go for? Heavy duty front & Medium (2" lift all round) for rear was what the guy at ARB proposed for my 1997 80LC 1HD-FT engine (Hope I got it right). I don't tow very heavy stuff (At present). Just up to eight person & 3 mountain bike when travelling far & Tows a light trailer around town for work every now & then. Will be looking for a steel bar up front in the future and winch if I get lucky. Do I need HD Springs for the rear too?
Interesting that ARB have spec Caster kits & lower shock stone guards with the package. All good & bad comment pls. Rgds
Reply By: Member - Karl - Thursday, Jul 17, 2003 at 14:06
If you are going to add the steel bar and winch then I would suggest that you do get the heavy duty springs now as it will be cheaper than doing it later by doing it as one package.
Karl
AnswerID: 25197
Reply By: Member - DOZER- Thursday, Jul 17, 2003 at 15:12
Hi Wil
I would go for the 850 front spring if you are getting bar and possibly winch, and the diesel engine is a heavy sucker aswell (compared to a 1fz) also the 863 rear which is medium hvy duty.
Only do the caster if you are unhappy with the way it steers afterwards, because it is a step backwards for articulation, and once a winch goes on it will be closer to how it is now.
Andrew (850 on the front)wheredayathinkwer mike?
AnswerID: 25199
Reply By: Member - Graham - Thursday, Jul 17, 2003 at 15:38
Wil, heavy front & medium rear, if it is some time to the bullbar fitment, the steering will be alittle sensitive, at 100ks becomes very annoying that it doesn't seam to go strait. Its not a comfortable drive. I had to wait a couple of weeks for the bullbar to come, any longer you'll too get frustrated with it.
I would think that they could preload the front and set it up to start with then the jobs done, just a thought. Stone guards do there job.
AnswerID: 25200
Follow Up By: Wil - Thursday, Jul 17, 2003 at 16:53
Graham
Is your a diesel engine? Could I possiblilly get away with it since I have a diesel motor? If money is no object, then I would go for the whole lot.
I would like to have it all eventually, hopefully by Christmas. :(
FollowupID: 17050
Follow Up By: Member - Graham - Thursday, Jul 17, 2003 at 17:18
yes 1hz
FollowupID: 17055
Follow Up By: Wil - Thursday, Jul 17, 2003 at 20:08
Just a though. What If I workout the weight of the bullbar & goodies for the front. Then just bolt some dead weight (die plates or steel channels) to the inside of the front bumpers for now. Then it should ride like I have all the stuff on! :V
FollowupID: 17064
Follow Up By: Wil - Friday, Jul 18, 2003 at 15:44
Sorry..wasn't reading your message. Preloading means exactly that.;)
FollowupID: 17126
Reply By: Truckster (Vic) - Thursday, Jul 17, 2003 at 16:14
The BEST way to do it is to set up your car first, then do the suspension last.
Otherwise if you set it up now for a bar and winch in future, its gonna suck until then. Or if you dont, its going to cost you money down the track to do the suspension AGAIN...
YMMV
AnswerID: 25201
Follow Up By: Wil - Thursday, Jul 17, 2003 at 16:32
What if I just raise the back now and wait till later on to do the front in 1 go? Problem is the back is saggin big time and the 285/75 is touching the inner guards when cornering at speed or diving into a dip at high speed.
Will I get good driving charateristics with a rear raise?
FollowupID: 17048
Follow Up By: Truckster (Vic) - Thursday, Jul 17, 2003 at 17:04
Its up to you, you could put spring packers in there from ARB. $20ish that would raise 10mm and save your tires until you have the $ to do it right.
I just have learnt the hardway to think ahead... You could do what you suggested, many do, you could try
FORSALE SECTION OF LCOOL - http://www.lcool.org/sale/classifieds.html
FollowupID: 17053
Follow Up By: Truckster (Vic) - Thursday, Jul 17, 2003 at 17:06
FOR SALE 4/7/03
80/105 suspension, OME 850 front springs(3 inch lift) and Dobson 5 inch lift rears.(20mm wire, 1 inch higher than heaviest OME 864) good condition $250.00 for the set, suit cruiser with a bit of weight to carry around.
Email me for a photo of the cruiser with them on.
Andrew Lukies limo4b@ozemail.com.au
Ive dealt with Andrew before from sold.com.au, very good. hes here to I think. hes in Wollongong area.
FollowupID: 17054
Reply By: Wil - Saturday, Jul 19, 2003 at 15:46
Thanks to all for your reply. I have decided to go for the 860/8500 combo & caster kit as recommended by ARB. Apparently the wheel alignment guys said that it's good for handling. Which is important to me. Cheers
AnswerID: 25350
