van levelling
Submitted: Monday, Jul 28, 2008 at 22:05
ThreadID: 60264 Views:2988 Replies:9 FollowUps:8
when using our van (14.6 Windsor rapid ) in the bush where the ground is not level, i use a jockey wheel with a plate on the bottom. I put this in the square tube for the jack point to raise the van from the side. Not enough to lift the wheel up but to just level the van. then lower the corner stabilizers to make the van safe.
Is this acceptable as far as chassis stress? to me its the same using blocks under the wheels.
cheers Shane.
Reply By: Member - Doug T (FNQ) - Monday, Jul 28, 2008 at 22:08
shane
I think for a van of that size it would be no problems
AnswerID: 317771
Follow Up By: jdwynn (Adelaide) - Monday, Jul 28, 2008 at 23:07
welcome back Doug!
FollowupID: 584131
Reply By: donk - Monday, Jul 28, 2008 at 22:16
Why do you do this instead of carrying a leveling ramp around with you
It seems like a difficult way to do it
Regards Don
AnswerID: 317775
Follow Up By: Member - shane (SA) - Monday, Jul 28, 2008 at 22:33
I find it much easier to do this than use levelling blocks. picture this, all i do is grab the jockey wheel that i have cut the wheel off and welded a plate on the bottom and a 40 mm square tube to the side with a brace on it. I just walk up, put it in the hole where the jack goes and give it a few turns until the water level i have mounted on the side of the van"s jacking point in front of me is level. It takes no more than three minutes. then use the front jockey wheel to raise or lower the front as needed, all done in a few minutes.
the other way you have to guess the height to go up, put the wood or what ever down. then get back in car, move onto wood. get out look if it is right, if not, do the whole thing over till it is. lots of back and forward for nothing. as far as time goes, i would put my way against the other way any time.
cheers Shane.
FollowupID: 584124
Follow Up By: Member - Redbakk (WA) - Tuesday, Jul 29, 2008 at 01:19
Pretty smart Shane....should patent it m8.....might use it myself...make up two
FollowupID: 584150
Reply By: donk - Monday, Jul 28, 2008 at 22:45
We use plastic ramps on our 23 footer
My wife goes inside the van with a 12 inch plastic level & sits it crossways inside the freezer (2 door fridge) & as i run it up the ramps (in low range 2wd so it happen slowly) she tells me when it is level side to side with a hand held uhf
I then get out of the patrol,put the van park brake on,disconnect the vehicle & level it front to rear with the jockey wheel
With out old single axle van we used to use blocks of timber but as you said it is a pain but the plastic ramp gives anywher from o to 5 inches of lift if needed & you only have to do it once
Regards Don
AnswerID: 317782
Follow Up By: Member - shane (SA) - Monday, Jul 28, 2008 at 23:01
Hi Don, that is a fine way to do it but the way i do it i only need me. Our routine is as follows, park van where SOMBO says to park it, then get out, walk around and undo the roof clips. turn gas on, grab the jockey wheel and level side to side, level front, drop down corner jacks, lower beds at end. by this time the brides made the coffee and all done, under five minutes. i also like to disconnect the power from the car.
Some time we watch other people set up and i have seen them take a half an hour, i know there is no hurry but some thought saves a lot of shoe leather.
cheers Shane.
FollowupID: 584130
Follow Up By: HGMonaro - Tuesday, Jul 29, 2008 at 09:37
Shane, your method sounds great except one thing.... you're on here asking if it could be damaging your van!
What I'd do is to try to work out if the van is twisting as you do this. If the jack point is in the middle'ish it might be fine. Not sure how you can test it though without some fancy instruments, maybe park it on a flat surface and measure front distances to ground as you jack it up to see if it goes up evenly. Also, listen as you do it, you might hear nasty sounding noises that tell the effects.
Cheers, Nige
FollowupID: 584170
Follow Up By: Member - shane (SA) - Tuesday, Jul 29, 2008 at 19:44
Hi Nige, im asking because i can't think of any reason why there should be a problem. but there is always something someone else thinks of and you don't. just checking.
cheers shane.
FollowupID: 584336
Reply By: donk - Monday, Jul 28, 2008 at 22:48
With out old single axle van we used to use blocks of timber but as you said it is a pain but the plastic ramp gives anywhere from o to 5 inches of lift if needed & you only have to do it once
Regards Don
AnswerID: 317783
Reply By: jdwynn (Adelaide) - Monday, Jul 28, 2008 at 23:11
Shane, slightly OT, but did you end up dragging the van up the Strz / Cordillo? If so how did it go? JD
AnswerID: 317787
Follow Up By: Member - shane (SA) - Tuesday, Jul 29, 2008 at 19:02
Hi mate, no did not go that way, the problem is the mother in law is crook and the bride did not want to be more than six hours away. so told her next trip is up there weather she's alive or dead.
cheers shane.
FollowupID: 584310
Reply By: Member - Tessa (NSW) - Tuesday, Jul 29, 2008 at 13:31
Shane
I presume that you leave the jockey wheel in place in the jacking hole for the entire stay. If so, the problem I see is that you are effectively placing the weight of that side of the van on the chassis at the jacking point for an extended period of time. The stabilisers are just that, stabilisers, they should not be considered weight bearing to any great extent. If you want to find out how strong they are just try and wind the van up with them after they take up the slack. You have removed the weight from the suspension which is designed to spread that weight over the distance between the u-bolts which attach the van to the suspension. You should also consider that although your van is only 14.6, when you open the bed/s out and insert their human occupants at night you are extending the radius of the load and creating a much greater downward pressure on that single axis point in the centre of the van. (sorry I can't remember if the Rapid has beds at both ends or only at the back). I appreciate that a proportion of the load is also being borne by the front jockey wheel but I have genuine concerns for the weight at the rear. Ask Roachie about carrying extra loads in the back!!!
tessa
AnswerID: 317875
Follow Up By: Member - shane (SA) - Tuesday, Jul 29, 2008 at 19:22
Thanks tessa, this is why i asked the question. the jacking point is right next to the rear spring mount so i think even if i don't use the jacking point and put the beds out, it would still have the same stresses. by putting the stabilisers down this should stop the stress at the far ends. the stabilisers are the drop down ones so are vertical and take the weight quite well.
cheers shane.
FollowupID: 584323
Reply By: Thermoguard Instruments - Tuesday, Jul 29, 2008 at 20:07
Hi Shane,
I appreciate the comments of others but from my experience (we've lived & travelled in our van(s) more or less full time since 2002), your approach will cause no damage as long as you don't repeatedly try to lift the entire weight of one side on the modified jockey wheel (and I doubt you could anyway, with a standard mechanical wind-up type). Afterall, that's where most jacking points are for tyre changing...
If you're on such a side slope that the side jockey 'wheel' gets difficult to wind and the chassis starts a bit of creaking and groaning, then you're obviously trying to take too much weight and will need to put a block under the wheel (or better yet, convince the 'bride' to pick a better spot!). Raising one side a couple of inches will cause no drama at all IMHO.
Do be aware that doing any lifting/supporting at the rear spring hanger (behind the axle) will put a more weight on the front jockey wheel but, again, I'm sure it would not be a problem..
All caravan chassis do flex a bit when supported in any unusual way (e.g. supporting it on chassis stands when parked for long periods, etc.) so the biggest problem you're likely to find is that the door might go a little out of alignment if you have a fair bit of weight on your side support.
I'm sure you are aware of this (or maybe, like me, you've done it yourself?) but, remember to always wind-up/stow the corner stabilisers before moving either your side or front jockey 'wheels'...
Ian
AnswerID: 317965
Reply By: Nomadic Navara - Tuesday, Jul 29, 2008 at 20:30
Shane
You do not mention levelling the van for and aft before levelling side to side. I level my van side to side and then use the jockey stand (wheel) to level the van fore and aft. I can not see how to level the van both ways by your method. Out in the bush I don't use blocks, I use a small shovel and dig the wheel or wheels in on the high side. Much more stable that way.
As for your original question - With the length of your van there may not be much of a problem with one side supported at the ends and the other by the axle. Chassis are not completely solid items. There is a little bit of flexibility in them. Most of my vans have been on Preston chassis, these all have had a double chassis up to the front spring hanger. The 15' van had the door at the front and I did not see much flexing when over tightening the stands. However the 18' and 19' 6" (body length) ones have the door at the back end. Both of these, when you attempt to level the van side to side with the stands, the door is likely to jamb. It does not take much to flex the van to make a well fitting door catch on its door jamb.
As posters in earlier replies said, the stands are for steadying the van, not to jack it. You are much better levelling the van side to side with the axle and then fore and aft with the jockey wheel.
AnswerID: 317975
Reply By: Member - shane (SA) - Tuesday, Jul 29, 2008 at 21:15
thank all for replies, as no one seems to think there will be much of a problem ill keep doing it. i will pay attention to the doors and their squareness.
Just for the record, i level the van side to side then front to back.
cheers shane.
AnswerID: 317993
