TAINTED WATER TANK
Submitted: Friday, Dec 14, 2001 at 01:00
SCOTT
Can anybody help me get rid of the tainted taste in my watertank.
Tank is on camper trailer and is of plastic construction... thanks
Reply By: tim - Friday, Dec 14, 2001 at 01:00
1 try vanilla essence added to
tank
2 there is a chlorine based addititive available at most camping/caravan outlets
3 both seem to work.
1589
Reply By: Graham - Friday, Dec 14, 2001 at 01:00
Scott,
The problem might lie in what u r using to fill the
tank with and the hose delivering the
water from the
tank to the outlet. U never elaborated on the type of taint.
I had a problem with tainting (plastic taste)in my
tank and replaced all the hoses including the hose I use to fill the
tank, with "drinking water" hose which is available thru any specialist hose retailer, problem solved. Hope this helps.
1590
Reply By: Roger Lowry - Saturday, Dec 15, 2001 at 01:00
Scott
What has been said about the hoses is true but to get the taint out you will need to flush your
tank out with clean
water then refill and put in some puratabs which are readily available from most
camping and caravan outlets. Let this
tank stand for a few days then reflush your
tank add more tabs and Bobs your uncle.
Cheers Roger.
1591
Reply By: mudguts - Monday, Dec 17, 2001 at 01:00
Vanilla certainly works and agree with the others re
water hoses.I've used an old publican's trick is to
flush the lines and
tank with a strong lime cordial solution - it works fine but can be a bit sticky getting
the cordial into the
tank.
1605
Reply By: Mark Wilson - Monday, Dec 17, 2001 at 01:00
I had a similar problem recently and fixed it by removing the
tank from the camper trailer and emptying it of the contaminated plastic tasting
water. I then mixed up a brew of 500gms of bi carb soda to about 30 litres of
water and put it in the
tank and mixed it round for a while. The next day I drained the
tank and set it in the sun to completely dry out. I then fitted it to the trailer, filled it with
water and its been fine ever since. Touch wood. Hope this helps.
regards Mark
1607
Reply By: scott - Monday, Dec 17, 2001 at 01:00
Thanks for all your replies. Whilst the camper has all the correct plumbing i must admit to using the old garden hose to fill
tank. I will invest in a length of proper hose from now on. I sure after a bit of work this weekend using the above info the
water out of my
tank will be sweet as next time we use. Thanks again everyone this is a great
forum and i have picked up lots of useful tips just reading through Cheers and hope to catch up in the bush.. Ill shout you a drink of
water.....
1612
Reply By: Wayne Prictor - Monday, Dec 17, 2001 at 01:00
try a large bottle of Vanilla Essence with a full bucket of hot
water put it in the
tank
and leave it for 24 hours drain it and refill theTank,the taint should be gone . Hope this Helps
1615
