ADvise for a dual battery system with LPG
Submitted: Friday, Jul 18, 2003 at 01:50
jeelan
Anyone got a dual battery system in a Patrol GQ with LPG setup????
Just wondering if this is possible without moving around the components of the LPG system.
Looking under my bonnet, i think they've installed the LPG unit in the biggest space they would find, right where the dual battery would ideally go..
Are there altnerative
places where a second fully sealed battery could go, ie under the car itself somewhere????
regards
Jeelan
Reply By: Voxson (Adelaide) - Friday, Jul 18, 2003 at 09:23
I have
mine in a marine box in the rear where the dickie
seat comes from...._____________________________________________
25271
Reply By: Gerry - Friday, Jul 18, 2003 at 09:51
My LPG converter is mounted on the firewall, passenger side. This leaves the 'usual' spot next to the radiator overflow bottle for the second battery clear. Can you shift the converter? Alternatively, a fully sealed battery can go inside the car somewhere but make sure you use beefy wires.
Gerry
25273
Reply By: ROBERT - Friday, Jul 18, 2003 at 11:11
GETTING THE DUAL BATTERY SYSTEM WAS ONE OF THE BEST THINGS IVE DONE TO THE CAR I HAVE A 1991 GQ PATRO GAS /PETROL TOOK IT TO ARB FITTED THE BATTREY IN FRONT OF THE RADIATER REFILL BOTTLE I ALSO HAD A EXTRA LIGHT PLUG FITTED IN THE BACK WHERE THE FRIDGE PLUG WAS GOING AT THE SAME TIME JUST FINNISHED 6 WEEK OUT BACK TRIP AND ALL RAN PERFECT HOPE THIS HELPS ROB
25285
Reply By: Truckster (Vic) - Friday, Jul 18, 2003 at 13:21
Theres discussion on this here.
GQ Patrol Owners List
25298
Reply By: diamond (bendigo) - Friday, Jul 18, 2003 at 13:31
gday jeelan.
i have gq on gas and i fitted my 2nd batt opposite original had to move a couplke of things but no major problemsnew job coming so no fraser this time:-((
25299
Reply By: Member - Bonz (Vic) - Saturday, Jul 19, 2003 at 19:41
I had my converter relocated to the drivers side when I changed to an Impco system, The fitters always fit them on that side, makes the run shorter converter to engine and works better. Left heaps of room on the passengers side for battery, compreseor etc.
All the bestSo many
places to go!
So much work to do :0(
25366
