Photo's of fridge slide and drawer system
Submitted: Friday, Aug 01, 2008 at 17:21
Ross H (QLD)
I finished off my drawer system a few days before we set off to this years gathering and didn't get around to uploading the pictures.
Would like to say a special thanks to member Pezza (bris) for the advice he gave me in the search for materials to make it.
Image Could Not Be Found
Reply By: Lotzi - Friday, Aug 01, 2008 at 17:26
Very tidy,
well done.
Lotz
318538
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 17:39
Thanks Lotzi
584985
Reply By: Willem - Friday, Aug 01, 2008 at 17:30
Hmmmm Very flash,
young fella. Looks a lot better than
mine :-)
318539
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 17:43
Hahaha somehow I don't think I could fit in as much as you intend to Willem and not real sure it would hold up to the pounding you intend to give yours. And unless you are just on 1400mm long I don't think you could sleep in it either. lol
ross
584986
Reply By: Member - Vince B (NSW) - Friday, Aug 01, 2008 at 17:43
Smart looking & practical set of draws
Ross.
Quite impressed with the new style of fridge slide.
Cheers.
Vince
318540
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 17:50
Thanks vince
The fridge slide is worth every cent it was so easy to access while on the road. The drawer system was quite easy to make using 1" qubeloc and pushin fittings.
ross
584989
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 17:58
Vince in behind the panels on the left and right I have 120amp agm's mounted into battery cradles.
Ross
584991
Reply By: Member - Warfer (VIC) - Friday, Aug 01, 2008 at 18:06
Great Stuff Rosco !
318542
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 18:10
Thanks Warfer
Ross
584995
Reply By: Member No 1- Friday, Aug 01, 2008 at 18:22
what are the bearing/slides arrangement for the draws...more detailed photos please
certainly looks the goods
318546
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 18:45
Hi No 1
The slides were 1000mm long 100kg load got them through Hettich in
sydney.
Will take a more detailed pic in the morning.
Ross
585005
Follow Up By: Ross H (QLD) - Saturday, Aug 02, 2008 at 16:47
Hey No 1 here are some pics of the runners
Hope that helps
Ross
585152
Follow Up By: Member No 1- Saturday, Aug 02, 2008 at 16:54
thanks
Ross
looks like i'll be off to hettich next week
585155
Follow Up By: Ross H (QLD) - Saturday, Aug 02, 2008 at 17:10
No1 when I get back to work on wednsday will have a look at my emails as I think I may have a pdf file on all the sizes and load ratings.
Ross
585161
Reply By: greybeard - Friday, Aug 01, 2008 at 18:27
looks great.
where did you get the fridge slide from? and ~ how much was it?
318550
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 18:50
Hi greybeard
Got the slide through TJM at Geebung (bris) price will vary from $490 to $550 I was lucky and got the $490 as I have just about brought the
shop. LOL Have spent a bit there over the years.
Ross
585008
Reply By: Cape York Connections - Friday, Aug 01, 2008 at 18:54
So it pulls out then drops down is that rite.
Is so you will sell a million.
All the best
Eric
318555
Follow Up By: Cape York Connections - Saturday, Aug 02, 2008 at 08:16
Sorry is it a commercially made unit.
All the best
Eric
585083
Reply By: ExplorOz - David & Michelle - Friday, Aug 01, 2008 at 19:38
I need one of those fridge slides that drop down like that - what a great idea. Is this the TJM part or a self modified system or a little of both - I have not seen this slide arrangement before but reckon it looks the goods. So where can I get it or will I have to spend some garage time to make it up?
318563
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 19:51
Hi David
This unit is sold through TJM as a complete unit but some people have found them hard to get I guess I was lucky.They work really
well and with the gas filled struts are very easy to lift up even with a fridge full of drinks. If you can't sourse them through TJM over there try going through TJM in
Brisbane and talk to Daniel.
Ross
585023
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 19:55
Sorry should have said TJM Geebung PH (07) 36330377
Ross
585025
Reply By: Member - joc45 (WA) - Friday, Aug 01, 2008 at 19:59
Very neat,
Ross!
Still intrigued how those drop-down fridge slides work. Good to see they're finally being delivered.
I like the idea of the AGMs being stowed down the back sides, esp in what would otherwise be unused space. Keeps them away from the heat of an engine bay.
Have been reading so many postings about fridges being knocked off, I have bought one of those locks like on your drawers and will fit it to the fridge slide this weekend. They'll have to wreck the drawer system to get the fridge out.
When I re-fit the system next week, I must put some pics up on my profile.
Well done!
Gerry
318568
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 20:09
Hi joc45
Thanks. The fridge slide comes with its own lock and key in the front. The sad thing is if they want your fridge bad enough it wouldn't matter if you had it chained they would just keep smashing things until it came out or it was so stuffed you couldn't use it.
I will put up some more pics of the slide at different stages so people can get an idea how the work.
ross
585032
Follow Up By: Ross H (QLD) - Saturday, Aug 02, 2008 at 16:56
Hi joc45 here are some pics of the fridge slide being used.
Hope that gives you a better idea how it works
Ross
585156
Follow Up By: Member - joc45 (WA) - Saturday, Aug 02, 2008 at 17:41
Brilliant!
Mine's just a simple slide-out where the Autofridge goes into a boxed-in enclosure. I have two small 12v fans at the front to push air thru when the compressor starts. The boxed-in part ensures adequate ventilation around the sides of the Autofridge. Hope to get pics up soon.
585168
Reply By: Gone Bush (WA) - Friday, Aug 01, 2008 at 20:08
Ross,
you've mentioned one part of the fridge arrangement coming from a place in
Sydney and the rest (I think) from TJM.
Can you please confirm that the whole arrangement is not available from one supplier.
And if that's the case, what were the individual pieces and did you have to join them together somehow.
Just a little more detail please mate.
318571
Follow Up By: Member - Matt M (ACT) - Friday, Aug 01, 2008 at 20:13
Keen to hear as
well Ross. It looks great (whole set up and the fridge slide).
Matt.
585033
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 20:19
Sorry guy.
Member No1 asked about the drawer slides not fridge slides.
The fridge unit is as it appears one complete unit. They weigh about 25kg so they are a bit weighty and seem to be quiet strong.
ross
585035
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 20:21
Sorry guys.
ross
585037
Follow Up By: Gone Bush (WA) - Friday, Aug 01, 2008 at 20:21
Thanks for that clarification
Ross.
Should read things a bit more closely.
It looks great.
It's on my list.
585038
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 20:22
MMMMM I have a stutter
585039
Follow Up By: Ross H (QLD) - Friday, Aug 01, 2008 at 20:25
Hi gone bush
Was a bit weary as they were so new, but to be honest it was great for our needs as it would be a real PITA to get into any other way.
Ross
585040
Reply By: Member - Brian H (QLD) - Saturday, Aug 02, 2008 at 10:38
Nice work
Ross, the draw face on the left is a bit out by the looks of it LOL.
The fridge slide if it is the same company where stationed in
Brisbane and I beleive importing the components and assembeling them here. Many people had placed ordered when they first came out but issues arose about supply and many people waited for months to get them.
I beleive this issue has now been addressed and supply is not a problem now.
I inquired about the slide some twelve months ago and put a post on here about this slide and speaking with company they were going to have one big enough to take a trailblazer so may try and contact them and see if it is part of range now.
Brian
318626
Follow Up By: Ross H (QLD) - Saturday, Aug 02, 2008 at 16:23
Hahaha
Thats because that was the one you were holding when I drilled it. LOL
Bloody builders cant trust them.....hehehe.
I think it was more an assembly issue than an import issue.
Have to catch up.
Ross
585145
Reply By: Member - Brian H (QLD) - Saturday, Aug 02, 2008 at 10:57
Thread 52376 has a bit more info on this slide I posted one about a week before this thread but cannot be bothered to fine it.
Or you could try this web site
www.platinumgear.com.au
Brian
318628
Reply By: Best Off Road - Saturday, Aug 02, 2008 at 13:17
Very nice job
Ross.
Jim.
318637
Follow Up By: Ross H (QLD) - Saturday, Aug 02, 2008 at 20:43
Thanks Jim
Don't think I will be giving you any competion soon though.
What a pita de-buring all the tube, didn't have a cold saw.
Ross
585218
Reply By: Jo and Mark (Qld) - Saturday, Aug 02, 2008 at 19:26
So when do I drop the paj over to you?
318677
Follow Up By: Ross H (QLD) - Saturday, Aug 02, 2008 at 20:48
Hahaha sorry Jo only work on nissans namely
mine.
Would the paj be able to handle the extra weight and swing those muddies as
well. LOL
Ross
585221
Follow Up By: Jo and Mark (Qld) - Monday, Aug 04, 2008 at 15:15
HaHaaaa yeh she is starting to get a little tired now!
585474
Reply By: Pezza (Bris) - Thursday, Aug 28, 2008 at 09:27
Ross,
Yeah I know, bit slow lol, been a tad busy two wheelin round the outback throwing rocks at EO members apparently, sorry bout that Kev ! LOL.
Then lost the email notifying me of this thread.
Nice job mate, but then knowing you and your "do it right or don't do it at all" attitude I expected nothing less, :-))
No need for the mention, was only too glad to be of assistance.
I may climb back into one of them lumbering 4 wheel behemoths again one day and see you by the campfire.
Cheers mate
Pezza
322596
Follow Up By: Sir Kev & Darkie - Thursday, Aug 28, 2008 at 10:36
Pezza,
You may have been one of the ones that actually stayed on the black stuff as I had the schites after the first dozen or so and pulled over and stopped for them. But even then some still liked to get off the black stuff to go past.
Cheers Kev
| Russell Coight:
589647
Follow Up By: Ross H (QLD) - Thursday, Aug 28, 2008 at 21:29
Hi Pezza
Been a while,
Trev and I kept a look out for you on our way
home but by the sounds of it you all went bush.
Will have to catch up soon.
Ross
P.s don't worry about kev (just another whinnig toyota driver LOL.)
589776
