L300 4x4 very weird problem
Submitted: Monday, Jul 21, 2003 at 12:33
Deano
Hi all,
Just purchased an 87 L300 after a great deal of hunting around. In great nick and drives like a dream. The other day after
parking suddenly there is no reverse gear or 5th, with no warning at all. I had a look at the unfamiliar linkages and all gears seem to select so I dropped the tray off the box (5 speed) expecting the worst.
There was very little metal in the oil and the inside of the box looked fine to my untrained eye.
There are 2 selectors run by cables from the gearshift, does it sound like a simple adjustment problem or do I need to look further? I also unhooked the linkages and tried to manually get the gears but still no joy.
It drives fine, no noises just no 5th or reverse! can even put it into reverse or 5th while driving and it acts just like as in neutral.
Deano
Reply By: Deano - Monday, Jul 21, 2003 at 15:06
Found it...
Nut on the rear of the gearbox holds the shaft that controls 5th and reverse.
Fairly common to come loose after heavy load in reverse such as pullingh someone out of a bog.
Just got to pull it down now to fix.... :(
25492
Reply By: Member - Willem- Monday, Jul 21, 2003 at 18:26
Hi Deano,
Mitsubishi's had a gearbox problem with the 5th gear retaining nut up until about 1988 when they fixed it. Normally gearboxes would last around 80,000 to 150,00km and then the plastic fastener that held the retaining 5th gear nut disintegrated and then
the nut would wind loose and drop off and stuffing the gearbox totally. This normally happened at speed. You have been very lucky not to have this happen to you. I would pull the box down and have a good look at it. Contact Mitsubishi to ask what the procedure is to remedy this.
Cheers, Willem
Never a dull moment
25510
Reply By: Deano - Monday, Jul 21, 2003 at 19:40
Thanks Willem. I will certainly take your advice and give the box a good going over. That will be this weekend taken care of! :)
25521
Reply By: Eric - Monday, Jul 21, 2003 at 21:48
deano.
The recomended fix for the large nut that comes loose is to grind a second slot in the mian shaft opposite the factory one and then double stake the new nut. There is no plastic retianer just the stake. Eric.
25543
Reply By: Deano - Tuesday, Jul 22, 2003 at 01:09
Much appreciated Eric. Will do. Damn you guys are great. Learnt more here in a day than 4 calls to Mitsu themselves. :)
25565
