Orbital 100AMP battery
Submitted: Saturday, Oct 04, 2008 at 22:45
imjames
Hi there I just have had fitted a Orbital 100AMP Deep Cycle Battery and a Projecta 12Volt 100Amp Battery Isolator fitted. Was wondering if anyone has the same and can advise how much running time a Engel 40litre fridge would run for on it. thanks
Reply By: Member - Phil G (SA) - Sunday, Oct 05, 2008 at 00:48
Check the specs on your battery.
From the website, Exide Orbital has a reserve capacity of 100minutes at 25amps. They don't quote any numbers for the actual capacity, which I expect is about 50Amphours.
Running time varies with temperature, fridge setting, how often you open the fridge, and what you put in it etc etc But I expect it should be good for 24 hours (give or take a day :-)).
328473
Follow Up By: Robin Miller - Sunday, Oct 05, 2008 at 21:35
Yep thats about what I get Phil.
My orbitals good for some 24 hours , by which time its around 11.5v , and in really shouldn't be used below this for a long life.
(My Waeco fridge draws 1 amp per hour in average conditions)
595844
Reply By: Member - DOZER- Sunday, Oct 05, 2008 at 20:14
If you work on 2 amps per hour current draw of a 4 amp fridge running 50% of the time, it should last 50 hours
328573
Reply By: Member - Norm C (QLD) - Sunday, Oct 05, 2008 at 20:56
If it is a failrly new 40 Litre Engel, it is rated to draw 2.5Amps when compressor is running. I have verified this to be correct with a Clamp metre.
So assuming you won't run the battery down below 50% (recommended for long battery life) that gives 20 hours of compressor operation.
How many hours per day the compressor operates will be dependant on fridge setting, ambient temp, how often fridge is open and other factors.
I'd figure if you keep the fridge in the shade as much as possible, you will go close to 2 days of operation. Assuming you have no generator / battery charger or solar charging, it is probably worth running your motor at fast idle for 15 mins twice per day if not doing any driving. That will make sure you can go 2 days (perhaps a bit more). If driving for an hour or more per day, you should be fine.
It is worth considering getting a fold up solar panel at some stage if the budget can handle it. Not cheap, but a 100W panel will (under normal circumstances) give enough power to charge your battery and run your fridge and
camp lighting almost indefinitely.
This is one available from Derek Bester an advertiser on this site:
100W Solar Panel
Good luck.
328580
