Minimum 5th gear speed for LC100
Submitted: Friday, Aug 01, 2003 at 08:56
ThreadID: 6295 Views:2083 Replies:4 FollowUps:0
I have just bought a petrol, manual LC100 and I was wondering as to what the minimum speed one should drive in 5th gear. In my old 4runner you could tell when the motor was labouring, but in the 'cruiser the motor has so much grunt and the soundproofing is such that it is difficult to hear the engine struggling. I have been told in the past from various sources that loading a motor in too high a gear can cause excessive wear on the cylinder walls. Opinions please, thanks.
Reply By: Member - Bob - Friday, Aug 01, 2003 at 09:02
There was also mention that this will cause excessive wear in the fifth gear cog.
AnswerID: 26487
Reply By: Member - Willem- Friday, Aug 01, 2003 at 09:28
Hatcher,
5th gear lowest speed has been advocated over the years as 80 km/h. 5th gear is an overdrive gear to reduce revs when motoring at speed. The gear is not designed to work under load. I am not sure whether the weight of the vehicle comes into contention. My dad was a Jaguar enthusiast and had a string of manual cars commencing in 1973. They were pretty heavy vehicles as I recall and the Drivers Manual stated that the electric overdrive should only be activated at speeds higher than 80km/h.
Your Toyota Drivers Manual should tell you which 5th gear speed is advisable.
Cheers, Willem
Never a dull moment
AnswerID: 26490
Reply By: Treading Lightly - Friday, Aug 01, 2003 at 10:21
I have juts looked up the Owners Manual and there is no mention of min speed for any gears only the max. However it does say not to labour the engine in any gear.
So it's up to your ears and judgement I guess. Great waggons arn't they.
JDLife is to good to be dead.
AnswerID: 26501
Reply By: Bob Y. - Qld - Saturday, Aug 02, 2003 at 07:22
Hatcher,
Was advised by an ex Tojo dealer to use 5th only above 80 clicks. Have used this method for over 10 years, with no problems with 5th. Only gearbox problem have ever had with a tojo, was with 2000 model 79 series, when all gears lost syncro, speedo stopped working and bearing noise had to heard to be believed. Repaired under warranty.
Don't worry about whether the motor is labouring, do as Willem said, and don't overload 5th. Happy travels, but you should have bought a diesel. Hooroo...
AnswerID: 26604
