2003 Viscount Newport
Submitted: Saturday, Nov 01, 2008 at 08:05
rehose
Hi - We have just bought a 17' single axle Viscount and it sways all over the road - wondering if any other Viscount owners have had the same problem. It only has 75kg ball weight without
water in the
tank - and is positively dangerous. Have had lots of experience towing before and never had this problem. We have moved the
water tank closer to the front and this gives us a bit more - but were wondering if it is a design fault or something like that.
Reply By: Member - Mark G (NSW) - Saturday, Nov 01, 2008 at 08:09
REHOSE
it would pay you to get a set of good lift/sway bars.
cheers.
332967
Follow Up By: rehose - Saturday, Nov 01, 2008 at 08:22
Mark - thanks for your reply - We have 4 bar load levellers and have tried towing with them on and then taken them off and it doesnt make any difference. We have towed it with a Falcon S/W and also with a 4wd Jeep with the same result.
600815
Follow Up By: Member - Graham H (QLD) - Saturday, Nov 01, 2008 at 09:23
The 4 bar levellers are probably too light for it Get a proper Hayman Reece setup.
Would also pay to get the suspesion checked for looseness in bushes and pins etc.
Am surprised you didnt take it for a drive before buying it and you would have found out before parting with cash
600823
Follow Up By: Member - Graham H (QLD) - Saturday, Nov 01, 2008 at 09:28
Also if it has a bar axle check it for straightness If one wheel has been pushed back it will wallow around like a drunken sailor
600827
Reply By: Best Off Road - Saturday, Nov 01, 2008 at 08:28
Had the same prob with a similar van.
Step 1. Move a lot more weight forward, this will help a lot.
Step 2. Get a WDH, they make a world of difference.
Jim.
332969
Reply By: MEMBER - Darian (SA) - Saturday, Nov 01, 2008 at 08:59
I need to learn quite a bit about towing soon (upcoming van project), but in research I've seen mention of (here and elsewhere) anti-sway bars can be an included accessory in a load levelling hitch setup - would pay to enquire direct with an expert. BTW - why not ascertain the tare on a weighbridge, then arrive at your gross and then get the ball to 10% of that one way or another - that classic formula might get rid of the sway in itself ?
332976
Follow Up By: rehose - Saturday, Nov 01, 2008 at 09:59
Thanks everyone - will check these things out!
600830
Reply By: Cruiser 2091 - Saturday, Nov 01, 2008 at 12:03
Hi rehose.
I suspect the 75 Kg ball weight is the problem.
I have a 16 ft van which should have similar spec to yours. It has a Tare of 1060 and aggregate mass (fully loaded) of 1300. Now this means that the nominal ball weight should be 130kgs (10%) however some say that up to 15% is permissable.
The Hayman Reece 4 bar intermediate levellers are rated at 1300 / 130Kg so should be correct. Remember though that these llevellers are just that levellers, their purpose is to prevent the back of the car going down and the front comming up.
Check the loading of your van and make sure it is not back heavy also jack it up and check for looseness in the
suspension.
The ball weight can be checked by using bathroom scales, you can even use the scales with a long bar and fulcrum so the full weight of the van is not on the scales. You then multiply the reading by the leverage ratio.
Hope this helps.
332997
Reply By: Graham & Ann - Sunday, Nov 02, 2008 at 17:56
A WDH is only just a that, a weight distribution hitch, to distribute some weight off the rear axle to the front
wheels of the tow tug and the vans
wheels. The 4 bar should be fine for under 130kgs ball load. As a rough guide, ball weight generally needs to be up towards 10% of total weight of van, but a lot depends on how
well the van is designed. A properly loaded and designed van shouldn't sway in normal conditions. BUT to help stability in bad weather, strong side winds etc.... try fitting one of the sway control devices, we use the HR friction
Sway Control
Have used one for the last 120,000km towing over all roads.
333198
