Dreaming
Submitted: Sunday, Nov 02, 2008 at 17:42
ThreadID: 63154 Views:3285 Replies:7 FollowUps:9
Wondering what others, more experienced in the ways of 4wd would do.
If buying a brand new Toy Motor cab chassis (yep you can dream it)
would you fit it with the manufacturer's
Towbar
Diff locks
Air Con
Tray top
Bull bar
Or would you buy a 'bog standard' poverty version vehicle and then head for the manufacturers specialising in the various add ons that will make it a more capable 4wd.
Any thoughts ??
Reasons?
Reply By: OzTroopy - Sunday, Nov 02, 2008 at 17:48
Brand New ?????
Always go with approved ( in writing ) or factory options ...
If something breaks ... its warranty and they cant blame somebody elses better equipment for a fault.
AnswerID: 333196
Follow Up By: Member - Footloose - Sunday, Nov 02, 2008 at 17:53
Totally agree. Many times you can have install problems with aftermarket stuff, and some of it isn't up to scratch. The F/O's can also actually work out not better but also cheaper...certainly in the long run.
FollowupID: 601038
Reply By: austastar - Sunday, Nov 02, 2008 at 17:55
F/O = fitted options?
AnswerID: 333197
Reply By: Sir Kev & Darkie - Sunday, Nov 02, 2008 at 18:04
I personally would only fit the -
Towbar,
Diff Locks and
Air Con.
I would get a custom made Tray that suits your prefered set up. ie all in one tray and canopy.
Aftermarket Bullbars are stronger that the factory option and have better mounting points for accessories like spot lights and aerial mounts.
JMHO
Cheers Kev
Russell Coight:
AnswerID: 333199
Follow Up By: Member - Mark G (NSW) - Sunday, Nov 02, 2008 at 18:09
kev
.........like the KING GEE tojo,
any tougher it'd rust lol
FollowupID: 601046
Follow Up By: Member - Tour Boy (Bororen) - Sunday, Nov 02, 2008 at 18:36
Come on Kev you know the factory steel bullbars are made by ARB and are 1/2 the price.
Eg for the lux it was $1300 from arb in rocky and $880 for the same bar at toyota both commercial steel non airbag winch bar.
the only difference is the pretty ARB badge that must be worth $420...LOL
2015 Fortuner
Had 72 cruisers in my time
FollowupID: 601060
Follow Up By: Sir Kev & Darkie - Sunday, Nov 02, 2008 at 18:42
Dave,
The factory one on Darkie is not worth the paper it is written on. I am now going to get side rails and steps to strengthen the outer sides of the bar.
Cheers Sir Kev
Russell Coight:
FollowupID: 601063
Follow Up By: Member - Tour Boy (Bororen) - Sunday, Nov 02, 2008 at 18:49
Kev hopefully by the time you get back I will have sold the lux and bought back my 105 and I'll show you how to strengthen an ARB bar so the truch crumples up to it and set the truck up right.
2015 Fortuner
FollowupID: 601066
Reply By: Member - Mick O (VIC) - Sunday, Nov 02, 2008 at 23:41
Most of the dealers will fit all that ARB stuff at a "dealer" price which usually represents a good discount off what the punter pays at ARB. You can then also pump them for a further cut. The trick is to have the accessories invoiced seperately to the price of the vehicle and not lumped in as an all in one price. If it's lumped in, you pay stamp duty on it and that's not cheap in Victoria at least!
Mick
AnswerID: 333280
Reply By: Trekkie (Member - WA) - Monday, Nov 03, 2008 at 00:45
austastar
If my choice I would buy the "poverty pack" and have the extras fitted by specialist 4WD - you will end up wih a far more capable vehicle. Certainly the Towbar, Diff Locks and Bull Bar. Air con could be different.
I would do my sums carefully - while it was 7 years ago when I purchased my vehicle, I fould the dealer to be more expensive than the likes of ARB or O/L
AnswerID: 333291
Reply By: offroad Bob - Monday, Nov 03, 2008 at 22:06
I did buy a brand new LC 70 cab chassis. I went with the dealer approved ARB roo bar, scrub bars, side steps. The toyota tow hitch, air/con and toyota weather shields. I gave the Diff locks a miss as the unit comes with a limited slip diff and IMHO this works better than diff lockers. This humble opinion comes from comparing my friends cruiser with twin diff lockers to mine. In a straight line his seems to go OK but rarely when off road and in deep bog do you get straight lines. When diff lockers are off all you have is an old banjo diff.
AnswerID: 333494
Follow Up By: offroad Bob - Monday, Nov 03, 2008 at 22:07
Just to add - I went with the GXL model to get the bucket seats - and mags, flared guards, plus lots of chrome are a bonus.
FollowupID: 601333
Follow Up By: Member - Serg (VIC) - Tuesday, Nov 04, 2008 at 08:04
Do not know about LC70, but in my LC80 LSD been doing very little if anything at all. IMHO saying that LSD better then *ANY OTHER* traction aids (manual, semi-automatic, fully automatic diff-locks, lokka, Detroit etc) is plain ignorance. I can assure you that you either been trying non-operational diff-locks or you pick up very plain bog hole. LSD (even best one) DOES NOT operate at very low speed – it need some kind of difference in speed to be activated, thus one need to spin wheels in bog hole to activate it thereby only digging himself more. While any diff-locks can hold wheels locked at any speed, allow slow controlled progress with de-bogging. Not saying that LSD utterly useless on rock crawling. And on top of it Toyota LSD is clutch-type, thus with time friction material wear-out and diff need to be opened and pre-load spring need to be readjusted or replaced to keep LSD in shape. While diff-locks (factories for sure – no o-rings to wear-out) will be in service until diff itself wear out. What was OT about? About dreaming if I am not mistaken?
Serg
FollowupID: 601374
Follow Up By: Member - John F (NSW) - Tuesday, Nov 04, 2008 at 19:55
Hi Serg
You have touched on an interesting point which maybe you could clear up for me - "LSD ... DOES NOT operate at very low speed".
In my bog standard 06 Hilux, with, I understand, a rear LSD, when doing a slow, tight turn on fine gravel you can see that the rear diff is "locked" - the inside wheel claws at the gravel. I guess if that was soft mud then both wheels keep supplying some drive, hence they work well in that situation. Am I wrong?? I have little technical knowledge, but this was how it was explained to me by "Bob", our instructor at a 4wd course.
I guess if one wheel is off the ground then my LSD is only of use if the torque required to drive forward is less than the spring resistance in the diff - so a locked diff would be far superior.
So back to your point... why don't you think they work at low speed? Mine does!! (Well, I think it does)
Regards, John.
FollowupID: 601438
Follow Up By: Member - Serg (VIC) - Wednesday, Nov 05, 2008 at 09:49
Hi John,
I would not comment on all LSD – frankly there is common consensus that Nissan’s one is far better then Toyota’s one. However I did have LC80 with LSD up until I have fit ARB diff-lockers. LC80’s LSD (and AFAIK all Toyota’s ones, though I may be wrong on this point) is clutch-type spring-preload LSD. It means that there is multi-disk clutch fitted between left and right half-axels. This clutch is pre-load with strong spring calibrated in such way that when RPM of half-axles differs a little (i.e. cornering) it “slips” allows one wheel travel faster than other. But when RPM of half-axels differs more it does not slip that well anymore and divert some torque to wheel with less RPM (i.e. those one that not rotating and have traction). Basically from there it calls “limited slip differential”.
LSD is good device and doing job well in “non-extreme” situation. However it does have own limitations. Firstly because it “limited slip” it must occur some slip before it start to send torque to wheel with traction; this dumb mechanical device newer can distinguish what you are doing –cornering or trying to get out of bog hole. Secondly it *CANNOT* send 100% torque to wheel with traction, again because it is “limited slip”. And last, but not least being clutch-type related on friction it does wear out and with time its effectiveness decrease dramatically up to the point that it doing nothing. Then diff must be overhauled, possibly clutch plates and/or spring replaced and pre-load need to be recalibrated.
It modern cars like Prado fitted with traction control same effect can be achieved by electronic means. When computer sense that one wheel rotating faster then other AND steering wheel straight that it applies brakes to offensive wheel thus sending 100% of torque to wheel with traction. This system better then LSD, though it’s activation can be jerky.
IMHO diff-locks are ultimate traction aid because once locked it send 100% torque to both wheels without any slips or jerkiness. Sure they also have disadvantages like cost, necessity of manual interference and in some instances wear components (like ARB’s o-ring for example) that require some periodic maintenance. Also there are many “in-between” automatic solutions like Lokka or Detroit auto-locking diff. There been a lot of fruitless debated what is better. IMHO it came down to the point of one’s preference, driving style and expected harshness of application. I personally in general like manual, hate automatic and as result incredibly happy with my manual diff-lockers, though would prefer Toyota’s ones. As usual choice is yours and YMMV.
Serg
FollowupID: 601522
Reply By: Member - Serg (VIC) - Tuesday, Nov 04, 2008 at 07:33
As for me I would fit difflocks and aircon. Towbar for those who plan to tow. IMHO anything else would be better to get elsewhere.
Serg
AnswerID: 333545
