GME TX3200 issue
Submitted: Monday, Nov 03, 2008 at 20:41
mike w (WA)
Hello all learned ones,
I have a GME TX3200, and upon turning on display 'err'. Im guessing that this indicates an error, but does anyone have any ideas as to why?
Mike
Reply By: Member - Graham H (QLD) - Monday, Nov 03, 2008 at 20:46
What does the troubleshooting part of the manual say Or check on the GME site they may have a support FAQ
333459
Follow Up By: mike w (WA) - Monday, Nov 03, 2008 at 22:29
Manual says nothing, neither does the site. thanks for the suggestion.
Mike
601345
Reply By: Member - Andrew (WA) - Monday, Nov 03, 2008 at 21:03
Does it run off an auxiliary battery??? if so...is the battery flat? does it happen when the car is running?.
I had a similar issue and found the battery wasn't holding charge any longer and the CB only worked after running the car for a few minutes...
New battery...no worries.
Just a thought.....
333466
Follow Up By: mike w (WA) - Monday, Nov 03, 2008 at 22:28
No, off of the main battery, but something to investigate non the less.
601343
Follow Up By: howie - Tuesday, Nov 04, 2008 at 12:09
mine was showing 'err' or 'tx3200' on the display recently.
aux battery stuffed, only 8-9 volts.
new battery, all good now
601394
Follow Up By: Member - Roachie (SA) - Tuesday, Nov 04, 2008 at 13:33
Mike, maybe your battery is okay (starts the engine etc), but then you could still have a poor connection somewhere between the battery and the radio, which equates to the same end result.
So, check all the wiring to the radio. Is it wired direct from the battery to the radio via a fuse? If so, check the connections and the fuse holder etc. If it gets it's power from another source that you've tapped into (eg; one of those HORRIBLE sctch-lock gizmos), check those connections. In my experience Scotch-locks are a source of numerous electrical woes and I refuse to have them on my vehicle. Instead, if I want to tap into an existing power cable (where a sctch-lock would commonly be used), I actually strip a portion of the insulation (about 3mm long) off the donor cable and wrap the new cable around it and then solder (being careful of dry solder joints), followed by covering the new joint with liquid electrical tape or wrapping it in standard electrical tape.
Roachie
601403
