2006 TD Cruiser Issues
Submitted: Monday, Nov 03, 2008 at 21:04
ThreadID: 63209 Views:3155 Replies:8 FollowUps:9
Hi to everyone
and hope you can feed me some information.
Sadly I need to upgrade my faithful 325K , 80S TD Cruiser .
I am looking a a 2006 TD Cruiser, manual gearbox, and around 70K on the clock.
Does anyone have any info on any issues I should look for ?
I have already heard about possible front diff issues but is there anything that seems to be a common problem to have a look at ?
thanks in advance
Reply By: Member - Graham H (QLD) - Monday, Nov 03, 2008 at 21:27
Buy an auto much easier to drive. I have a 2005
Almost identical apart from grill taillights and a few minor other bits.
The front diffs only give trouble if you do a retrieval in reverse.
Mine has 80k and goes really well with a chip and a 3" exhaust.
Had a a Pootrol before and the difference is remarkable.
Towing a 2.8 tonne van I get 6kpl at 100kph.
No other problems so far.
Had Yokohama H/T'S on it and didnt get much mileage out of them 2 of them only did 30,000 and have replaced them already other 2 only 2/3 worn.
AnswerID: 333480
Reply By: V64Runner - Monday, Nov 03, 2008 at 22:35
For what its worth, I do know for fact that Landcruiser front diffs are their week point. And before everyone jumps down my throat, let me state that the weak point in the fronr diff is due to the fact that its mounted upside down and therefore the pinion gear is at the top and not the bottom as is the case with the rear diff. When I was working for Toyota in Perth we had a cruiser come in with a broken front diff. Apparantley he had gone to recover a stranded vehicle and had snatched several times in reverse. The end result was the front diff let go and there were lots of missing teeth and broekn bearings inside the diff housing. This wasnt the only time I had seen a cruiser with a broken front diff. If one must do a snatch strap recovery, then dont try doing it in reverse. Apart from that, they are solid vehicles and will give years of trouble free motoring provided they are properly maintained. Hope that helps.
AnswerID: 333504
Reply By: SPRINT-GTO - Monday, Nov 03, 2008 at 22:45
Yeah the auto Turbo Diesel is the only way to go if your considering towing anything for an extended period. Model changes were made in May and September 2005 so your 2006 Cruiser is possibly exactly the same as my October 2005 model.
I dont believe there were any changes to the T/D Cruisers after September 2005 till they released the 200 series this year.
However i am not 100% sure on this and will stand corrected if wrong. Try to get a good low kilometre vehicle and you cant go wrong.
Goodluck.
Gary
AnswerID: 333508
Reply By: Off-track - Monday, Nov 03, 2008 at 23:15
Have a 2004 manual TD LC. Me personally I prefer the manual but the auto is pretty sweet if that's your thing. The engine is a ripper :-)
Standard suspension is sloppy - dives under brakes and a little too much body roll for me. Lower A Arm's subject to cracking on heavy suspension and rough tracks. There is a couple of fixes for it.
Front diffs have been known to break, but not only in reverse. On rocky inclines when excessive wheelspin is met with a sudden stop as the wheel slams to the ground.
Clutch subject to shudder, although not as much as the LC80 and really a non-issue.
Radiator fan subject to hitting radiator in deep water as it is too flexible, can be replaced with stronger item or mesh guard on radiator rear face.
Roof rack mounting holes have been known to leak if bolts inserted and removed. Easy fix with sealant.
This is what I am aware of and fortunately none of that has happened to me. Am about to throw some decent suspension under it to give it a lift and firm it up. Yep there are issues with them as with any car - I havent come across one without faults.
Depending on what you use yours for I would even consider keeping the 80 TD and overhauling it as they are a really good rig - last and best of the real 4WD's in my opinion (coils/rigid axles/powerful and economical engine/nil electronics/very reliable/strong chassis).
AnswerID: 333522
Follow Up By: Member - Corio - Tuesday, Nov 04, 2008 at 14:01
Off Track,
Can you keep us posted on your suspension mods.Have an 04 auto I,d like to firm up.Like an idea as to what you do as have had several different opinions from after market experts.
FollowupID: 601408
Follow Up By: Off-track - Tuesday, Nov 04, 2008 at 23:17
Basically after a fair bit of research I am fitting the Ridepro/Billstein/Diff drop from ATS in Geelong (now Assassin Offroad I think). I bought the kit a while ago and havent got around to fitting it yet...but will do before xmas.
I wanted a setup that isnt too harsh when unloaded and by all accounts this will provide for that. We'll see. I also had Billsteins fitted to a previous 4WD and personally rate them very highly which is another reason for opting for this kit.
FollowupID: 601484
Follow Up By: Member - Corio - Wednesday, Nov 05, 2008 at 00:44
Off Track,
Thanks for your reply.Will look into it.
FollowupID: 601498
Reply By: chisel - Tuesday, Nov 04, 2008 at 00:01
I have a 2006 TD auto. Great to drive - thoroughly recommend the 5-speed auto. Not sure on faults yet apart from those already listed.
The 80k service is a BIG one. Try to avoid buying, like I did, a vehicle nearly due for that service ...
AnswerID: 333528
Follow Up By: Member - Graham H (QLD) - Tuesday, Nov 04, 2008 at 19:54
You will be happy to know that every 20,000 check costs about the same.
My 80,000 was $912.
FollowupID: 601437
Reply By: Richard W (NSW) - Tuesday, Nov 04, 2008 at 05:53
Pretty happy with my 2005 100TD Auto.
It's had a hard life both outback touring and some fairly serious 4WD tracks. Had more issues than I would have expected but them's the breaks. Motor and gearbox are a sweet match.
The only other common problems to the front diff that I have seen reported is a weakness in the lower control arms and a problem with the Toyota winch bar. There was a recall on some.
AnswerID: 333535
Reply By: Member - neville G (QLD) - Tuesday, Nov 04, 2008 at 06:37
Hi wowza,
I have a post sept 05 turbo/diesel/auto with almost 100000 on it. about 60k of that has been towing our three ton Phoenix over all sorts of roads and to date there have been no problems at all, the rig is great. I have always driven manual but will not go that way again, the auto is great in all conditions and with this box you can select what gear you want and lock it in, really good to drive.
Cheers, Nev.
AnswerID: 333538
Follow Up By: DEANO WA - Tuesday, Nov 04, 2008 at 11:26
Hey Nev, i currently own a 03 auto Patrol (3l td) and are looking to upgrade to 03-05 100 series. i tow a 2 ton boat and have serious issues with the auto box continually "hunting" gears esspecially when you engage cruise control. sometimes it will attempt to drop back into 2nd while already doing 100kmh and i have to quickly disengege cruise before the engine explodes. if i understand your reply you can 'lock' in a gear therefore not allowing the auto to hunt gears ?? and does this apply in cruise control
Regards Deano
FollowupID: 601390
Follow Up By: SPRINT-GTO - Tuesday, Nov 04, 2008 at 17:27
DEANO
In aT/D cruiser it is advised by Toyota to tow in 4th gear rather than 5th which is essentially an overdrive. So effectively you lock it in 4th gear and this prevents"hunting". However some prefer to tow in 5th gear but this is their personal choice.
FollowupID: 601424
Follow Up By: Member - neville G (QLD) - Tuesday, Nov 04, 2008 at 17:45
Hi Deano,
Yes you can lock in all the lower gears but can only use cruise on fourth and fifth. I tow in fifth when on relatively flat terain but move to fourth when the country is undulating. You are able to move from fifth down to fourth without upsetting the cruise control but if third is required the cruise will drop out. Haven,t worn anything out yet but have taken onboard the comments of others e.g. sprint etc.
Cheers for now, Nev.
FollowupID: 601428
Follow Up By: Member - JohnR (Vic) - Tuesday, Nov 04, 2008 at 18:47
Actually a lot of the hunting in 5th gear is actually dropping back from the torque converter lockup to unlocked, and it does that before dropping back to 4th. You can buy a switch to give you a torque converter lockup in every gear if you thought you could use it. I would like to be able to tow in 4th locked up.
FollowupID: 601429
Reply By: MEMBER - Darian (SA) - Tuesday, Nov 04, 2008 at 09:18
As well as here, you can learn heaps in your research at http://www.lcool.org/forum/
Bought my manual GXL 05 with 40k on the clock - very happy overall - about to move from a camper to a van - auto would have been handy for that purpose but this one had so much'fruit' on it that I went with it anyway. As you will see at LCool, the manuals have a very ordinary clutch action - minor shudder is your constant friend when swapping cogs, but on the other hand, engine braking on a diesel manual is very attractive when towing heavy vans through steep country.
AnswerID: 333566
Follow Up By: Member - Graham H (QLD) - Tuesday, Nov 04, 2008 at 20:01
Engine braking can also be acieved in an auto by manually selecting the gear you want and leaving it there when descending.
Old truckies adage Use the same gear downhill as you did uphill.
The comfort level over a Patrol is another plus as well Rides more like a car than a truck.
Have just bought a pair of EFS progressive springs for the rear of mine Hope to fit them this week.
Will see if it makes much of a difference in the ride.
I bought them as we are setting off around the block after Xmas towing a big van.
FollowupID: 601439
