12v light in caravan
Submitted: Tuesday, Nov 04, 2008 at 19:18
Member - Julie P (VIC)
We have recently purchased a 2000 Coromal van - love it a lot - there seems to be provision for using the internal lights and the external light on 12v - i.e. when connected to car - but nothing happens when we try it - are we missing something or could it be there is a wire missing in the connector plug? We bought it privately and the guy we got it from didn't even know what the "black light switch" was for - and the manual supplied is no help either.
Hope someone can enlighten us.
thanks - jules
Reply By: Boobook2 - Tuesday, Nov 04, 2008 at 19:27
I am sure there is a master switch somewhere. Does the van have a battery?
333641
Reply By: Member - Doug T (NT) - Tuesday, Nov 04, 2008 at 19:35
Julie
I reackon the problem would be in the wiring , 2 scenarios , 1 the socket on the car has no 12 volt live from the battery, 2 it's there but wired wrong , get a 12 v tester and check all the terminals in the car socket , turn all lights off on the car before the test, if the car does have a 12v live at the socket it should light up the tester , make a note of the pin number and change the caravan plug to suit, or vice versa.
Trailer Plug guide
333644
Reply By: Supercalafreakinawesome- Tuesday, Nov 04, 2008 at 19:54
I've used the diagrams in the link that Doug T supplied and re wired car & caravan without problems.
Also in my van (bought it second hand) it has a battery in the boot and located near the battery is a couple of switches (similar to white household light switches) and I can isolate the 12 volt lights from there. There is also a number of 12volt fuses in a fuse box. If you can find any or all of these things it may be worth checking if all is ok.
333648
Follow Up By: Dunaruna - Tuesday, Nov 04, 2008 at 20:03
I posted my '240v light switch' comment before realising that you had already referenced it, sorry.
601441
Reply By: Dunaruna - Tuesday, Nov 04, 2008 at 19:59
Most caravans do not have reverse lights therfore pin 2 becomes an aux but it is lightwieght, much better to get a 12 pin plug or add an anderson plug alongside a 7 pin.
Julie, is there a 240v light switch inside the front boot of the van?
333650
Reply By: Keith_A (Qld) - Tuesday, Nov 04, 2008 at 22:56
Hi Julie - we owned a Coromal, and they are brilliant vans.
(You are right about the manual.)
I do not remember any master 12V switch in the van.
Sounds likely the 12V supply from the car is missing.
They do have a fuse bank - worth checking for a blown fuse.
One simple thing you can do - plug in the 240V lead, and try the lights. They fit a transformer in the Coromals -(Usually a Zig X70
http://www.zig-electronics.co.uk/products.htm) so it provides 12V when connected to 240 (in a Cvan
park - or at home). If they work when plugged into 240V, you know it is the car supply. If they do not, then you need to look for a fuse or switch. nb - our fuse box was next to the Zig, under one of the seats.
There are always small teething problems when you buy a van, but you have a great unit there.
If you intend
camping in National parks etc away from 240V, it is fairly simple to get a deep cycle battery fitted, connected to the car by an Anderson plug, to keep it charged...............Keith
333689
Reply By: Dunco (NSW) - Tuesday, Nov 04, 2008 at 23:07
I'm with boobook2 on this...Please check to see if the Van has a battery as I have seen other people with similar setups...but NO BATTERY so you cannot use the 12v system.
I haven't really seen anyway that uses their vehicles battery for their van lighting...a bit dangerous me thinks...fall asleep with something left on and flat battery in the morning !!!
333690
Follow Up By: ross - Wednesday, Nov 05, 2008 at 00:30
I had a 23 ft
York caravan years ago and it was wired through the plug to run 12volt lights off the car battery.
I think a lot of the older vans were wired like that once.
601494
Follow Up By: Member - Julie P (VIC) - Thursday, Nov 06, 2008 at 17:19
G'day - thanks for all the advice - we have a dual battery system in the car - was thinking maybe to have it transferred to the van - anyway we'll think on that - will get "the boss" to check out some of the advice and see what eventuates.
jules
601725
