cant find previous thread on faulty leaking gasfuse
Submitted: Tuesday, Nov 04, 2008 at 21:29
ThreadID: 63244 Views:2564 Replies:4 FollowUps:6
recently there was some discussion on here about a faulty gasfuse leaking and the pros and cons with them. I am trying to find the thread so I can help my folks out with a problem they have with theirs. Can anyone assist by directing me to this thread which from memory i would have read sometime from september this year on. thanks..
Reply By: Member - John (Vic) - Tuesday, Nov 04, 2008 at 21:37
Is it This One?
Or This One??
From further back??
AnswerID: 333670
Follow Up By: PradOz - Tuesday, Nov 04, 2008 at 22:30
Thanks John for the reply. I found them too but unfortunately its not them. Maybe I am thinking of the wrong forum but was sure it was on here???
I thought someone had posted some info on their gasfuse they bought for their caravan being faulty and leaking and someone (manufacturer??) telling them it wasnt designed for use on caravans etc. I was interested in re-reading a couple of the replies as I cannot recall the specific details. Thanks anyway...
FollowupID: 601469
Follow Up By: Member - John (Vic) - Tuesday, Nov 04, 2008 at 22:37
Ok no worries mate.
They were all that came up on a search based om "Gasfuse" and go back to 2005.
FollowupID: 601472
Follow Up By: Member - John (Vic) - Tuesday, Nov 04, 2008 at 22:40
Actually having said that I just tried "Gas Fuse" with the inverted comma's and it came up with a few more hits that may be worth looking at??
FollowupID: 601474
Follow Up By: PradOz - Wednesday, Nov 05, 2008 at 00:15
Thanks again John - still no luck finding what i previously had read though - must have been somewhere else?? thanks for the help
FollowupID: 601491
Follow Up By: Geoff43 - Wednesday, Nov 05, 2008 at 21:42
Pradoz
I put some info on forum thread for you,re- couple of links.
Geoff43.
FollowupID: 601602
Reply By: Geoff43 - Wednesday, Nov 05, 2008 at 08:11
Pradoz
Here is a search tool for caravaners forum, just type in gas fuse.
http://www.cbchs.org.au/caravaners_search.html
Geoff43.
AnswerID: 333714
Reply By: Geoff43 - Wednesday, Nov 05, 2008 at 10:23
Pradoz
Check this one out.
http://groups.msn.com/Caravanersforum/caravanmods.msnw?action=get_message&mview=0&ID_Message=133273&ID_CLast=134522&CDir=1
Geoff43.
How do I make these links live??
AnswerID: 333729
Follow Up By: PradOz - Thursday, Nov 06, 2008 at 11:13
Thanks Geoff for the replies - that helped.
To make the "link live" try this:
Click on the INSERT LINK button down below the PREVIEW and SUBMIT buttons. A separate window will open up called: insert hyperlink - internet explorer.
Then copy and paste the web address (from the address bar on the actual web page you want to link into your reply) into the top line for URL Address in that separate window, but make sure you delete the http:// bit first.
Then just type a name you want to give it in the line below for DESCRIPTION and then click Insert.
To check you have done it correctly, click the PREVIEW button first and you should see your inserted link, and can even click it to see if it opens before you Submit your reply.
Thanks for your help
FollowupID: 601676
Reply By: Geoff43 - Thursday, Nov 06, 2008 at 16:05
Pradoz
Thanks that looks easy enough, glad to help.
Geoff.
AnswerID: 333912
