Camping saucepans
Submitted: Wednesday, Nov 05, 2008 at 18:58
ThreadID: 63264 Views:7619 Replies:8 FollowUps:10
Recently someone posted a request for advice on camping saucepans. (I can't find the thread.) Someone else answered that Tefal has a new range of kitchen saucepans that pack inside each other, but have a clip on handle. I thought that was a good idea, so I went down to Myers for a bo peep. Interesting product. Too expensive and flash for my idea of camping, but. You can buy the handle on its own. It's a pretty neat and solid device with an easy secure locking and unlocking action, unlike other camping lock on handles I have seen. I wandered around Myers handle in hand and tried it on quite a few saucepans. And it worked a treat. The handle sounds expensive but when you see how it is built and operates, not too bad. I reckon one of those handles (a bit under $40) and a set of solid old saucepans (handles removed) and one of my long term camping hassles is fixed.
Reply By: Member - Phil G (SA) - Wednesday, Nov 05, 2008 at 19:05
Handle sounds like a Trangia Handle. I did what you suggested a few years ago, and took the handles off some stainless steel saucepans, but have to admit to rarely using them - I went back to using billies because we like to cook on the fire.
AnswerID: 333794
Reply By: Member - Mfewster(SA) - Wednesday, Nov 05, 2008 at 19:13
No, I have had a Trangia handle and this is nothing like it. This is a big, comfortable, heatproof handle that locks onto the pot without the user having to squeeze handles together. Once you press the lock button, it stays locked to the pot. Those little Trangias were hot to use and really only useful for small pots. The Tefal thing gives you enough leverage for serious size cooking pots.
AnswerID: 333795
Reply By: Member - Crazy Dog (QLD) - Wednesday, Nov 05, 2008 at 21:20
Look here - I think this is what you are talking about...
http://www.kitchendiscounts.com.au/homeware/tefal-ingenio-stainless-steel-3-piece-set.html
Image Could Not Be Found
Grrr!!!
AnswerID: 333825
Follow Up By: Member - Mfewster(SA) - Wednesday, Nov 05, 2008 at 21:24
That's the little beauty!!
FollowupID: 601597
Reply By: Member - Mfewster(SA) - Wednesday, Nov 05, 2008 at 21:30
Crazy D (and other interested parties) I just checked the website you gave. That is $10.00 cheaper than my local Tefal shop. I wouldn't want the pans, but the handle is a thing of joy.
AnswerID: 333830
Reply By: ExplorOz - David & Michelle - Wednesday, Nov 05, 2008 at 22:56
Yes the Tefal handle is ingenious - and your idea to use it for camping is sound indeed! The Tefal handle is similar in concept to what my mum used to have with her old Corningware casserole pots - to carry them from stove to oven etc then unclip. I haven't (yet) got one but my neighbour does and I checked it out - from memory however was there a bit too much of a plastic handle for use near a fire?
MM
AnswerID: 333851
Follow Up By: Member - Mfewster(SA) - Thursday, Nov 06, 2008 at 07:14
Not sure about the fire resistance of the handle, however I don't think it would be a problem. The handle wouldn't sit over the flames. The thing clamps so quickly you would only need to have it very briefly over the flames while you placed or removed the pot. It wouldn't be attached to the pot while it was cooking.
I wouldn't (normally) have flames leaping up around a pot. If coals were very hot you might need a glove on your pot handle hand, but I can't see that the handle itself would have a problem.
FollowupID: 601644
Reply By: Member - Warfer (VIC) - Thursday, Nov 06, 2008 at 00:24
Hiya
Coleman hav (not sure if there recently released,hav not seen them before now) Well built and sturdy and non stick,i am impressed with quality...I just bought mine from Ananconda on sale for $60...I pulled the box apart to show you...
Two Pots and a Saucepan...The frypan and small pot hav removable handle,just one is supplied
AnswerID: 333865
Reply By: Peter 2 - Thursday, Nov 06, 2008 at 06:12
I was always under the impression that you should never use non stick cookware on the fire, if it gets too hot you will have teflon infused food.
all it takes is someone to put another stick under an unattended pot while your back is turned for a moment.
AnswerID: 333869
Follow Up By: Member No 1- Thursday, Nov 06, 2008 at 07:34
I'm not under that impression, to me its a no no
FollowupID: 601648
Reply By: Member - Mfewster(SA) - Thursday, Nov 06, 2008 at 07:19
No idea about the "teflon getting too hot" point, however I do prefer heavier gauge saucepans for cooking. They distribute heat much better and avoid burning on hot spots. The thin ones (and Trangia) seem to me to be designed for back packing where every ounce is an issue.
AnswerID: 333871
Follow Up By: Member - Mfewster(SA) - Thursday, Nov 06, 2008 at 07:21
Sorry Warfer, I should have added a thanks for going to all that trouble with your post. I haven't seen the Coleman kit but will also check one out.
FollowupID: 601646
Follow Up By: Member No 1- Thursday, Nov 06, 2008 at 07:37
Mfewster,
hit the "Post Follow Up" button instead of "Post Reply" button when replying to someone comment in a post
FollowupID: 601649
Follow Up By: Member - Mfewster(SA) - Thursday, Nov 06, 2008 at 07:44
Ta M1. I have a habit of doing that.
FollowupID: 601652
Follow Up By: Member - Warfer (VIC) - Thursday, Nov 06, 2008 at 19:59
Hiya Mfewster
No worries Buddy,The Teflon debate has been going on for years...
Who trusts the French (they eat snails for crying out loud lol)
To me the Gear seems of heavy duty..I have a hotplate that stands over the fire,The Saucepans in general will be used on the gas cookers or beside a fire on coals where its not raging hot...
From abc.net
Should I throw out my non-stick fry pan?
When it comes to the non-stick products themselves though, DuPont says there is no risk to consumers. PFOA, says the company, is used the in the manufacturing process but is driven out during that process. There is no PFOA left in the non-stick surface in the final product.
The EPA agrees. 'At the present time, EPA does not believe there is any reason for consumers to stop using any consumer or industrial related products that contain PFOA', says the EPA's website.
Nevertheless, non-stick fry pans can release toxins. At high temperatures Teflon is known to give off a cocktail of 15 types of toxic particles and gases, including trifluoroacetic acid (TFA) and phosgene. These chemicals are known to be poisonous to birds. And in humans they case headaches, chills, backache, and fever - a condition known as 'Teflon flu'.
DuPont admits this, but it says in humans the condition is reversible, and in any case it only occurs at high temperatures, not during normal cooking use.
This too is the accepted wisdom amongst consumer groups; in Australia, for example, in a November 2004 'road test' of non-stick frypans, the Australian Consumers' Association said:
'It's true that chemicals such as trifluoroacetic acid (TFA) can be given off by some coatings at extremely high temperatures. But it's unlikely to happen during normal cooking…Research hasn't indicated harmful long-term effects of TFA on people. At this stage there's no evidence that non-stick cooking poses a safety risk.'
About 80 per cent of non-stick kitchen utensils on sale in Australia use Teflon - the rest are made by other chemical companies using a similar process that involves PFOA. There are no Teflon manufacturing plants in Australia.
And, according to the Australian Government's industrial chemicals regulator, NICNAS:
'Based on information currently available, there is no risk to the health of consumers using non-stick cookware under normal cooking conditions.'
But the Environmental Working Group (EWG), an independent US non-profit consumer group, disputes this. It says that Teflon begins to deteriorate after the temperature of cookware reaches about 260°C (500°F), and begins to significantly decompose above 350°C (660°F). Cooking fats, oils and butter will begin to scorch and smoke at about 200°C (392°F), and meat is usually fried between 200-230°C (400-450°F), but hot spots in the pan can easily exceed this temperature.
Off-gassing can occur when a Teflon pan is left unattended. A Teflon pan can reach 383°C (721°F) in just five minutes heated on a conventional, electric stovetop, says the EWG.
Consumers to decide?
It's important to note that no Teflon product has been recalled in the US, Australia or anywhere else. As far as the regulating bodies are concerned, they're safe - as long as you don't let them overheat.
But the finding that a chemical in the production process has been identified as causing cancer, acknowledged by the company - together with the company's 'difficulties' with the EPA in the past - is likely to have an effect.
The problem for companies like DuPont is, consumers are increasingly punishing products in the marketplace that are seen to have a question mark over their safety, despite company assurances they're safe, even if they were once consumer staples. Think cigarettes, fast food, and sugar-enhanced breakfast cereals.
Here's our tip: expect to see rows of non-stick frypans in discount stores going cheap; and poached eggs - cooked in conventional stainless steel frypans - making a comeback.
FollowupID: 601756
Follow Up By: Member - Mfewster(SA) - Thursday, Nov 06, 2008 at 20:38
I am happy to use teflon both at home and camping. It reduces the amount of water needed to do the washing up enormously. The quailty of non stick coatings seems to vary hugely. Some of ours have barely lasted, some seem bulletproof. My favourite frypan however isn't teflon but has built up its own non stick patina.
I suspect that the clamp handle I wrote about that started this thread would not be good thing for teflon coatings, not on the top edge anyway.
FollowupID: 601765
Follow Up By: Member - Warfer (VIC) - Thursday, Nov 06, 2008 at 21:33
Hiya
I strongly suggest when you get a chance and before you buy anything else to look at the Coleman Set....~(8--)
Goodluck
FollowupID: 601779
Follow Up By: Member - Mfewster(SA) - Thursday, Nov 06, 2008 at 21:53
Yes. I haven't seen a set yet but I'll do this before buying anything. Thanks for the info.
FollowupID: 601787
