Fan Belt's replacement LC100 Petrol
Submitted: Thursday, Nov 06, 2008 at 15:26
ThreadID: 63285 Views:1936 Replies:1 FollowUps:1
Hi Guys,
Time to replace the fan belts on the LC. Are there any traps, or is it all plain sailing. Has the bottom bash plate have to be removed?
JD
Reply By: toyocrusa - Friday, Nov 07, 2008 at 06:44
Hi.It is a time consuming job and you do have to remove the bash plate. Other than that it's just head down and bum up. Bob.
AnswerID: 334000
Follow Up By: Treading Lightly - Friday, Nov 07, 2008 at 13:38
Hi Bob,
Thanks for reply. All done and all good. However, on removing the bash plate I was astonished to see that the hose from the Auto Trans to the oil cooler was rubbing (occasionally) on the crank pulley. A lot of rubber has been removed from the hose.
Another job to be done (asap)
JD
FollowupID: 601845
