Generator Power Feedback
Submitted: Thursday, Nov 06, 2008 at 22:29
ThreadID: 63295 Views:5984 Replies:10 FollowUps:7
Ok, so we go to Bathurst just about every year and we hire a 6 berth Winnebago/Motor home. What is the best generator to buy that will run the roof mounted heater, toaster, kettle computer, hair-dryer, fridge, lights and TV but not all at the same time. The hair-dryer would be run by itself. The lights, fridge and maybe the heater could all be on at the same time. The toaster would also be run by itself or maybe with the kettle.
Would a 3kva be enough? I don't want something so loud we can't even hear the cars, I was looking at the Honda 30 or the Yamaha, I really want something quiet.
Any thoughts would be greatly appreciated.
Thanks in advance
Reply By: balko - Thursday, Nov 06, 2008 at 22:49
If your only using once or twice a year try to hire one if not i saw in bunnings 4kva for $1400 or a 8kva for$2200 and they both had a robin engine. You wont kill those motors i use one on a machine at work it go,s all day in the heat great little engine Cheers Tony PS ..... i own a 2kva honda for the van its a great unit the the wife can even start it but there not cheap
AnswerID: 333985
Follow Up By: WA Camper - Thursday, Nov 06, 2008 at 23:14
What is the noise level like on the 4 & 8 kva generators please?
FollowupID: 601805
Follow Up By: RV Powerstream P/L - Friday, Nov 07, 2008 at 18:21
Those units are hard to beat but they are open framed units and are not Inverter Units and may be a little too noisy although I doubt they would drown out a good V8 sound.
Ian
FollowupID: 601870
Reply By: Dunco (NSW) - Thursday, Nov 06, 2008 at 22:51
I will be buying a 2kva Honda....from what I have seen it do, it will be quite ample. And fits in far more places than the 3kva model !!
AnswerID: 333986
Follow Up By: Member - Keith C (NSW) - Friday, Nov 07, 2008 at 08:39
Gday Dunco,be careful,a 2kva genny wont run a jug and a toaster at the same time,both draw more than1000w.We have a 20i Honda and it works well,runs the air con in our van and is quiet and economical.
regards Keith C
FollowupID: 601821
Reply By: WA Camper - Thursday, Nov 06, 2008 at 23:11
Excellent guys thanks for the help, it's amazing what these people in the shops will try to sell you. I have seen a 3kva at Supercheap Auto for about $379 on special, a bloke at Bathurst had one and he said it did the trick so maybe I look at that as well. I will google the others.
AnswerID: 333989
Follow Up By: Member - Corio - Thursday, Nov 06, 2008 at 23:55
WA camper,
I have one of those cheaper generators which is ok but they are very noisy.So much so that I dont use it.
Suggest Yamaha EF 2400.Cost around $1800.00.
FollowupID: 601812
Follow Up By: ross - Saturday, Nov 08, 2008 at 19:37
x2 The yamahas are the Roll Royce of gennys.
Easy starting,low noise and they sip the fuel
FollowupID: 602023
Follow Up By: Zukscooter - Saturday, Nov 08, 2008 at 20:43
Pay the extra get an Ashton Martin (honda)
Bob.
FollowupID: 602041
Reply By: disco driver - Friday, Nov 07, 2008 at 01:25
Hi WA Camper,
Just had a thought FWIW.
Rather than having to buy a Genset for the Winnebago unit that you hire, can you hire a Winnebago that has a Genset included in the hire package. This would solve your problems.
Of course if you are using the Bathurst trip as an 'excuse/reason' to buy a Genset anyway, just ignore my comments and take note of the other posters here in regard to your best options.
Disco.
AnswerID: 333997
Reply By: Tenpounder - Friday, Nov 07, 2008 at 08:51
Hi there. As well as power rating, noise and price, the experts say you must consider the 'quality' of the power output: see the article flagged in this post, plus many of the threards on this site. A cheap gennie can have power fluctuating widely, and stuff up your equipment with the greatest of ease. That's why lots of people pay the huge extra cost of a Honda or Yamaha (I paid around $1200 for a Yamaha EF1000iS earlier this year) compared to a cheapie at around $100 for the same nominal rating. A standard electric jug is rated at 2200W - 2400W, so this alone suggests a 3kW gennie. Heating is the killer (overhead heater, toaster, kettle, hair dryer). That's why lots of modern motorhomes have diesel powered heaters built in. A kettle on the gas stove is often used for the same reason.
They seem to say you should not expect any gennie to run for long at 100% of its nominal rating - better at say 75% or less. Hope this helps.
Chris
AnswerID: 334008
Reply By: Maîneÿ (wa) - Friday, Nov 07, 2008 at 09:32
Have you asked the Winnebago supplier for their recommendation ?
Why not hire the first one to make sure you get the correct capacity ??
Mainey . . .
AnswerID: 334017
Reply By: WA Camper - Friday, Nov 07, 2008 at 16:42
Than for all the replys guys. Firstly we did try to hire a generator woth the motorhome but the bob we went through doesn't do that. Also we actually travel the coast for a week or so going to Bathurst and the parks there have mains power. We still have to pay for the generator for the whole time we are away instead of just the 4 days of Bathurst and for the cost we may as well but one.
I was looking at the Honda 30is and and suggested by one of you I may as well just buy one like that, hell if the power goes out here again which it does on occasions at least we can run the fridge and freezer.
AnswerID: 334085
Follow Up By: RV Powerstream P/L - Friday, Nov 07, 2008 at 18:15
Of the 3000Inverter units I believe the Yamaha is the quietest but there is really nothing between the Honda Yamaha and the Subaru.
The 3000I Yamaha and the RG3200iS Subaru are both Inverters are excellent units and can come with Wireless remote control.
Currently I run a Subaru 3200iS on LPGas .
Ian
FollowupID: 601869
Reply By: RV Powerstream P/L - Friday, Nov 07, 2008 at 18:19
BTW
I just watched a Winnebago advert on TV where they are giving away a Cummins generator with so many new Winnie purchases.
Cummins now have 1700I 3200iS and 4300iS Inverter generators and they are all rebadged Subaru and the add showed the 1700I Inverter generator.
Ian
AnswerID: 334104
Reply By: Steve - Friday, Nov 07, 2008 at 21:03
I have one of those cheapo Bunnings GMC jobs. Had it for about 3/4 years now. Don't use it a lot but have never had a problem with it. I changed the spark plug for a decent one and took advice from guys on here not to leave fuel in it between trips and it has been great for our needs. Then again, we have over 220 watts of solar and some good batteries. If I was dependent on a gennie I'd go with the Honda 2.0 kv. One thing I would take issue with, is that the GMC is noisy. Having made a poiint of snooping around camps doing "gennie noise research" (yeah, I know ;-) I'm a saddo) it isn't any noisier than other gennies that I've been around.
AnswerID: 334131
Reply By: WA Camper - Saturday, Nov 08, 2008 at 11:17
Excellent guys, thanks again, Iwill go and have a look at the Bunnings ones and the Cummings.
AnswerID: 334202
