Oziexplorer CE Problem
Submitted: Friday, Nov 07, 2008 at 12:21
ThreadID: 63312 Views:3066 Replies:3 FollowUps:5
I have a registered copy OziExplorer CE Version 2 installed on my IPAQ PDA. When it gets to the end of a map in moving map mode and tries to load the next one a bar appears at the top with :
"Creating Map Index"
Then it pops up an error box:
"No Map Search Files"
I have checked the path to the maps in configuration, have deleted and reinstalled the software but still get the same error.
I can load maps manually.
Any ideas?
Pete
Reply By: Peter McG (Member, Melbourne) - Friday, Nov 07, 2008 at 12:47
Try the latest version - 2.19 I think.
AnswerID: 334053
Follow Up By: Pete Jackman (SA) - Friday, Nov 14, 2008 at 14:08
Thanks,
I had 2.19 on there. Ended up uninstalling and deleting all Ozi files for a clean install and it is fixed now.
Pete
FollowupID: 602917
Reply By: Squizzy - Friday, Nov 07, 2008 at 13:37
Pete,
Make sure the path is correct for the map data and map image.
Geoff.
AnswerID: 334063
Follow Up By: Pete Jackman (SA) - Friday, Nov 14, 2008 at 14:10
The path was correct, thanks for your help
Pete
FollowupID: 602918
Reply By: Member - Rob S (NSW) - Friday, Nov 07, 2008 at 17:16
Hi as the other guys said update to the latest version. 2.20d
And check the map file path .http://www.oziexplorer.com/
I have Hema 4wd maps Australia
Select config/map data folder.
click on the little blue box/select sd card/ select maps.
select maps austraila 250k.
and so on for different map selections for every 6 map file paths.
Rob.
I only ever made one mistake
and that's when I thought I was wrong!
AnswerID: 334092
Follow Up By: Member - Rob S (NSW) - Friday, Nov 07, 2008 at 18:42
Please note you allready have to have loaded version 2.19
as 2.20d is only a patch zip file update.
FollowupID: 601874
Follow Up By: The Explorer - Friday, Nov 07, 2008 at 22:18
Hello
Its actually not a "patch" in the true sence of the word. It is a standalone *.exe file that has no effect on the older OziExplorerCe.exe file. You simply unzip it and dump it in the Ozi folder on your PDA/win CE device. You then have to either change your shortcut to start the new exe file, rename it to match the older exe file name or start it manually. If you keep the older file you can always go back if you encounter issues. You have to downlowd the new screen designer as well or download the "extra files" to get full use of new dev version. See the CE dev page.
FollowupID: 601911
Follow Up By: Pete Jackman (SA) - Friday, Nov 14, 2008 at 14:17
Thanks chaps,
I fixed it by wiping my PDA and reinstalling from scratch.
The development version isnow up to 2.22d
Pete
FollowupID: 602920
