Little Bulldog Trailer Instructions
Submitted: Saturday, Nov 08, 2008 at 17:43
Leonardus
Just joined ExplorOz and was wondering if anyone had any instructions for the Little Bulldog Trailer.
I originally tried buying a new trailer but for whatever reason the manufacturer has stopped making them.
I managed to buy a second hand trailer but it didn't come with any instructions on how to fold it up and open it up again.
Can anyone help me with Operating Instructions?
Many Thanks
Reply By: Member - AJB (VIC) - Saturday, Nov 08, 2008 at 19:40
I've got a little bulldog over in the shed. Cant remember if they came with instructions but they are dead easy to 'erect'. Just spread the
wheels a little, hinge open the draw bar, slide in the extension and winch, bolt on the cross member and away you go. You can then attach the guards and lights if needed and total set up used to take me about 5 minutes. I haven't used it for about 6-7 years and no longer need it. Should sell it.
334257
Follow Up By: Leonardus - Saturday, Nov 08, 2008 at 21:36
Thanks for the info AJB.
The trailer came "erected" and although it should be quite easy to "de-erect" it, I didn't want to strain anything, so am trying to work thru how to "compact" the trailer at the moment.
The rose joints were "frozen" so have fitted new ones, and have "fitted" the tinnie to it (am going to try out the new tinnie tomorrow) just working through how to "shrink" the unit.
I am also looking for a bracket to fit the folded up trailer to the caravan.
Again, many thanks for your info.
Kind Regards
602058
Reply By: Supercalafreakinawesome- Saturday, Nov 08, 2008 at 22:36
Hi Leonardus,
I'll see if I can help by explaning
- undo the two nuts and remove tail light and number plate
bracket
- pull the two pins out that hold the cross bar to the top of the upright square tubes
- and lay the upright square tubes down into the U shaped holders and put the pins back in to hold them. (these square tubes stop the wheel frames from folding back when in use)
- undo the two nuts that hold the cross bar and remove cross bar
- undo two of the draw bar bolts and slide the front half of the draw bar (& winch post) out.
- fold the wheel/frames back towards the back roller until they fit neatly against the frame
After reading this I think I have even confused myself , I hope you have better luck.
Image Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
334289
Follow Up By: Leonardus - Sunday, Nov 09, 2008 at 14:29
Hey Thanks Super????????!!!!!,
it worked, and yes when I first read your instructions I thought "what the!!".
It was dead easy and it made sense.
Kind Regards
602120
