how to fit coaxial cable to plug GME TX3440
Submitted: Sunday, Nov 09, 2008 at 10:29
Con_Qld
Hello..Am having difficulties trying to work out how to fit the antennae coaxial cable to the plug that screws into the back of the radio.
The coaxial cable has multi strand wire in the middle and around the outside some sort of flex wires.
Am not sure how to secure the cable to the plug. Do I just cut the outside cable and peel back the flex wires and screw the cable into the plug?
Would appreciate any help. Am in
Southport....Many thanks...
Reply By: Wheatbelt Wayne - Sunday, Nov 09, 2008 at 10:49
Scroll down on this page for instructions and a diagram
UHF Plug fitting instructions
Hope that helps
334331
Reply By: Member - Mark G (NSW) - Sunday, Nov 09, 2008 at 10:52
con_qld
cut the coax so you have a clean cut end, strip the outer cable about 1 inch from the end.then you should have the fine wires exposed,these are called the shield.fold them back or snip them off( if these come in contact with the main wire they wiil short your radio out) then solder your middle copper cable up inside your end that screws to your radio
334332
Follow Up By: bigred70 - Sunday, Nov 09, 2008 at 11:31
I take it from that explanation that the shield does not have to be (and cannot) be connected at either the radio or antenna end.
My cable has disconnected from the antenna end - is it just a matter of re-soldering the main wire to the antenna, making sure the shield is out of the way and not connected in any way?
Thanks.
602100
Follow Up By: Member - Mark G (NSW) - Sunday, Nov 09, 2008 at 11:42
big frd 70
thats right mate......the sheild has no part in transmit or recieve
it will short out and bleep your set if you try to transmit if it is touching the main wire,cheers.
602103
Follow Up By: MickeyJ - Sunday, Nov 09, 2008 at 12:02
The shield does need to be connected at bothe ends. Just not connected to the center conductor.
A good picture
The shield needs to be connected at both ends, it may work with out it, as both ends may be grounded, but with a ground independent antenna, you will most likely have problems.
Mickey
602109
Follow Up By: Member - Glenn D (NSW) - Sunday, Nov 09, 2008 at 18:54
Why go to the trouble of using coax if you dont connect the shield properly.
Glenn.
602143
Reply By: ExplorOz - David & Michelle - Sunday, Nov 09, 2008 at 12:21
Have a look at the detailed image in the
UHF Radio article right here on ExplorOz.
DM
334343
Reply By: rredbeak - Sunday, Nov 09, 2008 at 14:30
if youre not comfy in doing fine solderring or if youre unsure then you can buy direct from Dick Smith or Tandy ready made coax with antenna plug one end and radio plug the other,in various lengths... HTH Rod
334356
Reply By: Member - Davoe (Yalgoo) - Sunday, Nov 09, 2008 at 16:59
dont forget it only takes 1 stray wire to seriosly reduce the ability of your radio
334372
Reply By: CraigB - Sunday, Nov 09, 2008 at 17:18
Hi Con,
Once you've got it up & running lets us know what you think of the unit and its performance.
Which antenna are you installing?
I am looking at purchasing one within the next couple of weeks.
CraigB
334374
Reply By: Con_Qld - Sunday, Nov 09, 2008 at 22:58
Hi all,
Thank you very much for the advices. The unit is now installed with the GME AE4705 1.2mtr antenna and using the bonus pack handheld 3 watt, I tested it in the surburbs and could communicate up to 1 km although with some static as expected.
Am happy with the unit although it took me 2 whole days just figuring out how to installed it. It was a learning experience.
Thanks again all.
334434
