1985 HJ60 Landcruiser
Submitted: Sunday, Nov 09, 2008 at 10:56
Member - Robert M (QLD)
Good Morning Everyone
My son recently ran up the back of someone all be it at about 10kph. As you can imagine no damage to him given the vehicle (A bit to the other though). My question is that the HJ60 has all of a sudden started popping out of 2nd & 3rd gear occassionally. This vehicle has never done it before. Can anyone shed some light? Could this be caused from the accident? And what could I do about it?
Morto
Reply By: lancie49 - Sunday, Nov 09, 2008 at 13:17
Morto,
I have no idea of the set up on those things, but could it be a bent selector rod not allowing things to fully engage ?
Maybe the sharp impact, combined with old weakened engine/gearbox mpounts may have let everything move about a bit.
Lance
334347
Follow Up By: Member - Robert M (QLD) - Sunday, Nov 09, 2008 at 20:24
Thanks Lancie
Will report back what it was when i get to it later this week
Morto
602155
Reply By: westozal - Sunday, Nov 09, 2008 at 13:53
Hello,
That model have a plastic/nylon bush at the bottom of the gear shifter which can wear possibly causing this problem.
To get it out undo around the base of the gear shift ,then get 2 screwdrivers to push down and twist the collar around the base of gear shift . It should then come out easily.
A fairly easy thing to check first up.
Regards Alan.
334351
Follow Up By: furph - Sunday, Nov 09, 2008 at 15:45
Completely agree with Alan.
The '85 / 75 series trayback I had did exactly the same thing (without a collision though!)
You will find that bush will be in a hundred pieces, it apparently was one of the most used Toyota spare parts.
furph
602125
Follow Up By: Member - Robert M (QLD) - Sunday, Nov 09, 2008 at 20:25
Hi Alan
Will get to it on Wednesday and check this out. I hope that is all it is.
Morto
602156
Follow Up By: Member - Robert M (QLD) - Wednesday, Nov 19, 2008 at 21:18
Hi Westozal
You were dead right. A quick fix. Just lucky it wasn't more serious.
Thanks again
Morto
603820
Follow Up By: westozal - Thursday, Nov 20, 2008 at 18:20
Gidday Morto,
Glad that part was cheap for you....now about my consultancy fee...
AL.
603937
