AnswerID: 26761 Submitted: Monday, Aug 04, 2003 at 15:11
Martyn (WA)
replied:
Rowdy,
I have some silica gel in a small plastic container with load of holes in it that I keep in areas of high condensation, when the little gel balls go pink I put the container in the sunlight for the day until they go blue again, give the container a bit of a shake during the day to move them all around, works a treat for me and I can't say I've had condensation problems.
Be careful with insulation, the condensation will form behind the insulation, the insulation will absorb the water and over time cause corrosion and you won't know about it, it's commonly known as CUI in the petrochemical game (corrosion under insulation).
Hope this helps, own opinions as usual.Keep the shiny side up
Reply 5 of 5
