Black wolf turbo owners.. question?
Submitted: Sunday, Nov 09, 2008 at 20:34
Ron173
G'Day all,
had the new 300 turbo out this weekend, was pretty windy sat night, flapped a bit here n there, but stood up to it fine.
What do most people do if it gets real bad with the fly?
take it off, leave as is, or do you tie the front flap down?
I just left
mine as its meant to be seemed ok, but not sure if it got real bad, think I'd feel better with it secured down.
Interested to hear what the majority do with this one.
Rgds
Ron
Ps Mrs wants an add on so we can
cook without having seperate tarp up, is the add on room any good?
Reply By: Member - cuffs (SA) - Sunday, Nov 09, 2008 at 22:13
I have seen a bloke pop up his Blackwolf & it blew away, forgot to peg 4 corners first.
I have springs that I attach to all guide ropes including front flap.
I have been in strong winds
the springs take the movement pressure on the fly.
If you remove the fly you can not tie down your tent and it wil collapse in strong winds, hence the ropes attached to the fly.
The instructions even suggest the use of springs.
334424
Reply By: Member - Kingsley N (SA) - Monday, Nov 10, 2008 at 09:34
Ron,
We have been caught in a windstorm with our 240. I lowered the verandah as much as the poles would allow and added a couple of extra guy ropes and pegs to the poles. That is about all you can do. I think the design could be improved by having a storm flap that could be zipped down instead of having that verandah. Another improvement would be to have a vent at the apex to allow moisture out. Condensation is a problem on cold nights and it is difficult to manage when the only cross flow available is to go out of the tent and partly roll up the window flaps.
The extension that you mention might alleviate the verandah problem, but the whole thing looks a bit unweildy.
Having observed a number of fellow campers I now believe that the OzTent is a better proposition than the Turbo Tent provided you can carry it on the vehicle.
Kingo
334464
Follow Up By: Ron173 - Monday, Nov 10, 2008 at 10:46
thanks.
we looked at oztent but roof rack essential, which we didnt have,and werent wanting to purchase.
I normally use a caravan for the longer duration trips, the wolf is really only for one nighters.
Ron
602238
Reply By: RobAck - Monday, Nov 10, 2008 at 18:49
Yep it can be a pain but you can do without the fly unless it is blowing a gale. Using springs on the guy ropes is mandatory to allow some flex there but yes the awning does fog around a touch. We have an extension pole with a big plaxtic X that folds flat or extends out to support the awning area nicely. If you have a look at this link
http://www.polarisinnovations.com/assoc.htm you will see what I am talking about
RobA
334531
