weight restriction for GQ
Submitted: Monday, Nov 10, 2008 at 17:12
ThreadID: 63403 Views:1964 Replies:4 FollowUps:1
I have a LWB GQ patrol. Anyone know the weight restriction for the roof?
I am getting an aftermarket flexible fuel bladder made which will hold 100 litres. Obviously I won't fill it that much if I am putting it on the roof rack but being flexible material I can put 30, 50 litres etc and roll the rest up to save space.
If I put it in the car then I can completely fill it. It's for the Canning trip I am planning.
Thanks,
Reply By: mechpete - Monday, Nov 10, 2008 at 17:45
don,t know the legal limits but in 2005 myself and 6 other blokes
3 dirt bikes and one other 4wd did a trip down the CSR i carried 140 lts, 3 swags , and a 2nd spare wheel , 2 bike tyres on the roof , yes it was heavy but if you take it carefully you won,t have trouble .
mechpete
AnswerID: 334517
Reply By: Topcat (WA) - Monday, Nov 10, 2008 at 23:29
I would not advise putting that much weight on the roof of a vehicle, especially doing the CSR. It is better placing heavy items as low as possible to keep the centre of gravity low & keep the vehicle more stable. A roof rack should only be used to carry light items. Cheers.
AnswerID: 334579
Reply By: Member - Vince M (NSW) - Tuesday, Nov 11, 2008 at 09:45
I would not fit a bladder type tank to any vehicles roof & even if it is baffled the surge will be real bad. If its a blister welded type it will only split in the seams sooner than later so make shore it is/has internal hinges on edges as this will help its life,they are tough but can chaff easily & normally tear in the hold down points,(eyelets, D-rings etc) I have imported/made & probably sold more than most & have used & sold since Mid 70's manly in fuel cells I use them in my Boat but never in my 4wd
regards Vince
AnswerID: 334600
Reply By: Mick15 - Tuesday, Nov 11, 2008 at 19:21
from memory its about 200kg, but would be dependent on the type of roof rack mounting (full length rails)
As others have said it'd be better to mount it low.
A mate has a grey poly tank under his ute - a lot more heavy than a caravan tank, and we measured it up, should fit in the cargo area of a gq - its 110mm high, and holds 80 litres, all you'd have to do is make a false floor, then just get a space case for the roof rack and stick all the light suff (clothes etc) in it.
Thats my plan anyway.
AnswerID: 334706
Follow Up By: Gossy - Wednesday, Nov 12, 2008 at 09:18
I already have a false floor that I put trunks on. As I need the extra fuel because of the Canning distances I might have to rearrange the way I pack a bit to make it all fit.
I am talking to this mob at the moment about flexible tanks. Fantastic idea so just getting some quotes at the moment. what I really like about them is that I can have a bladder made to what ever size I want and when it is empty I simply roll it up and free up the space in the car. Brilliant!
www.liquidcontainment.com.au
FollowupID: 602599
