ISUZU D-Max vs Holden Colorado
Submitted: Monday, Nov 10, 2008 at 20:11
ThreadID: 63407 Views:19425 Replies:4 FollowUps:5
HI All,
Just read a story about the D-Max. The new 4x2 and 4x4 Isuzu D-Max are now in showrooms. It has the same mechanicals as the Holden Colorado Isuzu UTE Australia (IUA) is selling the vehicles through 40 outlets. None of the Isuzu dealers are current Holden dealers due to the potential conflict of interest. IUA will market the D-MAX at a price that is claimed to be about $5000 cheaper than Colorado but mechanically identical. Peak power is 120kW at 3600rpm, with maximum torque of 360Nm occurring between 1800 and 2800rpm for the manual transmission variants or 333Nm from 1600 to 3200rpm for the automatic variants (3rd generation 3 litre Common Rail Turbo). Fuel consumption for the range (in accordance with ADR81/01 combined-cycle testing) ranges from 7.9 to 9.0L/100km. A LS Crew Cab diesel 4x2 has just done a test run from Broken Hill to Gatton on 1 tank of juice (1448km).
Anyone thinking of buying a Colorado may wish to check out the D-Max as well.
I have no association with Isuzu – just thought Forumites may be interested in this info..
GPM
Reply By: Isuzumu - Monday, Nov 10, 2008 at 20:40
Hi Saharaman, I've been keeping up with all the news about the D-Max. The Colorado and D-Max are both built in Thailand, like all the other utes but the D-Max is built in another factory to the Colorado. From what I can make out Holden is to lose the Colorado built by Isuzu and may end up with some thing from the States.
So yes it is going to be interesting to see how well they sell, I for one being a mad Isuzu fan will be looking at one in a few years, that is if I can wear out my MU hahahaha.
Cheers Bruce
AnswerID: 334546
Reply By: mike w (WA) - Monday, Nov 10, 2008 at 20:41
GPM.
Have had a bit of a look at both myself (not interested in buying, more out of interest), however a very good friend of mine who has too much time on his hands has eluded to similar to what you have stated. According to him and my ability to recolaect our conversations, the Colorado and D-max ARE the same vehicle, however it is just the left overs from some contractual arrangements between GM and Isuzu. Holden will be releasing their own utility in the coming years, apparently rumour has it, utilising a renault based engine ;). Also, I am informed that Isuzu will be releasing in the next few years a 4wd wagon, similar to the Jackaroo refered to OS as a Wizard 7??
In perth Isuzu is being sold through either AHG or DVG, not sure on the other half of the country.
Interesting times ahead.
AnswerID: 334547
Follow Up By: Isuzumu - Monday, Nov 10, 2008 at 21:22
This is the original Wizard a 1996 model with the 3.1TD, which we own, the next was the same as the Frontera, but with the 4JX1 motor (probably Isuzu only big let down).
Image Could Not Be Found
FollowupID: 602334
Reply By: autosparky - Monday, Nov 10, 2008 at 20:44
i think the rodeo and colorado are the same but for a few cosmetics. ie roo bars not the same because of light shape and depth of grille. ddiesel motor same as the last of the rodeos. until new model .
AnswerID: 334549
Reply By: Member - Tony B (QLD) - Monday, Nov 10, 2008 at 20:55
Fuel Consumption is a joke. You will get 10ltr per 100k at the best I would suggest. Cheers Tony
AnswerID: 334553
Follow Up By: MP - Monday, Nov 10, 2008 at 21:13
Tend to agree. Test was done in 4x2. Now with a strong south westerly, 60psi in the tyres and doing 70km/h in top gear I still can't see how you can get 5.2l /100km - isn't that Prius territory.
MP
FollowupID: 602330
Follow Up By: Wherehegon - Monday, Nov 10, 2008 at 21:15
Cousin has current model diesel rodeo and gets in the low 8's. I use to get 10/11's around town in my old 2.8D hilux, so under would be quit easy on the latest diesel motors in the 4 cylinder range eg prado's,hilux's are getting in the 8's. WHG
FollowupID: 602331
Follow Up By: Wherehegon - Monday, Nov 10, 2008 at 21:19
Hi there MP, must agree with you on that, cannot see them getting 5.2 ??? But 8's to 10's definately even in a 4x4. Towing,headwinds,weight, ect then obviously would climb a bit. My reply above to Tony was also based on no towing etc but in 4x4 range of rodeo. WHG
FollowupID: 602333
Follow Up By: MP - Monday, Nov 10, 2008 at 21:27
Hi WHG,
I've got a 2003 RA and used to get 10l/100km around town towing a trailer week in week out. Just went from Bridgestone 693's to 694's and now out to 10.4l/100km. best I got once was 8.4 on a weekend around the Barossa. Worst 15l/100kms towing a 1500kg pop top van at 100km/h.
Mark
FollowupID: 602339
