Building a Camper Trailer
Submitted: Tuesday, Nov 11, 2008 at 14:50
Bruce n Sal
Hey People,
I am going to a mates for dinner tonight and he is going to get a quote form a friend to weld up a trailer box and drawbar for me, so I can build a camper trailer. Then we will fit
suspension and
wheels etc.
What size does the trailer need to be I have these basic dimensions are they ok???
7 ' x 4' trailer I think they need to be about 500mm deep, and I want an 1800mm long drawer bar for toolbox and spare tyre.
I am told the trailer needs to finish about 1050mm above the ground.
Are these dimensions right.
Thanks.
Reply By: Shaker - Tuesday, Nov 11, 2008 at 15:31
The dimensions are up to you, the tent manufacturer will build the top to suit, if you are going to put a pre-built Chinese top on, Oztrail or similar, then you would need to check the required dimensions with the supplier.
334648
Reply By: Pat (vic) - Tuesday, Nov 11, 2008 at 15:44
hi
I just finished my ct the sides on
mine are 450mm you need to take into account wheel size and
suspension also how much weight it will carry.My finished and fully loaded height is 1030mm. now i cant wait to take it out.
have fun making it;)
Pat
334653
Follow Up By: Bruce n Sal - Tuesday, Nov 11, 2008 at 15:52
Sounds good. Looking forward to getting it built and using it.
602446
Follow Up By: Topcat (WA) - Tuesday, Nov 11, 2008 at 15:53
Make sure that the axle width is the same as the towing vehicle. It makes it so much easier towing off-road if the
wheels are tracking together.
602447
Follow Up By: Bruce n Sal - Tuesday, Nov 11, 2008 at 16:02
Great Tip Thanks.
Will make sure to measure the car when I get it and make sure the trailer will match.
Bruce
602450
Follow Up By: Topcat (WA) - Tuesday, Nov 11, 2008 at 16:40
Another tip is to have the trailer
wheels compatable to the towing vehicle. That way your vehicle spare wheel can be used on the trailer.
602461
Reply By: ross - Wednesday, Nov 12, 2008 at 01:17
I would check the dimensions with the local authorities.
Last time I registered my 6x4 John Papas trailer they were particuarly careful measuring it in regards to the drawbar(which was factory stock)
334790
Reply By: Member - Glenn D (NSW) - Wednesday, Nov 12, 2008 at 10:50
Hows it going ,
Just got through doing the same thing , I got a trailer made ( 99% sure it 7 x 4 ) useing the same
wheels and ride hieght as the Patrol
.Image Could Not Be Found
I got a chinese tent off ebay , Xtrail , and am really happy with it .
they just come in a standard size , my one fits exactly lengthwise and hangs over a little at the edges , because I used patrol
wheels the gaurds had to be a little wider but this is a good thing cause it makes them wider than the tent .
All the dimentions /requirements of the tents are on their ebay ad.
I mounted the tent permanently to the trailer ( no tilt ) and have full length sliding draws out the back .
Also have 12v power and a
water tank.
Good luck .
Glenn.
334828
Follow Up By: Bruce n Sal - Thursday, Nov 13, 2008 at 11:15
Hi Glenn,
That trailer looks great. Can you tell me where you got it from. Di you add the
water tank etc after it was built.?
Bruce
602736
Follow Up By: Member - Glenn D (NSW) - Thursday, Nov 13, 2008 at 12:43
Southern Cross trailers at Penrith,
Yeah just bolted all the pieces together . Took a bit longer than I thought , but took my time to do things properly
Glenn.
602745
Reply By: Nomadic Navara - Thursday, Nov 13, 2008 at 17:27
Before you get too far down the track, get hold of this book and study it thoroughly.
Site Link
335060
