radiator for 80 Series Landcruiser
Submitted: Tuesday, Nov 11, 2008 at 21:04
ThreadID: 63444 Views:6333 Replies:3 FollowUps:1
I am replacing my leaking radiator in my 1990 80 Series Landcruiser with 3F petrol engine and manual gearbox and I am getting mixed responses from suppliers. All the radiators are built for the auto transmission so some suppliers are saying the radiator brackets are different and so the radiator wont fit.
What I would like to know if this is really the case? I will ring a natrad store when I get a chance, but thought that with all the wise ones on this site, someone would be able to tell me and ease my tired mind.
Reply By: Member - Rob S (NSW) - Tuesday, Nov 11, 2008 at 22:31
Hi Glenn
I found that they mainly stock auto radiators as well for my fze 4500 eng as well. saves having to carry two in stock. and no difference in the mounting holes.
I can't tell you if there is any difference between the 3f auto or manual.
If your 90 model is simialar to a 95 allow a few hours to change it as there is a fair bit of stuff to move to get at the top bolts.
I fitted an adrad radiator and have found it ok, try them as well.
http://www.adrad.com.au/home.htm
Rob.
I only ever made one mistake
and that's when I thought I was wrong!
AnswerID: 334770
Follow Up By: Glenn (VIC) - Tuesday, Nov 11, 2008 at 22:48
Hi Rob
I will take the truck down to one of the suppliers to check.
I will also look at your link. One thing though, once the shroud is unbolted
and the hoses removed, it is only 6 bolts and the radiator is out, 20
minutes max! My mechanic showed me and I showed a radiator specialist
who was amazed that he had been doing it the hard way for so long.
The manuals all say the long way hahahaha
FollowupID: 602551
Reply By: Member - DOZER- Wednesday, Nov 12, 2008 at 13:39
There are two things different...the cowl pickup points that bolt the cowl to the top tank, and the water return that a 1fzfe has...any diesel radiator will fit the 3f, if you want to make up some adapters to hold the cowl onto it...Natrad were selling rads for $375 using your rad side mounts. They came top and bottom tank plus core.
AnswerID: 334853
Reply By: Member - DOZER- Wednesday, Nov 12, 2008 at 13:44
Ive heard of people removing the centre support up front to get into the two top bolts....whats your secret way?? Undo the sides??
AnswerID: 334855
