Clutch or Gearbox Issue?
Submitted: Wednesday, Nov 12, 2008 at 10:12
ThreadID: 63454 Views:2337 Replies:5 FollowUps:0
Gday - I have a really annoying problem with my 03 TD Hilux - its a constant ticking noise coming from the front end.
Whenever i put the clutch in even a little bit the noise goes away, it will then return once my foot is taken off the clutch again.
So in short - clutch out = constant ticking noise / clutch in = noise stops.
Now ive had some advice that it is probably the thrust bearing, ive done some research and this seems to be an inherent problem in Hilux - so ive priced it up and a new clutch kit is gonna cost me $850 fitted.
I'm now having a few people saying that it might be the Input Shaft Bearing in the gearbox...
Can anyone offer some opinions re this as obviously i dont want to replace the clutch and have the problem still exist.
Is it more likely a clutch issue or a gearbox issue????
Any help would be great.
Reply By: Member - DAZA (QLD) - Wednesday, Nov 12, 2008 at 12:30
Have you tried coasting down hill, with the Clutch out, and the
Gear Box in neutral, to determin if it is a Gear Box issue?.
Daza
AnswerID: 334842
Reply By: donks1 - Wednesday, Nov 12, 2008 at 12:41
hi there
it will be the clutch release bearing
very common. just live with it unless you're due for a clutch aswell
Donks
AnswerID: 334845
Reply By: Ron173 - Wednesday, Nov 12, 2008 at 13:33
I'm with Donks on that one.
Clutch release bearing, common as, in lots of vehicles, in fact most vehicles will do it to a small but noticeable amount if you listen for it.
live with it till you need a clutch, which in an 03 vehicle should be a while yet unless someone been drivin it who holds on clutch instead of handbrake... HATE WOMEN WHO DO THAT!!!!
AnswerID: 334852
Reply By: mechpete - Wednesday, Nov 12, 2008 at 22:13
an imput shaft bearing will give you a noticable bearing wine in each gear until you get into 4th ,then the drive is straight through one to one and it is normally much quieter .
mechpete
AnswerID: 334915
Reply By: Hilux03 - Thursday, Nov 13, 2008 at 20:05
Cheers for that - ive priced up a new clutch kit and can get one fitted for $750 - this noise is annoying me that much im willing to pay this to get rid of it...
I take it a new clutch / kit will get rid of it?
What are the odds of it coming back in the near future if i do install a new kit?
AnswerID: 335084
