2004 Patrol 3 Litre Intercooler Fan
Submitted: Wednesday, Nov 12, 2008 at 15:40
GregF
Howdy All ; Could anyone offer any good info regarding fitting of a Thermo Fan onto the top of the Intercooler of my 2004 GU 3 Litre Patrol. I would like to wire it into the ignition with a relay, and run it full time. Mounting and wireing info much Appreciated / Thankyou
Reply By: Member - RobnJane(VIC) - Wednesday, Nov 12, 2008 at 16:07
Hi Greg,
Not necessarily the answer, but maybe a a thought to ponder.
Depending on what you want to achieve, the fan may or may not do much for you. I think at low road speeds you might get a beneficial effect by forcing additional air over the intercooler, however at higher road speeds the restriction caused by the bulk of the fan in the path of incoming (road speed) forced air could
well negate any benificial effect or even cause a restriction over the standard set-up.
As noted just a thought, it'll be interesting to see what others suggest.
Rgds,
Rob.
334876
Follow Up By: Gunna Do - Thursday, Nov 13, 2008 at 07:41
Rob,
I am no expert on the matter, but it was bought to my attention that at highway speed with a bullbar fitted there is very little air flow through the bonnet scoop, due to the bullbar disrupting the flow over the bonnet. Just something to keep in mind. Once anything is fitted to the front of a vehicle, the air flow is anything but what it was in the factory under test conditions.
At least with the fan fitted you have no doubt that air is being forcecd through the cooller.
Gunna Do
602721
Reply By: Member - Peter B (SA) - Wednesday, Nov 12, 2008 at 16:08
Hi Greg try the patrol
forum http://www.patrol4x4.com/forum/ and search for intercooler fans
334877
Follow Up By: Member - Roachie (SA) - Thursday, Nov 13, 2008 at 08:03
Yes, the Patrol
forum will be your best bet. I know a number of the blokes on there have done this mod to their 3 litre but have used a heat-activated switch (50oC I think) to activate the fan. After all, there's no point having the fan running full time if it's not needed.
Roachie
602722
Reply By: stefan & 12 times Dakar winner - Wednesday, Nov 12, 2008 at 16:40
The 2.8 GU has a fan under the intercooler to suck air through. Maybe that is worth looking at. I believe the 3.0 and 2.8 intercooler are the same size or very similar
334879
Reply By: Stevo - Thursday, Nov 13, 2008 at 08:37
Gooday Greg,
the intercoolers on the Patrols are next to useless. Lift up the bonnet and feel the tempmerature of the intercooler body after a run at 100 kph. You'll be very surprised at how hot it is. At lower speeds it acts as a heat sink. I fitted a fan and it is absolutely remarkable how cool the intercooler stays (almost ambient temperature at both highway driving and low speed rock crawling or sand driving)
http://users.bigpond.net.au/conody/Intercooler%20Fan.htm
334955
Follow Up By: pepper2 - Thursday, Nov 13, 2008 at 12:06
does it have any effect on engine performance
602740
