C.B instalations
Submitted: Thursday, Jan 10, 2002 at 01:00
ThreadID: 635 Views:2074 Replies:4 FollowUps:1
can an a.m cb be installed without a s.w.r meter? if so how?
Reply By: Matt - Thursday, Jan 10, 2002 at 01:00
Hi Neil
The answer is yes they can. I put in a Uniden pro 510XL. You dont need to do anything except choose the ariel of your liking and plug it in. No meters needed. Regards Matt
AnswerID: 1723
Reply By: Warwick - Friday, Jan 11, 2002 at 01:00
Neil (and Matt) i have also to just installed the same Uniden model in my truck, i had no problems with the installation, except that when i turn on my A/C i get a little bit of interference, Has anyone else had this problem? and what would be a viable solution for fixing it??
AnswerID: 1725
Follow Up By: Bernard - Friday, Jan 11, 2002 at 01:00
Warwick
You need to install some noise filters on your power source for your CB, very small and cost next to nothing!!
FollowupID: 575
Reply By: Robert - Friday, Jan 11, 2002 at 01:00
Neil,
Apparently if the antenna is not tuned then you run the very real risk of both damaging the radio and affecting the transmitting range.
If you don't want the hassle of getting someone to tune the antenna you can purchase pretuned antenna's that only need's tuning with a SWR meter if you wish to fine tune them and if not checked won't do any damage to the radio or seriously affect the transmitted range. I have one of these pretuned antenna's myself made by MobileOne (available from Dick Smith Electronics), suggest you look at their web site - www.mobileone.com.au or contact them as I did myself, I found them to be very helpful something I didn't find when I tried to get unbiased information from several communication equipment specialist near where I live.
AnswerID: 1727
Reply By: Darryn - Thursday, Jan 17, 2002 at 01:00
To Neil, Matt and Warwick Interferance with 27mhz am radios is a fact of life, ie you probably will never get rid of it all. Best to run antenna coax well away from alternators and a/c compressors and use a length of antenna coax as your power wire straight from the battery. Put the positive to the centre wire and earth to the braid and remove the excess wire fromthe back of the set.
ALL 27mhz antennas need swr checking as installation can affect them esp if you haven't got a good earth on the antenna base.
Regd's Darryn
AnswerID: 1783
