Advise needed re off road trailer
Submitted: Thursday, Nov 13, 2008 at 22:10
ThreadID: 63506 Views:3593 Replies:6 FollowUps:4
hi guys
i'm looking at purchasing an off road style box trailer and saw one 2nd hand. It's got the right gear re the chassis etc but comes with slipper springs.
I'm just wondering how easy it would be to convert to an eye-to-eye style setup?
It is just a matter of welding the swinging shackle housing at the slipper end or is there something more involved than that?
Mate has a metal fabrication business but we have no experience with trailers and/or suspensions etc so any feedback would be greatly appreciated.
Current setup on the trailer is a 6 leaf slipper setup.
Jeelan
Reply By: Wheaters - Thursday, Nov 13, 2008 at 22:31
Hi Jeelan,
I have just purchased a Casuarina Camper from Seaford in Melbourne.
Lochie builds a Great trailer and after lots of research I found value for money you couldn't buy better. He has years of experience and is able to accomadate any needs you may have in "specialising it " to suit your application.
In his offroads he has two options independant leaf or independant coil.
His canvas work is done by Southern Cross who is reconised as one of the oldest and best in Canvas work,
Couldn't be happier,
Cheers John
AnswerID: 335136
Follow Up By: Jeelan - Friday, Nov 14, 2008 at 01:41
hey John
thanks for the response - at this stage, i'm really just looking at box trailers only and even then, most likely 2nd hand to meet my budget.
I've looked around for new trailers and in WA, cant seem to find anything under the $2K mark, and that's just a starting price. Eastern states trailers are competitive but at around $1K for transport to WA makes them a No Deal for me.
Jeelan
FollowupID: 602860
Reply By: Member - Barnesy - Friday, Nov 14, 2008 at 00:56
I haven't done this myself but common sense would say it would be as simple as welding a shackle onto the trailer chassis and putting springs in it.
A possible consequence of changing the springs means the axle may move (probably back if the springs are longer). This may affect handling and require a different weight distribution when loading the trailer. This could be fixed however by welding both shackles, rather than just the slipper end, to accommodate longer springs.
But apart from that personally I can't see any problems.
Barnesy
AnswerID: 335152
Follow Up By: Jeelan - Friday, Nov 14, 2008 at 01:43
thanks Barnsey
as well as changing to Eye-to-eye style springs, i was also thinking about getting some longer springs so this may work out advantageously.
i'll hv a look into a bit more. I also found a website for Martins Trailers Parts so i might give them a call tomorrow to see what they suggest and their thoughts.
Jeelan
FollowupID: 602861
Reply By: Willem - Friday, Nov 14, 2008 at 08:07
Jeelan
I tow an Offroad Trailer.
I went to Melbourne to look for these trailers as that city is the capital of things to tow. Could not find one under $3000. Eventually came back to Adelaide and bought a Modern Offroad Trailer for under $2000. It is very strong and has done 45000km so far without any issue with some of the journeys being cross country travelling. I had to do a springover as the spring setting was too low and the tyres rubbed on the guards.
Buying a trailer with slipper springs may not be such a good idea as the trailer might not be built to Offroad standards. If you do go down that road then you might have to look at strengthening the box, if needed.
Changing the slipper springs to eye to eye shouldn't be a problem but get a professional welder to do the job, unless ofcourse, you are one.
AnswerID: 335166
Reply By: Moose - Friday, Nov 14, 2008 at 14:21
G'day Jeelan
Assuming the chassis is strong enough to be a real offroad unit then yes - all you need do is weld in the new bit. I had this done to a box trailer yonks ago. Used LandCruiser springs in place of the slipper springs the trailer came with. Still going strong some 20+ years later. The ride with the bigger springs has been and remains excellent. Never had any issues. Can carry a heap of weight too. Those short springs most trailers come with are useless in my opinion.
Cheers from the Moose
AnswerID: 335214
Reply By: Jeelan - Friday, Nov 14, 2008 at 16:29
MOOSE and WILLEM
thanks for your responses - much appreciated.
Another question - do you use your trailers with a soft cover on it?
i'm considering getting a hard lid fabricated. It would be hinged on one side with gas struts. I'd put roof rack mounting points on the lid.
ideally the lid would hv removeable hinges so if i needed to use the trailer as an open trailer, this could be done easily enough.
what are your thoughts? does the soft cover (like a tonneu cover with loops) seal dust from the trailer fairly effectively?
as noted above, a mate is a fabricator so to do the lid would only be material cost.
Jeelan
AnswerID: 335239
Follow Up By: dionbremner - Friday, Nov 14, 2008 at 18:54
Hello there, I'm in the process of restoring a trailer lid for our camper trailer. Have a look here for a little clip of it that might give you some ideas. They come up on ebay fairly regularly and at good prices. Another option is this.
Cheers and good luck
Dion
FollowupID: 602960
Follow Up By: Willem - Sunday, Nov 16, 2008 at 17:40
Jeelan
I have a soft cover specially designed and fabricated(my welding and unholsterers canopy). Have been caught in the rian a few times and now make sure we stay dry. Canopy has awnings on all four sides. It works well for our application. Trailer has followed me over extreme country without a problem.
Image Could Not Be Found
FollowupID: 603242
Reply By: offroad Bob - Friday, Nov 14, 2008 at 21:04
I built an off road trailer 15years ago using landcruiser springs. Works great and a softer ride for the trailer. I towed it across the Gunbarrel including the abandon section without a problem. I saw many abandoned slipper spring trailers out there. One of the cars with us was towing with slipper springs and didn't last 150k on the track before smashing his springs. When fitting your springs just make sure the centre pin of the springs is about 25mm to the rear of the centre of the trailer, that was advice from a trailer manufacturer. Cutting off old spring mounts and putting new ones on is straight forward and doesn't worry the trailer. I have done it a few times.
AnswerID: 335288
