AM - FM Reception Antenna Feedback - Review
Submitted: Friday, Nov 14, 2008 at 18:44
ThreadID: 63525 Views:2890 Replies:3 FollowUps:3
There has been a few posts on Radio reception and a good antenna for the job. A while back someone posted a link in reply to www.mobileone.com.au. As I had been trying for a while to get a good antenna and gone through 3 others without much change, I thought I would give their M2W 1550MM Broadcast Band Antenna a go. Also brought the mounting kit with the correct coaxil.
Results are great, I pick up FM stations I never could get before and the dead transmission spots I used to get are no longer. So I can recommend this product to anyone having the same issues. PS - Just a review, I have no connection with the business -Cheers Tony
Reply By: a convict - Friday, Nov 14, 2008 at 21:27
Thanks for heads up Tony B.
Just been to their site but can not find "M2W 1550MM" at all.
Did u phone, or am I looking in wrong category?
tks..
AnswerID: 335292
Follow Up By: Tim Owen - Friday, Nov 14, 2008 at 22:26
Try http://www.mobileone.com.au/antennas/default.htm and then click on AM/FM Broadcast Band on left menu.
FollowupID: 602996
Follow Up By: a convict - Friday, Nov 14, 2008 at 22:36
.."Tim Owen" many tks for that, can't see for looking.
FollowupID: 602998
Reply By: Member - Linda M (VIC) - Saturday, Nov 15, 2008 at 09:58
Tony
Where did you mount it on the vehicle? I need one on the bull bar because my slide on camper blocks signal to the one mounted near the top ofwindsreen on the drivers side in the Rodeo.
Linda
AnswerID: 335341
Follow Up By: Member - Tony B (QLD) - Saturday, Nov 15, 2008 at 10:43
Linda. The same was happening with my antenna and camper. I put it on the bull bar at this time. It would be better on a guard but the Rodeo does not make that easy to do. I may change that to behind the cab, on the front of the tray bars and add a spring mount. It is aways better to have a ground plane surrounding your antenna mount. The onlly problem with this is when you are driving through the scrub. Cheers Tony
FollowupID: 603046
Reply By: swampy66 - Tuesday, Nov 18, 2008 at 13:50
Thanx Tony,
this was just the sort of info i was looking for when i posted a question on this forum a few months ago.
Swampy
AnswerID: 335887
