pajero knock sensor
Submitted: Friday, Nov 14, 2008 at 22:00
ThreadID: 63531 Views:2494 Replies:3 FollowUps:2
does the nm 3.5 have a knock sensor ? if so where abouts ? and can it be disabled? cheers
Reply By: Dunaruna - Saturday, Nov 15, 2008 at 09:16
Yes it does, it's under the intake manifold.
Why would you want to disable it, it is a very simple but crucial sensor.
AnswerID: 335335
Follow Up By: zacc - Saturday, Nov 15, 2008 at 10:12
the reason being , i have dual fuel and also a unichip, now when on fuel it pings slightly which in turn retards ths timing . the ecu takes its time on resuming the original timing to original thus when i switch to gas the timing is still retarded. so if i disable it it can not retard the timing on fuel .
FollowupID: 603040
Reply By: Philip A - Saturday, Nov 15, 2008 at 10:41
I think the Unichip tuner needs to retune it and take out a smidgeon of advance.
I do not know the Pajero injection, but I bet if you disable it, the injection will go into retarded limp home mode.
Regards Philip A
AnswerID: 335348
Follow Up By: zacc - Saturday, Nov 15, 2008 at 14:20
i was not going to disable it just relocate it so it does not pick up the pinging . the reason i do not take it back to the tuner is that i live 400 klm away from them , other wise i would
FollowupID: 603067
Reply By: toyocrusa - Saturday, Nov 15, 2008 at 14:44
Hi. Pinking/Preignition/Detonation will all eventually destroy your engine. That's why the knock sensor is fitted.I would get the chip recalibrated no matter how far away they are.Bob
AnswerID: 335374
