Fridges and Batteries
Submitted: Saturday, Nov 15, 2008 at 09:03
Mandrake
Hi all - I am waiting for my new Waeco 50 to arrive and am now wondering how to keep it running - Dual battery systems seem to be the main choice here - I was wondering why a single larger say 150ah battery in the vehicle is not a common option - apart from the obvious flattening battery are there other problems associated with running the fridge from normal car cig lighter socket ?
I probably won't be
bush camping more than overnight anytime so fridge would only be running without charging battery for 10-12 hours overnight and a 150ah battery should keep it running for that amount of time - I think ?
Any not too technical replies would be appreciated ...
Rgds
Steve
Reply By: Sir Kev & Darkie - Saturday, Nov 15, 2008 at 09:29
Steve,
Before I had a dual battery system in my old 4by I used to just use the standard starter battery for overnight stops.
I usually ran the fridge on a lower setting until we pulled up for the night and then changed the fridge to a higher setting. We also limited the number of times we accessed the fridge during the overnight stops as
Cheers Kev
| Russell Coight:
335337
Reply By: Rock Ape - Saturday, Nov 15, 2008 at 09:33
Batterys aren't batterys, you have one engine starting battery high current short time and one deep cycle low current long time.
If you have one battery the chances of running it flat are quite high and it is hard to get a combined deep/starting battery although Optima make one, this also comes at a price as they give quite high starting current but not a long deep cycle life.
Beat to have 2 batterys that are seperated by an isolator, no worries when starting in the morning.
Have a good one
335338
Follow Up By: Member - Mike DID - Sunday, Nov 16, 2008 at 18:24
Standard AGM batteries work very
well for both Starting and Deep Cycle use.
603254
Follow Up By: Rock Ape - Sunday, Nov 16, 2008 at 23:14
Mike
I am sure they do but they are still not a deep cycle battery, my optima is good for 750cca but only hasan output of 65 amp/hr in deep cycle application.
Have a good one
603314
Follow Up By: Member - Mike DID - Sunday, Nov 16, 2008 at 23:20
"has an output of 65 amp/hr in deep cycle application"
- so it does have deep-cycle capability.
603315
Follow Up By: Rock Ape - Monday, Nov 17, 2008 at 07:36
Yep, it is a feature of the Optima batterys and if you have a cool $350 you can buy one, luckly for me
mine were free as they change them out every 2yrs on a piece of critical equipment.
I still have 2 batterys isolated with a manual switch so I don't have to worry about starting
603327
Reply By: Best Off Road - Saturday, Nov 15, 2008 at 10:13
Whilst these days I have solar, generator, and dual battery, a few years back I ran a 39L Fridge from the start battery in a Falcon for four days. About 5 times a day I idled the motor for about 15 minutes.
It was no monster start battery either, about 550 cca.
So I have no doubt what you are planning is totally feasible. Perhaps invest $70 in a little jump start pack as insurance.
Jim.
335342
Reply By: Affordable Batteries & Radiators - Saturday, Nov 15, 2008 at 10:37
I recommend a portable battery pack that can be used for the overnight stops and this can run the fridge and some lighting.
I recommend to leave the starting battery for just that.
Derek.
335345
Reply By: Mandrake - Saturday, Nov 15, 2008 at 11:08
Thanks for all this -
I have been playing around with a small portable unit
3 X 7ah batteries with solar reg and a 10w panel - this unit should run the fridge for 3-4 hours while driving without totally discharging
trouble is the 10w panel is not big enough to recharge the batteries and cope with the fridge !!
I will get a Jumper Unit as a backup - And I have a Ctek XS 3600 charger to charge up overnight on a powered site
Before going on my safari to
Darwin next August/Sept I'll invest in a nice new battery for the Jeep over 100 ah if possible ..
Hopefully that will keep the tinnies cool for a few weeks !!
Steve
335352
Follow Up By: Pete Jackman (SA) - Monday, Nov 17, 2008 at 16:01
I went cheap and put 2 x 35 AH second hand gell cells in a home made box. Total cost $50. This keeps our Waeco CF50, lights and a lap top happy for 2 - 3 days if we leave our panels behind.
You cna get second hand gell cells from the shops that service gofers - the little electric vehicles that run you down on footpaths.
Pete
603385
Reply By: Johnny B Good - Saturday, Nov 15, 2008 at 15:46
i just been to the 4wd adventure show in WA. I have a D40 Navara got no were to but a dual battery system except in the ute so i went for a Thumper it is a portable battery which you can run fridge lights jump start if you get stuck it is wired through to your engine plug it in to charge when your back on the road 2 to 3 days you will get etc
hope that give you more of a idea
335378
Reply By: ross - Sunday, Nov 16, 2008 at 23:33
Steve, I have had a Wacko 50 for about a year now. I can run it off a 100 amp battery for about 3 days,maybe 4 under good conditions.
I can also run it for a few days off one of the batteries in the engine bay.
I have a solenoid which automatically isolates the aux battery so I have one good battery for starting.
For overnight use this might be the best option for you.
The only problems with using cig lighters is the wiring between the fridge and battery may not be in perfect condition .
This causes the fridge to shut down with a red light flashing about every 4 seconds.
The other problem is that the wacko plug falls out or wobbles around .
The best way is wired direct to the battery with wire that can handle up to about 4 amps.
I butchered a wacko plug and soldered eyes that connect to the battery poles.
335618
Reply By: Sea-Dog - Monday, Nov 17, 2008 at 10:49
By having only the one battery... of course you have the obvious of running the main starter flat... but then when a battery is run flat it loses some of its holding power.. so each time it is run flat the battery is that little bit worse off (up to 20% each time)
In the end the cost saving of getting a single 150A/h battery would be eaten up in having to replace the battery more often.
I would be definitely looking for a second battery setup.. preferably the auxhillary set up that will charge when driving as opposed to the battery pack set up.
335658
Reply By: Mandrake - Monday, Nov 17, 2008 at 11:05
OK - all of your experience and knowledge has won me over -
150 ah AGM mounted in the back - wired with "BIG" wire and the
dual battery set up ...
Thanks everyone for input - any donations gratefully accepted !!
See you around OZ
Steve
335661
Follow Up By: Maîneÿ (wa) - Monday, Nov 17, 2008 at 11:58
Steve,
Maybe, 2 x 80ah AGM Deep Cycle batteries will fit in the area better?
Mainey . . .
603360
Reply By: Kiwi100 - Monday, Nov 17, 2008 at 14:54
Can I hop in and pose a similar question?
I've owned a Waeco 50l fridge for three years but never used it, mainly because we're travelling with a caravan with its own fridge and three deep cycle batteries linked to solar panels.
But the caravan fridge has been known to play up, it also needs to be cleared out and defrosted from time to time, and sometimes it would be useful to have the car fridge betwixt
shop and caravan.
So, if I were to carry the Waeco in the truck, plugged into the cig lighter, I take it that it will operate just fine while travelling. I'm guessing also that the standard twin starter batteries in the LC 100 Series TD will not suffer unduly if the Waeco was run overnight (I'm not sure if the socket remains active with the ignition off so this may not be practicable anyway)? Equally, as an emergency (or defrost-time) source of refrigeration, the Waeco could be run indefinitely if plugged into a caravan cig socket.
I take the point that for extended use as the sole source of refrigeration, it makes more sense to fit heavier wiring and to install a (third?) deep cycle battery in the truck and to ensure that there is an appropriate system in place to maintain the health of the battery.
Michael
335698
