trackranger
Submitted: Monday, Nov 17, 2008 at 16:06
Member - Peter T (WA)
has anyone out there brought trackranger and had / having the biggest dramas ever over one little program getting it to run as told it can.will it run with hema maps and bu353 mouse.thanks
Reply By: Racey - Monday, Nov 17, 2008 at 19:24
Hi Peter,
I have Trackranger for about 2 years and I run some Hema maps.
After you install Hema maps you need to upgrade your Trackranger database. Under file menu go to load a map and then select the Hema map you have installed. I'm not familiar with the bu353.
Racey
335747
Reply By: Geoff M (QLD) - Monday, Nov 17, 2008 at 19:56
Hey Peter,
Same as Racey ...... have Hema maps loaded but don't use them too much. (use NATMAP most of the time) Never had any dramas when I do use them though.
Not familiar with bu353 mouse.
I was one of the first to use TrackRanger with Vista and found that their support was fantastic. Try contacting them and see what they've got to say.
Geoff
335753
Reply By: Member - Malcolm C (QLD) - Monday, Nov 17, 2008 at 23:03
Check out my thread from yesterday - had BU-353 USB in the heading.
Malcolm
Still learning the program with UBD and NatMap.
335803
Reply By: Member - Mick O (VIC) - Tuesday, Nov 18, 2008 at 15:56
G'day Peter,
I've been using TrackRanger for the past year and have found it fantastic. It was my first foray into moving map programs so I needed a bit of help getting it set up as
well. It works
well with the Hema maps. On the Hema disc, you have to locate the seperate folder of images (Can't remember the file designation at present as I'm away from my computer)for the trackranger program and load them across into the Trackranger Map folder. Then you "Update" the map index from the file menu.
Don't hesitate to send the guys an email because their service has been second to none and they'll ensure you get it working to your satisfaction.
Cheers and good luck. Don't get frustrated just email advantech.
Mick
335908
Reply By: jskogsta - Thursday, Nov 20, 2008 at 03:28
I've had Trackranger for a while and I've had no problems what so ever... only problem I've had is relating to the laptop that runs it. Keeps crashing and being "too" sensitive to the coorugations etc. Though from a program UI and user interface perspective, I'm more than happy and I'll continue using it. Have had no qualms about the product post me buying it.. though must note that I've not been exposed to any other products like it before so I don't really have any comparisons. ;-)
336150
