GPS
Submitted: Tuesday, Nov 18, 2008 at 00:33
ThreadID: 63614 Views:3081 Replies:3 FollowUps:8
Has anyony got any info on a oyagi-618 GPS i bought one online it is suppose to have the latest navtech software on it, has anyone used one or know what there like, would like to use it going bush but not sure if you can down load extra maps onto it ?
Reply By: Member No 1- Tuesday, Nov 18, 2008 at 07:20
there = over there
their = as in, someones jacket
they're = as in, does anyone know "what they are" like
apologies for the grammar lesson
AnswerID: 335824
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Nov 18, 2008 at 10:20
Grammer!! My Grammer died recently, she was 92 years old!!
Michael.
FollowupID: 603517
Follow Up By: Member No 1- Tuesday, Nov 18, 2008 at 13:55
do you mean your nonna
grammer is what i typed first time round but it came up underlined in red dots so i thought it was wrong...changed letter to "a" (which i thought was wrong) but it accepted it with out underlining it?...so much for Davids spell checker...or is Mozilla that does this?
either way, some one is wrong
FollowupID: 603559
Follow Up By: Hughd - Tuesday, Nov 18, 2008 at 17:19
Grammar is correct- but what has this got to do with a GPS?
FollowupID: 603593
Follow Up By: Member No 1- Tuesday, Nov 18, 2008 at 17:49
would you believe.....i need to make sure what he is talking about before i can post an applicable answer....:))))
FollowupID: 603596
Follow Up By: That Troopy Bloke (SA) - Tuesday, Nov 18, 2008 at 18:05
' their = as in, someones jacket '
Errr,sorry dude...shouldn't that be ' someone's '
People...glass houses...stones :-)
Glenn
FollowupID: 603597
Follow Up By: Member No 1- Wednesday, Nov 19, 2008 at 07:32
you were not supposed to notice that
FollowupID: 603660
Reply By: Peter 2 - Tuesday, Nov 18, 2008 at 07:56
I suspect that it is using win CE core as the OS as many of the cheaper ones do.
You will need to install Oziexplorer on the SD card in the same folder as the existing Nav program. Place the maps that you want to use in the 'map' folder in Ozi.
Then change the nav program that it is looking for in the main menu from Navteq (or whatever the existing turn by turn program is called) to Oziexplorer.
How big is the supplied SD card? I'd suggest getting a 4GB (usually the biggest these devices will handle) as then you will have plenty of room for maps.
AnswerID: 335828
Follow Up By: Shaker - Tuesday, Nov 18, 2008 at 11:07
Isn't Navteq only the map provider?
It will be running navigation software such as Route 66.
FollowupID: 603526
Follow Up By: Peter 2 - Tuesday, Nov 18, 2008 at 11:14
probably ;-))) I'm not thinking too straight at the mo' home with the flu.
FollowupID: 603528
Reply By: Skippy In The GU - Tuesday, Nov 18, 2008 at 18:33
The software for this model could be 2 years old but it doesn't mean it's the latest navtech software that everyone uses. Some companies are selling there latest software with 2008 maps in which were put in last year.
AnswerID: 335939
