Ute canopies
Submitted: Thursday, Nov 20, 2008 at 21:27
ThreadID: 63693 Views:5206 Replies:7 FollowUps:7
Guys,
Need to buy a canopy for a Ranger single cab wellside and since it's for work I dont need anything fancy like a top of the range ARB, so min. cost. Have googled but not many firms do one for this ute.
Flexiglass do one (Cheftain don't) for a bit over two grand. Has anyone had experience with one in terms of water ingress, delaminating or any thing else.
Your advice welcome.
Reply By: ross - Friday, Nov 21, 2008 at 01:23
I looked at buying a Flexiglass canopy. They dont guarantee them to be watertight but installed properly it would be close.
The product seem to be of high quality but wasnt suitable for my alloy tray.
Isnt a Ford Ranger the same as some model Mazda's? I would have thought there would be plenty to choose from
AnswerID: 336296
Follow Up By: wigger - Saturday, Nov 22, 2008 at 00:06
Ross'
Ford are the only one doing a single cab wellside and the numbers obviously aren't sufficient to interest the canopy firms.. Mazda do only a cab chassis in single cabs so the canopies are quite different.
I will have to go back to thier Slack's creek yard and see how they effect the seal between the headboard and their canopy because this could be a problem area.
FollowupID: 604073
Reply By: Best Off Road - Friday, Nov 21, 2008 at 07:03
I've got a Flexiglass, bought it primarily because it was the only place open last January that could do one in a hurry.
It is fine, one water leak where the roof racks bolt through, I just need to loosen the nut and seal with silicone.
As a significant part of our business is fitting drawers to Tradie's Utes, I've seen them all. Water leaks are just as common in the flash brands. It all comes down to how well they are fitted.
One tip, regardless of what brand you buy, make sure you get the lift up side windows to allow access. The sliding windows only half open and are next to useless.
Jim.
AnswerID: 336303
Follow Up By: wigger - Saturday, Nov 22, 2008 at 00:58
JIm, thanks for the info.
I'm undecided about the windows. Others have said to get lift ups but I'm not really using it for camping gear. Unless these windows are fairly large, I can't see how they would make things much easier to retrieve gear but maybe I'm wrong. Just tell me how they've been useful for you and what size you needed.
The sliding ones are pretty pathetic and for the $170 are just a cosmetic thing.
The biggest problem is that the tray is 2320 long and so getting stuff out from the front will drive me nuts. At one stage I thought of just fitting a dual cab caopy (1450mm) with no rear door and this would have given me a rain cover for the front 2/3rds and I could get a skid on the back. Since both canopies are the same price this isn't the way to go.
FollowupID: 604079
Follow Up By: Best Off Road - Saturday, Nov 22, 2008 at 09:42
At 2320 long you'll never be able to get at stuff up the back without crawling in. With the lift up windows at least you can reach in and lift stuff out.
Naturally I've got a set of drawers in my ute which also keeps the lift out stuff at a workable height. eg I can slide my generator in its cardboard box through the window and then stand it up. Bloody lot easier than pushing it in from the tailgate and then clambering in when I go to retrieve it.
Size? Get them as big as they make them, but they are generally pre-fabbed, so you take what you get offered.
Jim.
FollowupID: 604090
Reply By: Member - John F (NSW) - Friday, Nov 21, 2008 at 08:50
Wigger,
I have a Flexiglass on my 06 Hilux. It is the smooth finish one - they also do a stipple finish tradesman style which has a stronger roof for proper racks. Mine is waterproof. It has the sliding windows which are good for the dog. The interior light fell off - it was useless anyway. The hinges are stainless, but their fixing bolts and strut bolts and nuts are mild steel, hence not fit for purpose. It had to be refitted three times as it was fitted too close to the cab and banged on the back of the cab on mildly bumpy suburban roads.
In summary, it's ok, but specify stainless fixings.
BTW the company did not respond to my request for proper bolts and nuts.
Cheers, John.
AnswerID: 336313
Follow Up By: wigger - Saturday, Nov 22, 2008 at 00:36
John,
FG say only available in leathergrain finish.
Dont think the problem you had with cab contact will arise because wellside has a headboard as part of tub structure and they will have to butt up to this.
I intended wiping the bolts with vaseline if were mild steel but are you saying that the contact between stainless and mild produces a galvanic reaction between the two and corrosion is impossible to stop.
FollowupID: 604077
Follow Up By: Member - John F (NSW) - Saturday, Nov 22, 2008 at 16:53
No, just that the nuts/bolts should be either stainless or gal - mild steel is not fit for exterior applications. They can be easily replaced, but should be done right in the first place.
John.
FollowupID: 604129
Reply By: Twinkles - Friday, Nov 21, 2008 at 16:18
I have a TJM canopy. Lift up side windows. Had to have the rear lock/handle replaced twice. It is a pop in/out one. Looks good, flush when locked. It jams when you get in dusty conditions. Latest handled jammed first trip in dusty conditions. Had to buy carby cleaner pressure can to clean it out. This stuff wrecks paint work so have to use a towel around it when cleaning lock. It worked, but what a nuisance! Before told to use this stuff ended up having to hit button on lock with hammer to make it pop out! Canopy seems good, flush locks on side windows look good.
AnswerID: 336346
Follow Up By: wigger - Saturday, Nov 22, 2008 at 01:04
Twinkles,
On the TJM site, they talk about "loadboards" but no one else does so what's it all about.
Tjm stuff may be a bit up market for what I need ans I need to find out if they do a Ranger single cab model.
FollowupID: 604080
Reply By: Axel [ the real one ] - Saturday, Nov 22, 2008 at 10:04
Ive just had a Flexiglass canopy fitted to the Rodeo dual cab with alloy tray ,,Tradesman liftup windows and 2roofrack bars ,, quality of canopy is A1 , fitting was hohum [was necessary to realign canopy at home as was fitted askew to tray enough to make opening/closing tailgate board next to impossible] , Price ?? looked at several different options including all alloy / alloy roof and canvas ect ect ,, spent $3527 allup.
AnswerID: 336420
Follow Up By: wigger - Saturday, Nov 22, 2008 at 12:15
Axel.
Very encouraging that the quality of the canopy per se was good.
After your experience I will make sure that it's aligned properly and opens before leaving their premises.
FollowupID: 604106
Reply By: Twinkles - Saturday, Nov 22, 2008 at 13:47
No idea what a load board is.
AnswerID: 336441
Reply By: Member - Dennis P (Scotland) - Saturday, Nov 22, 2008 at 18:45
I had a Flexiglass canopy fitted to my traytop Patrol and could not fault it.
Found this on their website,
Ranger pic
Dennis
AnswerID: 336471
