Jayco Freedom Question
Submitted: Monday, Nov 24, 2008 at 14:54
ThreadID: 63762 Views:2477 Replies:2 FollowUps:6
Hi All, theres a plastic vent at the side of the van for the fridge (marked electrolux) it has a removable small flap inside is a hole ,looks like a nozzle, anyone know what that is for ?
regards,
Reply By: donk - Monday, Nov 24, 2008 at 15:19
The thing you are liiking at is the outlet for the flue for the cooling system boiler that is heated by either gas or a electric element when you are on 12 or 240 volts
I will find a link for you & post it so you can see for yourself how a 3 way operates
Regards Don
AnswerID: 336709
Follow Up By: donk - Monday, Nov 24, 2008 at 15:23
Here is a link that will explain it
http://www.rv.com.au/frames/hints/Fridge.htm
Regards Don
FollowupID: 604380
Follow Up By: Wizard1 - Monday, Nov 24, 2008 at 15:41
The flue is for the release of the fumes created by the heat transfer to cool the firdge using 240 Volt or gas. When running the fridge on these sources get up close and you'll smell the ammonia fumes and feel the heat.
12V is a maintenance source and won't generally produce as much heat or fumes.
FollowupID: 604382
Follow Up By: Dave Thomson - Monday, Nov 24, 2008 at 17:32
Wizard on the ball again,
thanks mate.............
FollowupID: 604400
Follow Up By: Member No 1- Tuesday, Nov 25, 2008 at 07:23
wizard....where does this ammonia gas that you say you could smell come from?
FollowupID: 604468
Follow Up By: Nomadic Navara - Tuesday, Nov 25, 2008 at 11:15
If you smell some ammonia it means that the cooling system at the back of your fridge has leak and you should attend to it quickly.
FollowupID: 604504
Follow Up By: Member No 1- Tuesday, Nov 25, 2008 at 11:39
what wizard wrote
"When running the fridge on these sources get up close and you'll smell the ammonia fumes and feel the heat."
he makes it sound like you can smell ammonia all the time.... which is course is not right
you may or may not smell ammonia if your fridge develops a leak. Absorption fridges work under a vacuum so the first thing it will do is suck is in air...then depending on where the leak is one may get an ammonia smelling solution or vapour leaking out...if a very small leak you maynot notice anything
FollowupID: 604511
Reply By: Dave Thomson - Monday, Nov 24, 2008 at 15:36
Donk your a star, dont know how you find that out but just goes to show what an amazing site this is,
thank you,
AnswerID: 336711
