Diesel/gas vehicle owners
Submitted: Tuesday, Nov 25, 2008 at 10:36
ThreadID: 63779 Views:20706 Replies:3 FollowUps:17
Since you have had the conversion done/added....has your oil cleaned up and so lasted longer?
Prado owners...since you have had it done has it improved your economy at all?
Thanks in advance...cheers.
Reply By: Alan H - Tuesday, Nov 25, 2008 at 11:05
Hi Redbakk.
I had my Defender done and can see no apparent difference but possibly technical examination would. It certainly looks just as dirty.
I haven't had the Prado done and at this stage don't think I'll bother.
Cheers.
Alan.
AnswerID: 336815
Follow Up By: RV Powerstream P/L - Tuesday, Nov 25, 2008 at 11:59
Yesterday we had Rods Country Camping Gear's F250 7.3Navstar on the dyno at Dungog NSW and with a chip in it it produced 1640.5397 N/M torque at the back wheels.
On diesel gas installed by J&J Diesel Services it produced 2190.3541 N/M torque at the back wheels.
Rod rang on his way back to Wollongong and said it appeared to have a lot more grunt but the test would be when the 28Ft trailer is on and they are running a distance where they can check the economy by setting the cruise control he is not making any comment.
As soon as he does this and rings me I will post his findings no matter what they are as he travels a lot of k,s and it will be a fair dinkum assessment of the system working and benefit potential.
I will also ask him for a report on the oil at the first chance between changes.
I want to install Diesel gas but there appears a lot of negative vibes about the economy and I think that with the improved torque the economy should be there so we will see.
One thing he doesnt need to prove is that his vehicle is more powerful and faster than most cars on the road as he already knows this so if there is economy he should drive to get it.
I hope the results will be helpful.
Ian
FollowupID: 604515
Follow Up By: Flywest - Tuesday, Nov 25, 2008 at 13:15
Ian,
Any chance you could get Rods country campings F250 Dyno Graph and post it to this thread for comparison with a stock f 250 7.3 PSD with and without the Diesle gas switched on or off?
Both the figures you quote - seem to be playing footloose and fancy free with an extra at least 1000 NM of torque over the standard F 250 7.3 with the Dieselgas conversion.
I can't see the addition of a chip adding those sorts of increases...
An example would be Jody Tiptons DP Tuner out of the USA (http://www.dptuner.com) where even with 120 Hp boost - and the diesle gas conversion - those figures would not likely be achieveable (you'd need a Exhaust Upgrade and Air Intake Mods to run the full +120 RWHP tune).
So on mine at 233 Hp I could add another ~120Hp to bring me up to say 353 Hp
As you can see from the above graph a stock F 250, 7.3 PSD only pulls 534Nm @ 2688rpm's & with the Gas switched on pulls 566Nm @ 2750rpm's
Those figures show a 23HP increase, from 210 - 233 Hp...i.e. a 32NM increase.
Most of the after market chips available here only add some 40 or 80 HP tops....so maybe another 100Nm of torque - but certainly not in the 1000 - 2000Nm'sas your figures would tend to suggest.
I'd be real keen to see the actual graph off the dyno for the REAL figures - I've written to Jody Tipton about writing a special 120 HP tune for the F250's on diesel gas.....
If someones producing the torque and HP your suggesting - without subtsantial mods - then I'd really like to see it..
2000 odd Nmeters ~ about 1000 RWHP!
Now - I've followed the US drag guys who compete at tractor pulls using F 250's ad special built trannys etc - to drag sleds in competition and they aren't getting those sorts of numbers yet.
The recent (after '99) F 250's came out with powdered metal con rods - good for about a MAX of 400 RWHP...over that and you risk catastrophic failure, unless you get the forged steel con rods out of the very early 7.3 powerstrokes.
The ONLY 1000RWHP F truck I've seen had a cummins in it with twin turbo's...and it was nudging 1000RWHP
I haven't seen anything like those numbers here in Oz.
Not knocking the idea of adding gas and a chip to the F 250 - its something I've been toying with doing for some time - but the numbers in your post just don't add up is all.
Even if Rod would share his dyno graph with me by PM or email if he doesn't want it public...
You can't post numbers like those, without people who understand them wanting to know a bit more about how this is achieved....it's in the top of world class competition figures... and not achieveable with just a chip add on to a standard F 250...with a bit of gas thrown in.
It's easy enough to make such an error posting when going from memory on numbers, heck I've done as much myself before today!
I'd just have to see them on the graph in ink to believe them and then would need to know about the mods used to achieve them.
All chips do is alter the amount and timing of extra fuel delivery - the Diesel cycle is about 87% efficient, so all the chip (tune) progrmmmer has to work with is the remaining 13% of inefficiency in the diesel cycle..
13% of the stock 534Nm = about an extra 70 or so Nm...
I've yet to see any tunes or chips that produce an extra 1000 or so N/meters. For a start you'd need new special larger HEUI injectors (8of) and they are some $900 a throw...$7200
I'm sure you can understand why the numbers have peeked my interest.
Please tell us more about this truck and the figures etc - sounds interesting.
FollowupID: 604523
Follow Up By: RV Powerstream P/L - Tuesday, Nov 25, 2008 at 21:16
I will post it as soon as I can get it.
I may be wrong as I only got them over the phone and if they are wrong I will apologise with humility as I did not check or query what I was told .
What they actually told me was I think 1100lbs/ft with chip and 1650 lbs/ft ongas at the back wheels.
The horsepower was 255 and they cut it back to 149 and they indicated the original vehicle was around 170 odd.
Now Ill shut up and wait till I either prove it or eat crow either way Im happy to do it.
Ian
FollowupID: 604613
Ian
FollowupID: 604614
Follow Up By: RV Powerstream P/L - Tuesday, Nov 25, 2008 at 21:46
I cant shut up Im an idiot.
Reading all of your post it appears you have engine dyno figures and I quoted Chassis dyno figures.
The sytem installed on Rods F250 I m led to believe is far superior to the system you have installed.
I should get the figures tomorrow.
Ian
FollowupID: 604622
I cant shut up Im an idiot for not looking harder.
Ian
FollowupID: 604623
Follow Up By: RV Powerstream P/L - Tuesday, Nov 25, 2008 at 21:47
Ian
FollowupID: 604625
Follow Up By: Flywest - Wednesday, Nov 26, 2008 at 00:44
Ian - don't sweat it - its not a big deal - mine are dyno figures at the rear wheels.
Yes theres a fair chance your quoting non metric torque figures most likely.
Its just that you had me trying to figure how the heck he gets that much poke is all...
No need to apologise or eat crow, I'm just really interested in how many more Hp I could get with mine with a chip is all, and what sort of chip he has etc,
255HP is quite acheiveable and sounds to be in the right ballpark.
Here's an aside for the guy if he's interested that you might pass on.
I recently found an aftermarket source of bonets to suit F trucks (F 150 &F 250) in fiberglass that has the old 1975 XB falcon scoops moulded in.
They look kinda cool I reckon - might be able to get a 2 for one freight deal maybe if he's interested!
FollowupID: 604633
Follow Up By: RV Powerstream P/L - Wednesday, Nov 26, 2008 at 09:13
Flywest
Evertime I hit submit it came up with a server not available screen so I went back and did it till it came up ok .
I wasnt trying to stress a point.(LOL)
I spoke with the Dyno people this morning and they said they have done F250,s before but nothing that can compare with this one .
Ive asked them for further info and they will try and get it to me today.
The cars look great you posted maybe they will be very cheap very soon but I must admit Im a GM man and maybe they will be cheaper sooner.
Ive got some info in my head about oil but Im going to check it first so i dont put my foot in it again.
It came from a man that is a diesel cam specialist and he cited some interesting information about modern oil problems so when I get it Ill post it for you.
Im running an additive that I import for myself and I recently put some in a mates 4.2L sahara and his engine normally idles at 750 and after 100Ks towing a boat trailer on a trip it was idling at 900 and he had to wind it back to 750.
I also gave him some 2 stroke from the same company and the first day out he used a full tank with his yami using standard oil .
For the rest of the week he used the oil I gave him and every day of roughly the same work load he claimed no smoke whatsoever, no residue of oil in the water and only 3/4 tank used.
Ian
FollowupID: 604645
Follow Up By: Flywest - Wednesday, Nov 26, 2008 at 12:55
I managed, to come up with a few things to put your first lot of posted figures into perspective..
You'll see why the info in it's original form peaked my interest.
This is a competition sled hauling F truck from the USA, owned by Dr Speed, capable of the numbers you originally posted.
[url]http://www.youtube.com/results?search_query=stroked+out&search_type=&aq=f[/url]
This is Dr Speed
DrSpeed works at PACCAR's test facility. If you don't know PACCAR, they are the parent company for Peterbilt, Kenworth, DAF and Bedford.
This is what a 7.3 powerstroke engine capable of those original posted numbers looks like.
That's a p-pumped 7.3 motor. I's slang for a Bosch P7100 gear driven injection motor where the injectors have a preset pop off pressure - and the fuel is pressurized via plungers, ranging from 10, 12, and 13 mm plungers. Timing is gear driven, and advanced with MAP. It can flow as much fuel as you ever want or ever need, and it's simplicity makes it a great pump. It's not a show engine - it's a sled puller.
Source:- [url]http://www.dieselpowermag.com/tech/dodge/0807dp_bosch_p_pump_diesel_fuel_injection/index.html[/url]
[quote]The '94-'98 Cummins 5.9L engine has been the mainstay of diesel power in Dodge trucks, and has a reputation as an excellent performer with the ability to make some serious horsepower. [B] One of this engine's features that makes it so desirable is the Bosch P7100 inline mechanical injection pump. This injection pump, often called a "P-pump," is the Holley Four-barrel carburetor of the diesel world. The P7100 pump has been around forever, is practically bulletproof, and is very tunable for high performance.[/B][/quote]
Quite simply - there is no one in Australia running those originaly posted sorta Hp/Torque numbers in a F truck and only a few F trucks in the world capable of such...
Those that are sure don't use the standard f 250 7.3 powerstroke powdered metal con rods - which are only good to about 400 RWHP max. Quite simply at those numbers the standard rods fly apart and exit via the sump or wall of the block.
It seems quite likely to me that your figures are in the old ft / lbs measurements for torque...
The most recent amended Hp figuresyou posted seem quite the norm for the mods mentioned and make a lot more sense.
When I first read the original post about the figures - my eyes bugged out at the idea I could get that sorta poke outta my Effie.....with just gas and a chip.
I gotta admit - I'd love to be able to blow that much black smoke like Dr Speeds Sled pulling P - Pumped 7.3 F truck pumps out when it's makin the numbers!
I'd be neat to see just ONE truck like that downunder!
Cheers!
FollowupID: 604673
Follow Up By: RV Powerstream P/L - Wednesday, Nov 26, 2008 at 13:55
The hunter Valley truck show on the Newcastle Waterfront just recently had a Kenworth Race truck there with a V16 GM mounted behind the cab and it sounded beautiful and it had a lumpy cam in it no exhaust other than a 6" bend out of the turbos 4 of.
Ian
FollowupID: 604677
Follow Up By: RV Powerstream P/L - Friday, Nov 28, 2008 at 15:29
Flywest
The figures given to me were while driving home and I now have the dyno printout.
The LBS/FT Figures were converted roughly to N/M and told in a way that maybe was confusing and were actually N/M so Ive then converted N/M figures to N/M again and came up with everyones dream of power that defies physics.
The figures are as follows .
Tested with Chip 830 LBS/FT =1125N/M
Plus Sequent 11 gas 1250 LBS/FT =1695N/M
Max HP on chip 179.4
plus gas 249.3
Ill try not to believe everything Im told in future and use a prove before post approach.
Ian
FollowupID: 604944
Reply By: Flywest - Tuesday, Nov 25, 2008 at 14:08
RedBakk,
I've run used oil analysis on our 2 vehicles before and after diesel gas conversion. (A f250 7.3 PSD & A Landcruiser 8o series 1HD-T) Both are turbo diesels - the F trucks intercooled.
Dieselgas Australlia (Lovato) did both the conversions.
In neither case have the manufacturers claims of "cleaner oil" been proven true with the used oil analysis testing.
We performed the sampling and testing using identical samples sent to 2 different laboratories, one here in WA (Westrac equip) and one in the USA (Oil Guard).
Both vehicles showed increased soot in the oil after conversion - not a decrease.
Having said that, it needs clarification to be fair to Diesel gas Australia!
In their website they do mention somewhere that immediately after conversion - the LPG will have the effect of cleaning up the deposits in the engine that accumulated while it was running as a standard diesel.
As a result they claim soot levels in the oil will increase for the first 2 oil changes after conversion, not decrease.
They also recommend dropping the oil after the first 1000 km's after conversion then again at the next 5000 km's to get rid of the extra soot deposits that the LPG will bring out of the engine, and deposit in the oil.
They never mentioned this 1000km oil drop to us at conversion I only read about it afterwards so we never did the 1000km's oil drops because we didn;t know about taht requirement instead we did 2 x 5000km oil drops.
As stated Soot levels were up (not down) in Both vehicles results.
However...
The F 250 was also fitted with sub micron oil bypass filtering supplied by Oil Guard USA, that sposed to remove almost al the soot anyway - and the inceased soot levels actually remain after more than the first 2 oil changes - they are still up, and there are afew other oil issues with both vehicles that we don;t seem to be able to resolve...despite all the testing.
The "other issues" are increased Sulphation, Nitration and Oxidation levels in Both vehicles.
This appears to be a result of - the addition of the LPG to the burn cycle.
LPG engined vehicles like forklifts use a much different oil with much higher sulphated ash levels that standard diesel engined vehicles for good reason.
It seems that while the addition of LPG certainly gives increased economy and savings based on out test figures - that the oil companys themselves have not as yet formulated any oils specifically for Diesel gas blends vehicles.
I have been in contact with Mobil in Australia about this issue because one of the oils we used that gave uisall these results is their premium fully synthetic Delvac one which costs about $20 a liter and is sposed to be good for extebnded oil change intervals, especially if you have sub micron oil bypass fltering to scrub your il clean of soot and other contaminants.
The testing resulyts showed no adverse wear metal results - it's justr that the oil has used all it's add pack of detergents etc in fighting the sulphation nitration and oxidation under hot Australian road use conditions - and isn't fot for any more than 5000 km changes based on the ressults in our vehicles.
Mobil say they have no plans to prodiuce any specific poil suited to diesle gas belnd engined vehicles- so it is up to users to find an oil that works with the gas if they want extended oil changes.
It might yet prove that the addition of LPGmeans you CAN'T run extended oil changes due to sulphation, nitration and oxidation issues.
It too early to tell - the jurys stil out on this issue of oil for diesel gas vehicles- the manufacturers have no helpfull adviceother than "use whatever the manufacturer of your engine recommends! Thats very helpfull when Used Oil Analysis proves even the best o f the bestDelvac 1 can't cope with diesel gas blend fuels!
It's an area the diesel gas manufacturers havent adequately supported their customers IMHO as an owner of 2 such converted vehicles.
There are other oil realted issues with respect to older Landcrusiers engines - that i won;t go into here since they seem to attract all manner of criticism...
What you do about converting r not is up to you,
All I'd suhggest after my experience is to do used oil analysis befiore and after converson andkeep good records of same.
I personally go to the trouble of graphing my results...
This is a UOA result from the F 250 before LPG & sub Micron Bypass filtering
Graphing various results trends
Unless you keep track and look for the trends - you are only really guessing about oils and that could be a bad risk to take with this new and unknown LPG diesel technology IMHO.
Some labs use different methods to analyse the samples also which makes comparison between labs results on the same samples difficult.
Some use infrared spectoral analysis for determining soot levels while others don't measure or report on soot at all!
Lastly - the info you get back from a used oil analysis is of little value if you don't have a virgin oil analysis to compare it too in the first place.
Howdo you know whether wear metal levels are up if you don;t know what those levels werein the clean oil you started with?
Thankfully that info can be found online if you know where to look.
You might for example worry if you got a result back saying wear metal for iron (fe) was 3ppm in your used oil analysis result - but if you knew the virgin oil had 2 ppm Iron Fe) in it when it was new- the extra 1 ppm wear metal of iron might not worry you so much!
Learning how to interpret used oil analysis results is a bit of an artform in itself.
My habit of testing the same oils in different labs at the same time even shows up some anopmoalies between labs on the same oil..
Theres always a possibility for shenannikins with UOA results....
Maybe they lost or mixedup the sample in the lab so gave you a copy of someone elses results!
Maybe newengine sales are down at the co this month and he sales guys need a bit of a helping hand so you get a dodgey result in the hope that you'll pannic and sell / trade your engine this month for a new onebefore the old one craps itself!
All I'm saying after the excercise in testing is - beware of the results you get, be prepaired to question them, educate yourself to be able to intepret them and keep good records (spreadsheet & graph them) to look for any trendsthat give clues to impending problems before they become serious issues.
Sorry the answer about soot isn;t an easy yes / no clearcut issue.
The truth is- theres more not known than is known on this particular issue.
The manufacturers of dieselgas technology aren't too happy that anyones actually looking as closely at their results as what I do - they would far prefer that customers wipe the dipstick on an old oily rag and say "yeah that looks cleaner than before"...
Take from the above what you will.
Cheers!
AnswerID: 336836
Follow Up By: Member - Redbakk (WA) - Tuesday, Nov 25, 2008 at 19:15
Flywest...you are a legend...thanks for all the info...much appreciated
FollowupID: 604579
Follow Up By: Flywest - Tuesday, Nov 25, 2008 at 20:20
You are more than welcome, its an interesting subject that I invested a lot of time Money and frustration into - the idea that someone else might benefit from that experience is one of the things motivates me to bother writing it all - and recording / analysing the results.
My other reason is that hopefully someone else with the same question at some point in the future will find the answers they seek via a search engine.
I do believe - that unless people bother to upload worthwhile info to the internet then it won't reach it's potential as a research tool
The other thing is - it helps keep the bastages honest as old Don Chip of the democrats was want to say!
The whole thing has got me too the point of believing that there COULD possibly be a small but growing market for sopmeone to specially blend an oil specifically for diesel gas conversion engines - since so far nothing from the major manufacturers seems to quite measure up.
You know - if the diesel gas conversion co's were smarter than they are - they would do this themselves and SELL theor happy customers their own special brlnd of diesel gas converted engine oil and add ongoing profits from their now once off conversion clients! ;o)
So far they don't seem to be quite that smart - I have a suspicion that all it might take, is to increase the sulphated ash content like they do for LPG powered forklift engines...
But there could be more too it and an industrial chemist could no doubt come up with better blends!
Another little gem I found out thats not often spelled out by the synthetic oil freaks...
Fully synthetic oils that derived from distilling esthers etc does have a lot of the claimed benefits in terms of uniformity.
Whats NOT spelled out is this.
It's a base 5 oil.
Yes - think Singer Sewing Machine Oil - i.e. thin - thin as water!
Now - the interesting thing withthis thin oil - is that - its formulated for VERY cold US and European climates where they have sow and ice and on cold start ups tolerances are very tight and a very thin base 5 oil is great in that situation.
We in Oz with the exception of parts of the snowfields inVoc and part sof tassie etc generally have deserts and bloody hot temps.
In HOT conditions THIN oil ain't all that good at protecting your engine.
So - what do the companys add to the base 5 synthetic oil to make it behave like a heavier 15 - 40 base oil?
Well it;s an emulsifier - that is NOT UNLIKE the goo in your viscous clutch fan in it's properties, i.e. the hotter the oil gets the thicker the emulsifier gets. (Think it thru, as the fan clutch gets hotter, the special goo inside gets hotter & thus thickens & the cluth grips more and the fan spins faster, to cool the radiator more).
The emulsifier addedto the thin base 5 synthetic oil works the same way - the hotter the engine and oil gets the thicker the thin base 5 oil gets - such that it acts like a 15 - W 40 oil under typical Aussie conditions.
Thats all well n good - I only have ONE concern about it!
Occasionally Viscous fans clutches fail - the goo leaks out or goes off / bad and stops doing it magic....and then the thermo fan thing is tossed out and a new one put in or sometimes just the goo replaced for new goo once it stops working asit should.
So if we start going for extended oil changes on this expensive $20 a liter fully synthetic oil, up to say 20,000 km;s on one oil change (with UOA testing) - whathappens IF - like the rest of the addpack - that special magic emusifier gets worn out used up or in some ways deteriorated by the aforementioned increased sulphation, nitration or oxidation effects of diesel gas conversion?
Well I guess your $10,000 or $20,000 intercooled turbo diesel engine is back to being lubricated in the heat of the Aussie desert by THIN base 5 (singer sewing machine) oil - at a time when it possibly needs a base 40 oil protecting it!
After the failure of Mobils Delvac 1 (and their subsequent re blending and repackaging re labelling) of the oil after they were advised of our results - I personallyhave a few reservations about recommending fullysynthetic oils for the moment - I remain to be fully convinced.
At $20 a liter the F truck takes 18 liters and the cruiser 12 - or 30 liters total ($600) for only 5000 km's (3000 miles)
Thats mighty expensive oil, if you do say 30 or 40,000 kms a year!
Specially when crude is back below $50 a barrel! ;o)
I could think of better things to spend say $3600 (5 changes a year at 30,000km's / vehicle) on what is essentially chemically derived base 5 singer sewing machine oil with magic thickener goo in it (emulsifier)! Especially 9 x 20 liter drums of it!
Good luck to those who go fully synthetic - been there done that, and it sucked big time.
Cheers!
FollowupID: 604598
Follow Up By: Member - Redbakk (WA) - Wednesday, Nov 26, 2008 at 10:44
Question...would a oil pressure gauge be or give some kind of indication on how the oil in the sump is preforming in regards to thickening or thinning ( viscosity) and also indicate that through operating temperature changes?
FollowupID: 604660
Follow Up By: Flywest - Wednesday, Nov 26, 2008 at 21:18
Indeed.
A working oil pressure gauge is a valuable assett in regards to monitoring oil pressure.
It should show any thinning of the oil, if the magic emulsifier in the fully synthetic oils were to be exausted or fail.
Theres another "quesionable" safeguard as well.
Chlorinated parrafin - used in the tooling industry, sppecifically in cutting and working steel on a lathe etc
It has very unusual lubricating properties - in tha it is attracted to heat, rather than repelled from heat source like most oils.
In a run low oil situation, where any direct metal to metal contact occurs the chlor paraffin is attaracted by the heat of friction and lubricates that spot, hence why it is so efficient in the tooling industry for industrial cutting etc.
Bitron is a co that packages Chlor Parrafin for use as an oil additive.
I have reservations about using it in an internal combustion engine - because the chlorine when it blows bye the rings and enters the sump - along with the gasses of exhaust will form hydrocloric acid and eat away the calcium or magnesium detergents put in the oil add pack to combat acids that caiuse corrosion....
So - while it may protect from heat damage and wear it also might result in internal corrosion.
Where i think Chlorinated Parrafin perhaps has GREAT potential is in lubricating things like diffs and gearboxes etc where there is no combustion gasses present yet heat caused by friction CAN be a problem in a oil run low situation.
Cheers!
FollowupID: 604721
Reply By: fwdfun - Tuesday, Nov 25, 2008 at 22:43
I converted my GU Patrol to Diesel Gas & applied for and received the federal government grant for gas conversion, which helped to ofset the cost of installation. It gave me a considerable power increase and minor improvement to fuel economy. Conversion was done at 26,000kms, and have now done 70,000kms. No noticeable difference in the oil colour. Overall very happy with it.
AnswerID: 336907
Follow Up By: Member - Redbakk (WA) - Wednesday, Nov 26, 2008 at 10:45
So your oil still is just as dirty as before?
FollowupID: 604662
