Keeping sand out of gennie
Submitted: Wednesday, Nov 26, 2008 at 11:07
ThreadID: 63803 Views:3644 Replies:6 FollowUps:6
Morning Team,
I do a bit of beach camping and my gennie always comes home with a fair bit of sand in it that I just blow out with compressed air. What I am after is something to put the gennie in on the sand to keep it sand free. This device needs to be compact and needs to fold up some how for easy storage while moving. I could probably make something out of wood with some hinges that fold up but does anyone know if there is an off the shelve product for this?
Reply By: Member - Beatit (QLD) - Wednesday, Nov 26, 2008 at 12:18
A small tarp! We find it works well - also need to keep that sand from getting into the intake when running as well as moisture if it's about!
Kind regards
AnswerID: 336960
Follow Up By: Member - Beatit (QLD) - Wednesday, Nov 26, 2008 at 16:14
Troll,
This how I also use mine when I travel with the trailer.
Image Could Not Be Found
Kind regards
FollowupID: 604690
Follow Up By: furph - Wednesday, Nov 26, 2008 at 17:44
Beatit.
That looks a great idea for transporting your unit, but it also looks like you have an exhaust extension to run it in that box.
With the hot engine cooling air blowing down into the box, the "cool" air pickup ducts are going to be recycling very hot air and that little motor is going to fairly cook.
I bought a Honda 10ui, and was told by the dealer that running it on fairly high load in around 35+ deg. ambient (which we do) will destroy that motor. Three years on and it using quite a bit of oil.
As it is I should have bought a 20ui, I run a 30a. battery charger plus up to 500w. of lighting when we have a "camp out".
They are a great product though, and so quiet till the eco throttle kicks out!
furph
FollowupID: 604700
Follow Up By: Member - Beatit (QLD) - Wednesday, Nov 26, 2008 at 17:54
G'day Furph,
Yeah I do run it in the box with the lid up mainly – it’s been OK. I was also concerned initially about the heat but after a couple of trips I’m less concerned. There is a fair bit of heat generated but it seems to be able to get out OK. A week on Fraser we had some rain as well and I had the camper tonneau cover over the boat rack then over the box. This also worked because the box was open and there was room for air to circulate.
I take your point though.
Kind regards
FollowupID: 604701
Follow Up By: Member - Troll 81 (QLD) - Wednesday, Nov 26, 2008 at 18:09
Will be perfect if I had a trailer :)
FollowupID: 604703
Follow Up By: Kiwi100 - Friday, Nov 28, 2008 at 18:56
Why not fit a 12V fan to the box, plugged in to the generator's 12V outlet?
Michael
FollowupID: 604973
Reply By: Axel [ the real one ] - Wednesday, Nov 26, 2008 at 13:12
Have a bit of a look see at the www.campertrailer .org under the tech tips - generator boxes , might just give you some ideas to modify.
AnswerID: 336966
Reply By: Member - Matthew C - Wednesday, Nov 26, 2008 at 16:04
Get one of those portable small dog kennels, they are easily folded up ,hard bottomed and about $25 from red dot type places.
Thats what we use and also keeps noise down.
Matt
AnswerID: 336978
might be the way to go thanks Matt
FollowupID: 604702
Reply By: Isuzumu - Wednesday, Nov 26, 2008 at 18:52
Saw a LC100 with the genny in the back, set permanently, on a fridge slide, worked great he said.
Cheers Bruce.
AnswerID: 336992
Reply By: Member - Redbakk (WA) - Wednesday, Nov 26, 2008 at 19:24
Hi Troll...I went to Bunnings and bought one of those solid rubber mats (no holes) and the genny sits on that.
The next morning when you pack up all you have to do is give the mat a shake and leave it turned over for a few minutes till it is dry and throw it in the back.....it is also handy for other things as well not least of which you can use it if you get bogged etc
AnswerID: 336993
Reply By: bilgolabands - Thursday, Nov 27, 2008 at 21:58
Very interested in your exhaust extension as we intend to run our 20ei in our yacht cockpit locker as well as our Campomatic.
Locker volume should be no problem re. cooling though I need to extend the exhaust to connect to an external hull fitting for obvious reasons.
Did you have any problem welding an extension to the small exhaust pipe and did it change the exhaust tuned length adversely.
Also what type of rubber (nitrile?) extended exhaust pipe did you use to cope with the heat.
Sorceress
AnswerID: 337166
