battery wiring jayco
Submitted: Wednesday, Nov 26, 2008 at 20:22
mintrax
I am about to put an agm battery in a jayco camper. There are two wires going to the battery box. Black and white.
I am presuming that black is positive and white neg or ground. Can someone confirm?
Reply By: Member - 1/2A - Wednesday, Nov 26, 2008 at 21:00
I suggest you purchase a multimeter, because if you get it wrong you could cause a fire.
337008
Reply By: Dunaruna - Wednesday, Nov 26, 2008 at 21:17
Yes, they are the colors that yanks (and jayco) use for aux circuits. Black is positive, white is negative. But i agree with the multi-meter comment, better be safe than sorry.
I usually heatshrink a red end over the black and a black end over the white to avoid future confusion if someone was to have a play with the wiring.
337010
Follow Up By: mintrax - Wednesday, Nov 26, 2008 at 21:25
Thanks for that. Yes I will put a multimeter across it but I just wanted to know the standard wiring config for the camper.
604722
Follow Up By: Dunaruna - Wednesday, Nov 26, 2008 at 21:38
Unfortunately, there is no standard. SHOULD be red positive, black negative in aussieland but the van builders seem to use whatever the heck they want.
The other day i was following an 8mm pink through the front boot and into the wall behind the fridge, it terminated at a fuse and then changed to 6mm black and then into the fridge connections - it was a jayco.
604723
Follow Up By: Member - Tessa (NSW) - Thursday, Nov 27, 2008 at 12:49
Jayco will use whatever they can get as long as it is cheap!
604790
