honda genni
Submitted: Wednesday, Nov 26, 2008 at 21:11
ThreadID: 63819 Views:2969 Replies:6 FollowUps:0
Hi explorers
I have 2 questions 1 can l charge a 12v battery straight from the eu20i question 2 l am after a 200ah deep cycle battery max price 550$ any thorghts
Reply By: Dunaruna - Wednesday, Nov 26, 2008 at 21:18
Yes. at full noise it is an 8amp charger. Underrated for a 200ah battery, but doable.
AnswerID: 337011
Reply By: Steve - Wednesday, Nov 26, 2008 at 21:36
2 x 100s would be better/easier to handle
$550????? Google is your friend - you just need to look around
Google.com
AnswerID: 337016
Reply By: Zukscooter - Wednesday, Nov 26, 2008 at 22:00
Ron,if you do a search on this sites search area onthe charging of batteries straight from the gennie i think you are putting your battery at risk.However if you use a battery charger between gen set & battery all should be ok.
Some more learned than i may be able to put you in the direction though.
Cheers Bob.
AnswerID: 337018
Reply By: Geoff (Newcastle, NSW) - Wednesday, Nov 26, 2008 at 22:22
Hi Ron,
First answer, I wouldn't use the DC output of any generator to charge batteries for a couple of reasons,
The output is unregulated. Meaning as the battery approaches full charge the voltage rises to the point it could cook your batteries.
Second reason, it's at best about 8 Amps. It's safer and more economical to use a good 240V 3-Stage battery charger of say 25 Amps between the gennie and the battery. You'll get a much faster rate of charge and the 3-Stage charger will protect your battery as well as charge it more thoroughly.
Second question, as others have said, Google is your friend. You'll get change from the $550 for a couple of Deep Cycle batteries. You should be able to score a couple of 100 Ahr AGM's for that.
Geoff
Geoff,
AnswerID: 337022
Reply By: Member - Russnic [NZ] - Thursday, Nov 27, 2008 at 06:38
Hi Ron
Yes you can charge a battery direct from a eu20i and have I done so, mainly to give a cheap electric fence battery a boost. The direct charger is unregulated so unless you are keeping a close check on the battery state of charge, I would not advise using it to charge expensive batteries. Far better to buy a 240v 3 stage charger and use that with the gen.
I use the eu20i quite often to charge batteries, sometimes have run 2 chargers 12 & 24v and also the direct charge at the same time, works on eco mode without a problem.
I have not had a lot of experience with generators but am continual surprised what a small package like the eu20i can do. Run a shearing machine, bench drill etc..., just a pity I can't run my old 3 phase welder off it. Might have to get a smaller inverter welder?
AnswerID: 337036
Reply By: Member - Troll 81 (QLD) - Thursday, Nov 27, 2008 at 09:10
yes you can but it's not a good idea and might fry your battery get a good charger and run that off the gennie
AnswerID: 337046
