Aftermarket steel rim failures
Submitted: Thursday, Nov 27, 2008 at 09:08
ThreadID: 63828 Views:9530 Replies:8 FollowUps:3
Hi all,
I received this safety alert from the Dept of Mines yesterday regarding failure of aftermarket steel rims on 4WD's. The alert refers to them as sunraysia style rims but they are not necessarily sunraysia brand.
DME Safety Alert- Aftermarket Steel Rim Failures
So for those of you with this style of steel rims it may be worth having them checked out.
Ando
Reply By: Member - Mfewster(SA) - Thursday, Nov 27, 2008 at 10:37
Thank you for that post. I will check mine immediately.
AnswerID: 337060
Reply By: Supercalafreakinawesome- Thursday, Nov 27, 2008 at 11:18
Hi andoland,
I recently bought sunraysia style rims for our caravan (16x7). They were Infinity Brand wheels. On the way back from a northern trip I checked the tyres daily and there seemed to be no problems.
We stopped at Clareview for the night and by morning one of the caravan tyres was flat. I changed it for the spare and inspected it but couldn't find anything obvious. On arrival back home I took the wheel in to the place I bought them from for a puncture repair.
It was found that the tyre was not punctured and that the rim had tiny holes or bubbles in the metal and that the during the flexing etc of the rim the air had found a way through the holes allowing it to deflate slowly.
Needless to say that the rim was replaced under warranty but I was lucky that the tyre went down overnight while stationary and not suddenly while on the highway or outback tracks.
I'm heading out to the shed now to check for cracks as per your thread as well. A bit worrying eh?
AnswerID: 337068
Reply By: Member - Redbakk (WA) - Thursday, Nov 27, 2008 at 12:04
Checked mine...all ok so far.....have ROH Australia TRAK2 written on them plus date of man numbers as well....how do you identify the dodgy ones ?
AnswerID: 337080
Follow Up By: andoland - Thursday, Nov 27, 2008 at 12:08
Redbakk I wish I could tell you which one are dodgy. I just received the safety alert through our safety department so don't know any more about it.
Ando
FollowupID: 604786
Reply By: knight44 - Thursday, Nov 27, 2008 at 12:29
This a posting from another website about the rim failures.
Re: possible Sunraysia rim failure warning/Email from Speedy
I received an email regarding a safety warning issued by BHP Billiton
in respect to our white steel wheels which is currently being hosted on your website.
There are a number of inaccuracies in the report, most concerning
being that the wheel in question which failed is definitely not a
Speedy wheel. For your info our wheels have always carried a
red/green pinstripe. The wheel which failed bears red/blue
pinstriping. I can think of at least 3 other manufacturers in
Australia who run this colour scheme so it's difficult to say where
the wheel originated.
I'm sure that you can understand our concern and would appreciate if
you could remove the safety warning from your website until we can
get to the bottom of the matter.
I have been in touch with the minesite to have the matter
corrected/retracted as these type of electronic releases can spread
quickly and quite easily have the potential to harm our reputation. I
will keep you posted on any developments.
Thanks for your time.
Best regards,
Luke Tonkin | Speedy Wheels
Web : speedywheels.com.au
AnswerID: 337083
Follow Up By: Gerhardp1 - Friday, Nov 28, 2008 at 17:44
Don't you just love this e-mail
To paraphrase
"Please allow your people to get killed or injured while we 'get to the bottom of the matter' . We don't want our reputation sullied even though we aren't sure if our wheels crack or not.
We'd rather you take down the safety warning and expose yourself to very high compensation claims if such an event occurs after you have become aware of the potential for failure.
Then, (as long as it's not one of ours) we are in the clear. That would be great, thanks."
As if !!!
FollowupID: 604959
Reply By: Bob Y. - Qld - Thursday, Nov 27, 2008 at 15:35
We bought 6 of these "sunraysias" to put on a 79 series ute.
The cartons containing the wheels gave Brazil as manufacturing country. Can't remember the stripe colours, & the vehicle is away at moment.
I'd suggest that these wheels might be less safe than aussie made ones.
Just something else to check regularly, eh?
Bob.
AnswerID: 337095
Reply By: offroad Bob - Thursday, Nov 27, 2008 at 19:57
I too have purchased 6 of these sunraysia type rims only to have 3 fail.Mine all failed along a bend line of the rim - one step in from where the lead weights attach on the outside. The first two the tyre shop replaced under warranty but with the third rim I demanded the full set replaced. From my research the only two types of rims to have are either ROH or Speedy. There seems to be other cheaper ones coming on the market but are just not good enough.Mine where replaced with Speedy rims and haven't had a problem for two years now.
AnswerID: 337136
Reply By: Member - Mark E (VIC) - Thursday, Nov 27, 2008 at 20:50
I'm led to believe that there are two different quality rims available in this style, one with ?3mm steel and one with 4mm steel. I'm not completely sure of the steel thicknesses, but it was something similar.
The 'cheaper' of the two were apparently sold for about $60 a rim, whilst the better ones were about $110 each.
It's the old adage......you get what you pay for.
I just replaced my old splitties with the Toyota steel 16x8 rims, which look very strong.
Mark
AnswerID: 337146
Follow Up By: Member - Phil G (SA) - Friday, Nov 28, 2008 at 18:25
Gday Mark,
I've got 2 sets and just took a measurement:
Toyota GXL 16x8 are a touch over 6mm thick.
Speedy Desert Rat 16x7 are ~5mm thick.
The Speedys have done a lot of hard work without a problem - they are made in Taiwan.
FollowupID: 604970
Reply By: Eric Experience - Thursday, Nov 27, 2008 at 21:30
Hello to wheel owners.
Anyone with a set of the Brazil made 16x7 wheels damaged or not I would like to see them, I am in Melbourne, Will pay frieght. Thanks,
Eric
AnswerID: 337158
