FZJ105 Heater tap
Submitted: Thursday, Nov 27, 2008 at 19:19
oldpop
Can anyone tell me where to find the heater tap is and is it adjustable warm air coming in thru the vents
Oldpop
Reply By: Member - Ian H (NSW) - Thursday, Nov 27, 2008 at 19:33
Probably on the firewall and yes.
337127
Reply By: Col_and_Jan - Thursday, Nov 27, 2008 at 19:49
I may be wrong, but I thought that with this model, there is no valve (or tap) to stop
water going to the heater.
Water runs continuously through the heater, but there is some type of flap which controls the air to the heater, thus controlling the heat.
Col
337131
Follow Up By: oldpop - Thursday, Nov 27, 2008 at 19:54
Thanks for that there is no heater tap in engine bay maybe have to look further under dash
Thanks Oldpop
604852
Follow Up By: Col_and_Jan - Thursday, Nov 27, 2008 at 22:08
The
LCOOL site is fantastic with Cruisers. You may have to join the
forum to access the site.
I have copied some info:
"The 100's have no heater valve,
the knob controls an air flap that directs air via the heater core or not.
Sounds like the heater door is stuck, or the actuator has failed.
Accessed by removing the glove box and liner.
You should see 2 servos, the 2nd is the "air outlet servomotor" which you'll be able to identify by switching
the knob from defrost to feet to face, etc.
Col
604868
Follow Up By: oldpop - Friday, Nov 28, 2008 at 06:18
Col thanks for that
will check it out over weekend
regards
Old pop
604903
