SWB LIFT KIT
Submitted: Saturday, Nov 29, 2008 at 11:35
x-man
I have Just installed a two inch
suspension lift on a 1988 SWB Maverick. Running 33" coopers under it now however have a horrible vibration in drive train. I'm assuming it because on raised angle of gear box to rear diff. My question is has anyone got some tips ideas that may help. I have purchased gear box spacers and upper and lower adjustable arms to alleviate the problem (hopefully). Can not find info any where on how to install spacers are they easy enough to install?
Reply By: Pezza (Bris) - Saturday, Nov 29, 2008 at 12:09
x-man,
Put a trolley jack under the gearbox, undo the 4 bolts holding the cross member to the Chassis, lower the box, insert spacers between cross member and chassis, reinstall longer bolts that you have puchased prior to starting job. (Only do one side at a time to avoid having to line up the whole lot again)
Since you have already purchaed the above items then try all them first, if it's still there then you may want to try offset caster correction bushes in front diff.
Pezza
337390
Follow Up By: x-man - Saturday, Nov 29, 2008 at 12:22
Thanks for your help. I have also purchased castor bushes forgot to mention that before.
605029
Follow Up By: x-man - Saturday, Nov 29, 2008 at 15:17
Spacers in took a whole fourty mins. All went
well. Still got vibration doesn't seem as bad now though so shall put rest of gear on when it arrives and go from there. Cross fingers it dissapears.
605033
Reply By: Oldsquizzy (Kununurra) - Saturday, Nov 29, 2008 at 18:53
How long since you have had the universals replaced in tailshaft. One of the most common causes of vibration after a lift is universals worn.
337420
Follow Up By: x-man - Saturday, Nov 29, 2008 at 21:53
Twenty years. They have never been changed car had an easy life only done 130000k so far. Something to look into if the other mod's don't fix problem. Cheers mate.
605086
